Good morning!!!!
/ Good morning!!!! #8,282
Wichita weather - todays high was 46F and sunny with clouds moving in. Stepdaughter had 3 rooms worth of wallpaper removed, found some old termite damage, repaired it. now have all walls back to primer. Some more "mud" touch up, and color coats tomorrow then home :)
/ Good morning!!!! #8,283
32 and clear here. Did not even get much rain yesterday,but everything is waterlogged regardless.
I hope all the NE TBN'rs are not in too bad of shape from the snow storm.
Be well all,
David
/ Good morning!!!! #8,284
Still dark and have not gone out to see just how much snow there is on the ground. Looks to be more than two feet and still snowing.
Wind has been blowing all night and hard at times. Local weather reports indicate it will be snowing until mid afternoon so most of the cleanup around here will start later on this morning.
Good news we still have power here and that is saying something as we normally lose power during big storms like this.
Glad I bought the wife a new shovel and I will be stuck on the tractor and forced to use the cab heater I just installed this year
/ Good morning!!!! #8,285
2013-02-09, 0625
Got about another 4-5 inches of snow since I cleaned off the back porch last night. There might be more, actually...as the wind is brisk and the snow might be drifting.
Snowfall right now is fairly light, but a bit stinging from the wind. Reckon we'll see accumulation through out much of today's daylight hours.
My guess is the totals around here will be about 10", but not much more then that.
/ Good morning!!!! #8,286
Only 2 degrees here right now but no more snow overnight and none is forecast for this weekend. Have to do a long-overdue cleanup job in the basement...will be a good day to stay indoors.
@WayneB...more than two feet oif snow? That is more than mid-Michigan has had combined the past two winters. Glad to learn you still have power for heat and lights.,
/ Good morning!!!! #8,287
Coffee is in the cup. 62 degrees with clouds this morning. Heading to 82 with a couple of breaks in the clouds for sun. Got to cut and trim the lawn today.
Good Morning All.
/ Good morning!!!! #8,288
good morning 23 degrees this morning, it's odd but lastnight and this morning i can here the wind just roaring on top of the mountain in front of the house, it's not bad down here. i don't know might just be me but it sounds like a deep roar weird. ihave listen to it for years and for what ever reason it sound's totally diferent. suppose to be in the 40's today but the ground is so wet can't do much. i hope all you guys and gals in the north east are ok and enjoy your seat time.
/ Good morning!!!! #8,289
Good Morning All.
Ron,
You mow at your SnowBird camp site?
Wow...
David
/ Good morning!!!! #8,290
9F lighty snowing gusty winds dieing down more so each hour goes by :) .....bout 9-10 inches fallen snow.
Stage one clear late morning least temp reaches 15F +,if still to cold windy stage two clean..seat time.. Sunday when temps are in 30's.
Be safe enjoy weekend.
/ Good morning!!!! #8,291
Still snowing down here and expecting to continue until mid day or later. I would think we will end up getting another 6 - 12 inches, but who knows what will happen. Temperature is setting at 17 F and winds are gusting up to 30 MPH. Really a fun day to sit next to the wood stove. I am planning on waiting until noon or so to get out there and blow snow.
/ Good morning!!!! #8,292
Same here Wayne..that wind kinda takes the fun out of snow removeal. :(
/ Good morning!!!! #8,293
Same here...normally I'd go plow when it gets to 8" or so. I think I'll wait until it's pretty much finished. Current temperature is 11 degrees. Wind chill is dropping it to about 6 degrees.
/ Good morning!!!! #8,294
Good morning to all. It is 17 degrees with 5 or 6 inches to clean up. Stay safe out there today and thoughts go out to you where the storms are still active.
/ Good morning!!!! #8,295
how you holding up in the blizzard,hang in there Ron
We just got a ton of rain and wind, the wind is still blowing today. Our creekbed/swamp in the back that's usually damp to dry is flooded into the meadow in back like it did during the hurricane last fall. We have it easy compared to New England. Thanks for asking.
/ Good morning!!!! #8,296
Low thirties now, windy making it miserable to do anything, no snow here. Yesterday was the 3rd anniversary of the first of 2 blizzards in 3 days here, we ended up with 32-36" of snow with several layers of ice at different levels. What a mess that was, I hope you guys stay safe up there!
/ Good morning!!!! #8,297
Sunny here and if I wait long enough the sun will take care of our snow clean up! :thumbsup:
/ Good morning!!!! #8,299
wichita weather: 38F going to 51F Showers later today.
Waiting for the ladies to make color decisions :)
/ Good morning!!!! #8,300
Wow! By noon, you may need a metal detector to find your tractor. You've got some serious work to do just clearing it off before even thinking of snow blowing. Good luck and stay safe.:thumbsup:
Our thoughts are with all you folks in the path of this storm. I don't know how you plan for something like this.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
S/A Utility Trailer (A59231)
S/A Utility...
2020 Kubota RVX900 4x4 Diesel Utility Cart (A59228)
2020 Kubota RVX900...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
