Good morning!!!!
   / Good morning!!!! #119,951
Good morning to all! Low of 49, going for 82. No rain....
CONGRATULATIONS TO Phil! You are going to need that few extra hours of sleep now that the real work is about to begin! Nice to be able to make the choice of WHEN you will do it though!
Mostly, when you get done with your gopher, I have a few you can try and get ! Come on up and have fun!
Rng, I hope the new trouble codes are an easy fix... you have progressed too far to have to start digging back into the inner workings again...
Did some errands yesterday and by the time I got home, it was just too darn warm to work on the trailer. No rush on it, so I'll do a little at a time so it is at least a little enjoyable. Will work on it a bit today.
Everyone have a great day!
   / Good morning!!!! #119,952
72°F and .09 inches rain, raining as I type.
Squared, plumb, and anchored, happy with my wall framing. Ready to start the roof.
Raining harder. Could curtail my outside activity but we definitely need the rain.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #119,953
Best of luck at hospital, Drew. Just a couple of days andyou start a new chapter 🤙
   / Good morning!!!! #119,954
Hope you got good news on hearing test, Ron. Another great pic, thanks
   / Good morning!!!! #119,955
Hard to keep up with you Mike. I think you fall in with the pacesetter group.
Hope you find relieffor shoulder soon.
   / Good morning!!!! #119,956
long day but good day at hospital, all tests came back fine, labs all within range and PET showed no spread and original spot shrunk to almost nothing.
All good. Thanks for all the well wishes. Boy I need a nap...
   / Good morning!!!! #119,957
I suppose a congratulations is in order for RNG as well, leaping that final hurdle with the Vanagon project.
It was more of a relief than an accomplishment, Paul, but thanks. There's still a TON of stuff left to do:
Fix emergency brake and seat belt idiot lights
Fix fuel gauge
Straighten steering wheel
Find and fix rattles -
Panel stiffeners
Clean turn signal stalk contacts
Move Westfalia plate from donor to Syncro
Install radar detector
Install speaker lead for GPS/Satellite radio
Recalibrate speedo
Recalibrate tach
3M heavy duty velcro hooks for carpet mats
Replace vacuum lines
Buy RV Mat - CGear - RV Sand-Free Mat by CGear [Review] - YouTube
Replace brake pads with PBR Axxis Dulexe Plus Brakes
Replace Nerf bars. 2.375 x 1 9/16 x 10' -> 2 1/2 x 1 1/2 x 11 ga (0.180?
Install Propex heater
Install propane tank
Install refrigerator
Refinish and install cabinets
Refinish and install door cards
Refinish and install upper bunk panels
Paint stripe
Fix water leaks -
driver and passenger side door leaks at top - done
sliding window felt seals
sliding window latch leaks - done
door handles
wing window penetrations - done
Check for vacuum leaks
Complete cruise control installation
Fix oil leak on oil pan front top lip
Fix oil leak on decoupler
reupholster front & middle headliners and install
replace front and back seat upholstery and cushions
wheel hub spinners
wood handle for emergency brake
Install laminate flooring
I do take some comfort in the ta done list being twice as long as the to do list, but the van is still an opportunity rich environment! :rotfl:
   / Good morning!!!! #119,958
Passed your smog test, excellent 🤙🤙🤙
   / Good morning!!!! #119,959
Extra prayers for your Dr friend, Rich
   / Good morning!!!! #119,960
Drew, good news !
RNG - but other than this list, pretty much done :D
golf cart (A56859)
golf cart (A56859)
Teakwood Horse Stool (A57454)
Teakwood Horse...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
Unused 20x20 Carport With 10' Half Enclosed Side Walls (A55272)
Unused 20x20...
2020 DRAGON ESP...
