Good morning!!!!
   / Good morning!!!! #167,313
65°F and 6.07 inches rain. It’s been a bit moist.
Currently a pause in the rain but more forecast. Will definitely impact todays’s activities.
In person Happy Hour at neighbors this afternoon.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #167,314
Don, If adults have money for Easter egg hunts the recession must not be hitting Texas yet. That farm is quite the entertainment industry.
Chris
This is the fastest growing area in the US. The adult Egg Hunt is a date night entertainment. 1500 wooden eggs are hidden in 15 acres at night to make it more challenging. The eggs have numbers on them and at the end of the hunt numbers are called out and prizes given with matching numbered eggs (egg lottery)
   / Good morning!!!! #167,316
63F and partly cloudy @ 13:45, heading up to around 66F for the day's high.
Got hopper and two tube feeders refilled yesterday, also one suet feeder. Plus scattered some cracked corn for the ground feeders.
After that spent the rest of the day up in the shop working on the sheet metal repair to the saw base.
Overall, it went ok ... the end result isn't perfect ... but it turned out reasonably decent.
Probably should have started by welding at the opposite end, which would have given more purchase for the new section when it came time to heat and bend it:
Tacked:
Even so, the welds held when I started to heat and bend it:
Center in the opening deformed slightly when I bent it, eventually cleaned that up with a zip disc on the angle grinder:
Even managed to get some sanding done on it (sides and top) before I quit late last night:
I did discover some more silicone rubber on it which I hit with the McKanica remover. Will need to see if that got it all today and if not hit it again.
Then sand the bottom and wash it off.
Likely will not sand and repaint the inside.
After that I can start squirting and shoot it with some primer.
Worked some on the getting the plug put on the power cord before I quit for the night.
Amazon due in today (a day early) with the t-strip edging and double-sided laminate tape for the fence.
Hope everyone is having a good Monday ... (y)
   / Good morning!!!! #167,319
Good Morning - currently 73°
Drew - glad you made it home safely..
It was a nice weekend here , mother-inlaw is here for this week..My son and I went and saw the new John Wick movie at the theatre. It was ok..
Hope everyone had a good weekend..
Mark
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
1997 HUBBLER BROS. LOGGING TRAILER (A58214)
1997 HUBBLER BROS...
2020 MACK P164T (A58214)
2020 MACK P164T...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
