m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 3,735
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
Good morning. 73 going to 88 with cloudy conditions today
Took the old pressure washer pump apart and pressed out the crank with bearings. Today will look at the new to me housing. It has the pistons in it but missing the crank and then clean it up and look to see if any parts are needed for assembly. Hope the cylinder sleeves can stay in place. If they need to come out will have to fabricate a puller
Stacked two loads of firewood following the plan.
Discovered a water leak in the copper tubing at the well water pressure tank in the basement. It is spraying out about 6 ft in a very small stream. This morning will stop it with a piece of rubber inner tube and hose clamp while pondering fix it myself or call plumber. Will post a picture later today
Plan to video call daughter today to give her some emotional support.
