Good morning!!!!
   / Good morning!!!! #98,351
And on gravel away from all food, I'll be using some this afternoon.
with gloves on for the first time.
I'll be doing the same this weekend. For better or worse, it's still the best product available to do what needs to be done.
Besides, if I captured rainwater and sprayed it on my driveway weeds, someone would find a reason to complain about that, too.
   / Good morning!!!! #98,352
Pretty day, low 80s sun and clouds. Club meeting and dinner last night, good to be getting out some.
I use glyphosate on my raised beds about now, in two weeks I plant mums and pansies, they grow just fine. It痴 not a pre emergent so it has to be sprayed on the plant.
Prayers for all in need. BEF, still rooting for you.
   / Good morning!!!! #98,354
my neighbor and I struggled for over an hour to get my chipper moved five feet. Put it in middle of shed with medium Massey, the one I sold. Big Massey won't fit under shed roof. My neighbor's JD 3 with sun roof could not quite clear the ceiling beams, third one in was lower than outside one and boy I'm glad we went slowly, particularly with his Uncles' brand new tractor. So we dragged it onto a pallet after having to reinforce the pallet, then dragged the pallet far enough out we could get nose of big Massey under shed roof and position. So much to go such a little way...
chipper is sold, 13 hours. Not one of my better ideas, found burn pile way easier.
Guy who owns a pool company over in Raleigh answered my craigslist ad. Seems like a nice guy and didn't try to beat me
down on price.
Another guy emailed yesterday asking if I'd take 500 dollars less for a cash price.
What did he think he was going to pay me in? Watermelons? Happily replied it sold for full asking price.
   / Good morning!!!! #98,355
Thanks for the news on glyphosate, Drew. I've always been careful about skin contact, but only recently started wearing a respirator with cartridges approved for organic chemicals, the same one I wear when spraying paint. It's a real killjoy for the spraying job, but then again I suppose cancer is even more so.
When I've had to move things I can't get to with the pallet forks, I've either hooked enough log chain together to reach between it and the tractor, or used jacks to lift it and put steel pipes under it so I could roll it. That only works on concrete or asphalt, though.
Remember I said the forecast for fire weather never materialized? Well, I was wrong. I've always seen it on my WeatherUnderground page, and today it wasn't there. It was plastered all over the NOAA page, though, and a good size thunderhead just rattled overhead. I just got home after my ride, with enough time to squirt some Gunk on the bike, and now it's raining lightly, probably still going to need a hose and brush.
Maybe I spoke (wrote?) too soon? Radar sez there's a blob of yellow and orange that just sprung up out of nowhere taking pretty good aim here. So maybe I'll get a free bike and VW wash!:cool2:
Oh, and the flat spot is gone, there were no oil leaks, and after some thought, the static I hear in the audio system might be coming from the tachometer pickup wire going to the new dash instrument. It was wrapped around a spark plug cable, which according to the instructions, was an OK thing to do. But because this fancy German ignition system apparently fires each plug three times instead of just one, the RPM reading is way high. I disconnected the tach wire to avoid the flashing red light from the instrument, but now I think I'll hook it to the same terminal that my analog tachometer uses and see if that takes care of the static. Otherwise it was an interesting ride. One of the roads I was on just a couple weeks ago now had a stream crossing, only about five feet wide, but deep and soft enough to get my heart started. When in doubt, gas it was never more true. And the Buck's Lake road between Quincy and Oroville is still out after going on three years, and they were working on the dirt fire road when I came through. It was wet from a water truck, which left me a bit anxious with the mud, but about half way through they were spreading gravel and rolling it, mostly in the oncoming lane. I took it easy and had no problems, but it sure makes me wonder if there are any plans to fix the highway, or if the county just can't afford to.:shocked:
   / Good morning!!!! #98,356
58 this morning and 80 currently. Nice low humidity. But foggy this morning.
Started dragging logs out. Think excavator is done. Now for the cleanup. Started looking around and figuring out a sorting plan. Initial count is 70-80 poplar logs. That is around 2 loads headed to the mill when I get them all dragged out. I’ll get everything piled and have a buyer come look at them.
Drew. Nice chipper. Glad you sold it quickly and for asking. Shows fair pricing. Glad it was a good program. Your takeaway is very good to hear. It’s the safest product on the market to do its job. It’s refreshing they were able to convey that. I wear gloves spraying glyphosate but I should do a better job of wearing them when I spray 2,4d. I stopped to talk to the farmer that buys my litter. He made a comment about the lawsuits. Said according to the courts he should be dead. A guy got cancer spraying his driveway from a gallon jug. He sprays 700-800 gallons of concentrate every year. Said something didn’t make sense.
Question for y’all. What is the most absorptive patch of skin on your body?
   / Good morning!!!! #98,359
My estimate this month is 2670 kwh $257
Last month 1804 kwh $176.
   / Good morning!!!! #98,360
I envy you, we pay just over 36c per KWH plus a $1.40 per day supply charge, fortunately the solar helps take a large lump off this off during summer and autumn with an infeed rate of 12c per KWH.
We run most things during daylight to keep the bill down such as dishwasher, washing and the heat pump hot water.
Hustler super Z zero turn (A56859)
Hustler super Z...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
40' Sea Container (A55272)
40' Sea Container...
Sedan (A59231)
Sedan (A59231)
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
