Good morning!!!!
   / Good morning!!!! #171,085
Thanks for sharing PopG. Boyo would be in the next county. In a couple of weeks We will be going to a new Vet and Vet clinic for the first time. I've only been in a Vet's office once in the +2 years We've had him due to our former clinic's Covid 19 "drop off-wait-pick up" policy. This should be "interesting."
   / Good morning!!!! #171,087
84F and Fair @ 14:30, HI 86F, heading up to around 86F for the day's high.
Spent the night in the garage planting winter squash and pumpkin seeds with the overhead door open, getting those watered in - it was very relaxing and quite pleasant ... (y)
Seemed like a better way to go (as opposed to sharpening blades), given the hand cramping.
Got 5 seeds planted in pots (one seed per pot) for each of the following:
Winter Squash:
Hubbard Golden
Hubbard Blue
Guatemalan Blue
Pink Banana Jumbo
Sweet Meat
Pumpkins:
Big Max
Mammoth Gold
Kentucky Field
Small Sugar
Limited it to 5 seeds per variety to minimize the watering burden until they can be gotten in the ground. Will probably plant more eventually, as the existing ones get planted. Still have several varieties I haven't gotten to yet.
Plant order from Burgess finally arrived, haven't inspected it yet.
Woman out doing purchase returns and laying in a stock of cat food for the beasts before her departure in a couple of days.
First item on my agenda for the rest of the afternoon is to water plants in pots around back.
Then probably work on getting decking boards cut for shelving.
If I can get enough done for another shelf, maybe load the pots in garage and get those moved around back and set out.
Beyond that see what else comes up.
Hope everyone is having a good Wednesday ... (y)
   / Good morning!!!! #171,088
Here is another. This was from a “down”. Admittedly I didn’t tell her to come, only told her that she was free.
She did come when called at the end, but I thought it was pretty funny.
She took you literally ... ;)
Thanks for posting that ... (y)
   / Good morning!!!! #171,089
I thought I needed to paint a realistic picture. She is far from a well behaved dog, but she loves people, and we are constantly working on manners. Ask Dennis,Drew or Ken. It it doesn’t matter if they love her, she is going to fawn over them.
   / Good morning!!!! #171,090
From what I can make out in their parts lists, there isn’t any. The stapler can fire 2 staples per second, so they aren’t driven by air, nor does it exhaust any. I’m guessing that they are mechanically loading a piston in a captive gas cylinder and using that stored energy to drive the staple like a spring.
It’s also very frugal with power consumption. May Frits will put his analytical engineering abilities to work and give us his thoughts.
Bu regardless HOW it does it, it really does it well.
That is surprising, because in my mind the difference would be having an outlet on the cylinder vs no outlet - so the motor and reciprocating mechanism could be, but then again people with engineering degrees and marketing degrees get to make those decisions, not us normal people!
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
METRIC DUAL CUT TAP & DIE SET (A58374)
METRIC DUAL CUT...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2013 Ford F-150...
2008 Ford F-350 Crew Cab Pickup Truck (A56858)
2008 Ford F-350...
