m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 3,731
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
I went to the toolbox to take some pictures before RNG posted that a blind hole pulled is the solution.
My suggestion to try grease was based primarily on cost of tools. Blind hole pullers aren’t cheap, they are pretty size specific and then you need to set up a bridge or slide hammer to do the actual pulling. There is an example of a blind hole puller on the bottom right. A small slide hammer with internal expanding jaws might work, the jaws in the one pictured expand outward when the screw is tightened.
However, the pictured tools are all SnapOn, and I’m sure painfully expensive in todays dollars.
If you have access to a lathe, you could make an internal puller pretty quickly if you already have a slide hammer.
Here is one drawer or puller bits to be fashioned to do a lot of tasks.
Agree they are not cheap. I will try other solutions before going that route
Plugging the oil passage and using grease would be my first choice
