Good morning!!!!
   / Good morning!!!! #129,401
25 high of 61 today as week goes by temperatures rise into 70s no rain till next Sunday. Prayers for all our Country
   / Good morning!!!! #129,402
Need to pour first cup of coffee. 25° with partly cloudy skies this morning. Heading to 61° with a mix of sun and clouds. Good visit with my son yesterday. Checked out his new bike. Very nice looking. 2007 Honda Shadow. With today's warm weather plan to start cleanup of yard.
Alien, hope the get some results soon.
Buppies, did I see where date for you surgery is 3/14. That's start of daylight savings.
Don, you had no backup of your phones to transfer to new phones?
Everyone stay safe and healthy.
Good Morning All.
   / Good morning!!!! #129,403
3/12 is the date Ron
   / Good morning!!!! #129,405
Thanks Ron great picture of nut hatch
   / Good morning!!!! #129,406
good morning all. 24 going up to mid 40's today, should be a nice day.
Electrician coming this morning to give quote on upgrading electrical service to 200amps from 100 so I can install a/c in this
little cottage. Really don't want to go to window units so trying to work a deal with landlord that if she pays for upgrading the electrical service,
I might split half the cost of hvac system with her. Have no idea what adding a/c to an existing hot air system will cost and whether mini system which I assume
means running more piping will be less expensive. This is all predicated on my getting a five year lease, which she was fine with.
going to cut off my beard this morning, went to grab clippers and saw the charger plug had fallen out, no juice. Oh well, later today. Warmer weather coming in and I'm happy
to celebrate approaching Spring with less hair.
   / Good morning!!!! #129,407
Morning all!
15 here going to a sunny 35. Looks like we have a week of above normal temps coming after today!
Need to get out and do more branch cleanup before the ground is to wet. Not much else planned for the day.
Furnace guy coming tomorrow to flush out the old antifreeze from the lines. When it gets old it starts plugging up all the one way valves and vents. Thinking on draining the in the floor heat in our sun room and shutting it off. We can change out the antifreeze for plain water if we do that.
It will still be available when/if we sell the house.
Hope everyone stays safe and healthy!
   / Good morning!!!! #129,408
Good Morning!!!! 50F @ 4:00AM. A mix of clouds and sun this morning followed by increasing clouds with showers developing this afternoon. High near 55F. Winds SSE at 15 to 25 mph. Chance of rain 60%. Higher wind gusts possible.
Split two more pallets of fire wood yesterday, then stacked the pallets into the container. I think there's room for 16 more. Need to get busy making more hoops, but not until it stops raining later this week.
Did some more reading on the gate opener, and there's a reset procedure I'll try later this morning. Also gonna take another shot at getting the keypad programmed.
I also want to rake out the burn pile so the coming rain can put out any remaining embers.
Hope everyone's week gets off to a great start!
   / Good morning!!!! #129,409
9F clear sky mid 30's for high.
Plans for today...fill Mrs. kindling area hope for the last time this winter,basement needs good sweeping,if not today than tomorrow remove snow bank with tractor place pickup plow on pallet until next winter,other than slow motion day.
Enjoy the day all.
   / Good morning!!!! #129,410
Good morning
It’s 23 and not he brilliant day without a cloud in the sky. High of 43 is forecast.
Yesterday was a lazy day. My mechanical contractor buddy came by and we came up with a plan to and some ductwork in my basement. I finished the entire basement about 25 years ago and it was never as comfortable as it could be in the winter. AC is fine, but some rooms were colder than the rest of the house in heat mode. We came up with a fix some simple that I feel bad about taking so long to get around to it.
Drew I would think that the simplest way for you to gate AC would be to add a coil to the supply duct from your furnace and a condenser outside. If your furnace is in the basement, it would not be a complicated or intrusive operation. You might even consider putting in a heat pump, as they don’t add much over a straight AC condenser, and would give you another heat source and a hedge against oil prices if they skyrocket.
Mostly- I generally mix music that was recorded here, some ordinal, some cover songs.
Still not vaccinated, but expanding my attempts.
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
Hustler super Z zero turn (A56859)
Hustler super Z...
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
Flameshield Safety Oil Tank (A59814)
Flameshield Safety...
