Good morning!!!!
   / Good morning!!!! #98,341
Good morning 70 now heading to 80 today
Heading to see my grandson for a little bit then having gutters put across the front of the 3 car garage at the lake and get recommendation for some sort of a gutter guard to keep acorns out
Don sounds like a frustrating day at DMV guess it really doesn't matter what state Motor Vehicle Departments are all alike. I think DMV clerks go to the same training as car salesman.
Enjoy the day and stay safe
   / Good morning!!!! #98,342
61 high of 84 today maybe a shower
Prayers for Betty and Ron BEF and Toppop and all others I missed
Thanks for the prayers each day!!
   / Good morning!!!! #98,343
Good Morning. It's 77° this morning and going to 97° this afternoon.
Rain got so close yesterday that I could smell it but not a drop. No rain in our forecast until this Friday. I'm thinking ..... the Ranch is in a "rain repel" zone?
Don ..... the Governor heard the People.
Gov. Abbott's push to end long lines at DPS offices across the state
Gov. Abbott's push to end long lines at DPS offices across the...
Drew .... I hope the presentation is actually balanced. There's so much mis-information and flat out lies out there, on glyphosate, spread by unscrupulous lawyers.
BEF & Randy ... keep making progress.
Ron ... You and your Mrs. continue to be in our prayers.
Hope everyone has an excellent Hump Day.
Prayers to all.
   / Good morning!!!! #98,344
Don. Wow, thought DMV was bad here...
68° more humid, overcast.
Not much else to report.
   / Good morning!!!! #98,345
65°F and clear skies this morning, going up to 83° today. Warming to near 90° tomorrow, but back to low 80s for the weekend.
Don, the extra push for proof of citizenship is because the REAL ID Act kicks into full gear next year, courtesy of Homeland Security. Without an approved DL or ID (or a valid passport), you won't be able to board a plane anymore.
   / Good morning!!!! #98,346
Good Morning!!!! 76F @ 6:15AM. Some clouds this morning will give way to generally sunny skies for the afternoon. High 96F. Winds S at 5 to 10 mph.
A few days ago there were weather warnings for today that included thunder storms. Today, they've disappeared and all we get are clouds. That's a good thing considering how dry everything is, and how many fires have been started by lightning in the past.
I think DMVs across the country are now requiring additional documentation due to the Real ID movement, all of it tied into airport security. I went through that a few weeks ago, and had to provide my birth certificate, driver's license (it doesn't expire until next year), Social Security card, and two utility bills to prove my address. The clerk photocopied everything, handed back my paperwork, took a check for $23, and two weeks later my new Real ID driver's license showed up in the mail. The DMV here did a pretty good job of providing instructions on their website, and thankfully they were accurate. The clerk I got acted like he'd never done one before, and had to talk to a couple other people when he got stuck. Kind of hard to believe, since this has been going on out here for a year or so...
It sounds un American that some company can pollute your groundwater unless you can provide proof that doing so is harmful. I'm no lawyer, but it doesn't seem fair that you'd have to pay for expert testimony, too, Don. Have you spoken to an attorney about this?
Nice breakfast at the little cafe in Oroville yesterday, but the ride got cut short when I found a quarter sized puddle of oil under the motorcycle afterwards. Got home, dug out the spare fork slider from the rafters, and had it swapped out by noon. About then I noticed an extra crush washer half trapped under the drain plug on the one I took off. Don't know how it got there, other than that spot is real hard to see... Took another look at the carbs and made an adjustment to needle height that should richen things up just a tad off idle, just where there's been a flat spot. Then found a split boot on one of the coil wires where it's been rubbing on the fuel tank. Shortened up the posts on the coil bracket to fix that, and am hoping that'll fix some electrical noise in the system. Probably safer, too, seeing as how sparks and gasoline don't mix so well outside the combustion chamber. The special plastic glue showed up on time, letting me attach the little brackets to the side covers. I found a small bungee cord that should work just perfect for connecting the two covers. Funny how I can find some things easily, and other stuff seems to disappear into thin air, never to be seen again. I'm still trying to find the instrument cover I made up for the VW, and I've spent hours looking all over for it...
I could only finish half of yesterday's burrito, so I'll have the rest this morning then go for that ride. Hopefully get back before it gets too hot, and then maybe catch up to that missed siesta.
Happy Hump Day, folks!
   / Good morning!!!! #98,347
Loving these cool mornings..
Decided we will likely use 6x6 treated posts for deck support instead of concrete posts. The current deck (many of the deck boards have rot), the supporting posts look good as new.. we don't think concrete will provide any benefit (more cost and work).
   / Good morning!!!! #98,348
RNG, your mechanical ability is really amazing. :thumbsup:
Two hour presentation by NC State professor, very interesting presentation on glyphosate, and no I am not relieved after seeing the presentation.
The science is good, but it's still guesswork. First on mice they figure out what dose would kill half the mice, then they reduced that amount by 90 percent, then they divided by 100. Basically one hundredth of what they think will likely kill you if it were ten times stronger. One one hundredth of one tenth.
They guessed at it...and only time will tell on longer cancer studies.
What I am convinced of is this is the best and least toxic product available for us, if applied properly.
And the latter is a huge issue.
I don't wear gloves while using Roundup. I sure will from now on...dermal contact a prime issue.
Long paints and long shirt. Never do that. Basically don't get it on you and for sure don't breath it.
Here's a fun factoid. Since the beginning, 80 people have tried to commit suicide by drinking Roundup/glyphosate.
Ten percent were successful. The other 90 percent are being actively studied and so far no grand conclusions from that,
but at least they survived.
I asked if I could spray glyphosate in my veggie garden and plant the next Spring and have all chemical residue gone.
A resounding NO.................
It still sticks around, as it binds immediately and strongly to the soil. Yes they say things will live if planted a month or two later in that soil, but
plant uptake would be bad news for edibles. I would imagine it would get into the flowers, and the pollenizers will then track it from plant to plant.
This is why it is likely that every one of us has some ppm of glyphosate in our bloodstream right now.
I have serious neurological issues, constant muscle firing in spots, just have to wonder where this all comes from. And not just weedkillers, all the stuff we eat
and work in.
If there was a more effective safer product, someone would displace Roundup and market their own better product.
But at the moment, that product just doesn't exist. Gyphosate is the best of an inherently worrisome group of chemicals, and since it's introduction into
the markets, use of much nastier chemicals has dropped dramatically. Farmers need a solution. Not sure they have what they need now. Plus resistance builds up to almost all chemicals and they have to make changes ongoing to deal with that. Just like antibiotic resistance.
I suggested that after my reading of all the legal references on Bayer AG's and Monsanto's website, Roundup would not be on the market in five years.
It will be reformulated, I bet to lower concentrations, and renamed.
Guy from NC State agreed with me.
Can you imagine if Ford lost 40 percent of its market value due to one bad car, say the modern Edsel, causing huge losses to the company?
How long would they make that car til they replaced it with something new and improved...
Legal claim reserving is off the charts based on current almost 19,000 plaintiffs on record.
Monsanto is costing Bayer too much money.
Presentation was fair and informative. Two thumbs up.
And on gravel away from all food, I'll be using some this afternoon.
with gloves on for the first time.
   / Good morning!!!! #98,350
72°F and .01 inches rain.
Finished this round of brushhogging.
Kioti part finally came in so back to prepping for sale.
Prayers for all
Be safe
Have a great day
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
IRanch Bi-Parting 20' Iron Gate (A57149)
IRanch Bi-Parting...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
