Good morning!!!!
   / Good morning!!!! #155,831
I went to the toolbox to take some pictures before RNG posted that a blind hole pulled is the solution.
My suggestion to try grease was based primarily on cost of tools. Blind hole pullers aren’t cheap, they are pretty size specific and then you need to set up a bridge or slide hammer to do the actual pulling. There is an example of a blind hole puller on the bottom right. A small slide hammer with internal expanding jaws might work, the jaws in the one pictured expand outward when the screw is tightened.
However, the pictured tools are all SnapOn, and I’m sure painfully expensive in todays dollars.
If you have access to a lathe, you could make an internal puller pretty quickly if you already have a slide hammer.
Here is one drawer or puller bits to be fashioned to do a lot of tasks.
Agree they are not cheap. I will try other solutions before going that route
Plugging the oil passage and using grease would be my first choice
   / Good morning!!!! #155,832
I would be worried about using the grease pressure as the aluminium housing cannot take the pressure needed to push a bearing like that out. The housing will break out first. It would be cheaper in the long run just to buy the correct puller than a new housing.
   / Good morning!!!! #155,833
SUCCESS! The transfer case is reassembled, ready togo back into the Jeep tomorrow.
I went to HF and got another "mini" 2 lb slide hammer wit very small puller arms. Fought for about an hour, the little arms kept popping off the race. So, used pieces from my other pullers, made and external frame, and slowly applied the pulling pressure. Left the pressure on and heated up the "cup" the bearing was in. POP! ok, it moved an 1/8".... repeated 3 times and out it came!
Thanks for all the suggestions, it was a true mix of many great solutions.
I looked into getting a real 'blind hole puller'..... they are seriously proud of them... ranged from $450-720. Ridiculous! I don't do enough to warrant those prices.
RNG, I was mistaken.... I have the axle bearing puller set from HF.... I noticed that one was made for pilot and needle bearings ---- it would have been the correct set. Unfortunately, the local store didn't have one anyway.
There was definitely something awry with the transfer case before the rebuild. Now everything spins easy and quiet. Now just to get it back into the Jeep.
I told my daughter's boyfriend that this work was his birthday present.... for about the next 10 years! My guesstimate of the labor would be close to $3K for everything that was done.
Thanks again for all the great suggestions!
No rain made an appearance today.... even though the weather guessers were hyping up the possibilities. Maybe some overnight--- fingers crossed.
   / Good morning!!!! #155,834
Great! Stepdaughter just found out (home test) she's alligatorus positive. And yes, she is vaxxed.
I don't know the latest company rules, but I'll need to find out before going to work
Aug. 23, 2022 – The incubation period from infection to symptoms or a first positive COVID-19 test has decreased as the coronavirus has evolved, dropping from 5 days to 3.5 days, according to a new studypublished in JAMA Network Open.
From CDC: August 2022
Persons who have had recent confirmed or suspected exposure to an infected person should wear a mask for 10 days around others when indoors in public and should receive testing ≥5 days after exposure (or sooner, if they are symptomatic), irrespective of their vaccination status.§§§§ In light of high population levels of anti–SARS-CoV-2 seroprevalence (7,16), and to limit social and economic impacts, quarantine of exposed persons is no longer recommended, regardless of vaccination status.
   / Good morning!!!! #155,835
I was just remembering 9/11 and how surreal it was. I was in Goose Bay Labrador on a trip. Everyone was in disbelief and the airport was a zoo. Most of the diversions went to St John’s, but there were enough to overwhelm the facility.
The Canadians were very sympathetic and helpful, my stay was almost a week longer than anticipated.
We were able to leave Goose and go to North Bay which was our next stop anyway. So I waited there until the border opened up again.
   / Good morning!!!! #155,836
If I can help BEF let me know I was born and raised in Roanoke
Thanks,
In NE of troutville, Botetourt co
Price a little higher than we like, but did find it was just perc’d. Neighbors own it according to tax records. Hopefully wells there not as deep.
Haven’t made offer, it will probably sell before we have time to go look.
They just had it resurveyed and moved some boundaries in July.
   / Good morning!!!! #155,837
Where did you find this, BEF? I need something like that on the Husqvarna. Mowing the pasture is a lot bumpier than the rest, and makes my compressed disc less happy.
Edit: Ah, just found it on Amazon.
Got mine from Amazon $159 labeled exmark. Same one kubota sells for $300. It’s not air ride, but it helps.
   / Good morning!!!! #155,838
Good late (Monday) morning. Winter is still hanging around as the overnight Low was 0.2C. It's sunny but with a breeze and there was 0.5mm in the gauge from a brief downpour yesterday arvo. it's presently 16.2C, which is a good 3 degrees above the predicted High.
I'll need to chain-harrow paddocks 3/4/5 as the Agisting Lady finally moved one of her ponies down to Triabunna to be a companion to another horse down there. Her other horse was put in with the 'Mad Horse Woman's on the adjacent paddock and I anticipate a new horse coming sometime next month.
Other than that, I'm got a Church Council meeting later this arvo. I'm fairly positive that I'll drive into Launceston tomorrow to accomplish a few things prior to my trip to visit family in Canada (Burlington, Ontario) on the 22nd.
That's about all, take care all.
   / Good morning!!!! #155,839
All this tutelage on bearing removal almost makes me wish I had one for removal. Not exactly, but I sure did enjoy reading and have filed away for future reference.
   / Good morning!!!! #155,840
Lot of tools I’ve never seen before.
1986 KURZ & ROOT 3500A GENERATOR (A52576)
1986 KURZ & ROOT...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
HOME MADE SMOKER / FRYER TRAILER (A52472)
HOME MADE SMOKER /...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
100 GAL FUEL TANK AND TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
