Good morning!!!!
   / Good morning!!!! #13,201
75 this morning mostly cloudy humid outside with a high of 88 expected with thunder bumpers this afternoon
   / Good morning!!!! #13,202
Thanks David! My pipe search is on. is schedule 40, 2" galvanized water pipe heavy enough?
I am not even going to start on the math, but there will be considerable sway with 2" pipe. Schedule 80 would be better than 40 regardless of diameter.
You will have significant loading on these poles with a giant sail attached at the top of a 15'? pipe.
My gut tells me in a commercial setting this pipe would be spec'd at 6" schedule 80 or even 120 pipe.
   / Good morning!!!! #13,203
70 degrees and sun, sausage is almost done, scrambling eggs next!
   / Good morning!!!! #13,204
Morning all. At work again this morning. 0900, sunny, 80 with 90% humidity. Forecast high of 91 with 30% chance of rain. Had a nice thundershower yesterday, but only a tenth of an inch of rain.
   / Good morning!!!! #13,205
Hazy, hot and humid. Looks like standard Was. DC weather has finally kicked in.
Inside again today, trim work. Almost done with this project. :)
   / Good morning!!!! #13,206
Thanks Dean, I am taking your advice, my pipe will now be larger.
   / Good morning!!!! #13,207
Had an early trip 85 miles up the road to pick up wheels and tires I bought for my Cutlass project, stopped at Cracker Barrel and had a breakfast to make Don cringe! No meat though, just scrambled eggs, biscuits, grits and sawmill gravy and some apple butter.
   / Good morning!!!! #13,208
72F, .58 inches since midnight. Sun shining brightly
Apparently, I slept thru a 4.6 shaker this morning according to wife she and dogs felt it pretty good.
Off to Sunday breakfast
Have a great day
David Sent from my iPad using TractorByNet
   / Good morning!!!! #13,209
Don
Another thought - My 4in pipes were required to be 1/3 buried in 12in of concrete. My 10ft high pipes are 5 ft deep. If that rule applies then a 21 ft would net 14ft. I didn't engineer mine, someone else, the architect, did.
   / Good morning!!!! #13,210
Don, I would think the wind loading the sails would be minimized when set up horizontally, but if you mount them at an angle, you will get proportionately more loading. My J24 sailboat had a large sailplan and had a mast that was an aluminum extrusion oval shape with grooves in the front and back. I'd say the widest part of the oval was 5". But, the boat had cable stays supporting the mast and if you could do something like that, you could get by with smaller pipe. You could also attach the sails to the pipes with a "sacrificial" rope designed to break in a strong storm.
This could be a good thread on its own.
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
2015 Hyundai Veloster (A50324)
2015 Hyundai...
Unused 2025 CFG MX20R Mini Excavator (A50322)
Unused 2025 CFG...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
