Good morning!!!!
   / Good morning!!!! #192,361
Poured cup of coffee. 64° with clear skies this morning. Heading to 85° with thunderstorms and rain most of the day. Changed out house water filters. Did some repairs on the shut off valve's that allow removal of filters. Replaced rubber valve seats. No more showers while changing filters. Filter are mounted up near ceiling. Spent more relaxing time on back porch. Need to check To-Do list for todays plans.
Have not seen frogs at my pond for awhile. Toad was out in lawn.
Everyone stay well and safe.
Good Morning All.
   / Good morning!!!! #192,363
good morning all
sitting on outside porch of friend's home in Milton DE, lovely 62 out now but going up to 91 today. I'm off at 8am for Washington NC.
Yesterdays drive down went fine but traffic was heaviest I've seen in a long time, must be summer traffic going to DE shore spots.
Today going to NC should be fine, over the big tunnel bridge.
going to be a busy day, since I am picking up a friend at 4pm to take to dinner, and I need a shower and rest before hand.
hope everyone has a good day
   / Good morning!!!! #192,364
Good morning, the low is 57 and going to a high of 73°F. Wind SE 7 mph. 70% chance of showers.
If it rains, then I will be doing, nothing. If it doesn't then I have some stuff to keep the creative juices going for another day or two.
Drew, drive safe going down to NC.
Everybody else, have a safe day
   / Good morning!!!! #192,365
58 outside right now, heading to lower 90's.
I see a low crawling fog coming up from the creeks. Looks like we are finally getting some moisture on the pastures. Rain hopes are up, maybe tomorrow.
Time for the morning chores. Hope all have a great day, be safe.
   / Good morning!!!! #192,366
Safe travels Drew
60 this morning high of 80 pond down almost a foot grass dormant fire danger increasing
High in upper 80s today 97 tomorrow this heat is serious
Prayers for all silent or spoken our Country
   / Good morning!!!! #192,367
Good morning,
59° now highs in the upper 80’s and mostly sunny, NW winds 5-10 mph,
dew points mid/upper 50’s should be a nice day.
Off to pick up some groceries in a bit and then spend the day outside.
Enjoy your day everyone
Stay safe and healthy
   / Good morning!!!! #192,368
Good Morning,
Ct, 60 to start going to upper 80’s ! Sunny now but last night we had another band of light rain come through!
Woman reports Japanese Beetles have arrived (apparently early) and She has been on the warpath, picking them off plants
RS, we have had pretty good luck with the BagA Bug getting most of the beetles ! We have quite a few already and they have only been up for a couple of weeks ! We will see !
Pool filter needs to be cleaned, I guess with all these heavy rains over the last few days it’s getting loaded up with pollen etc. Will do that this morning before it gets hot !
Have to go into work tmrw for a few deliveries! Hopefully I will get done earlier than later, supposed to be a scorcher!
Pleasant out now so will get an early morning walk in !
Hope all have a good Tuesday! 🙏
   / Good morning!!!! #192,369
58 and glorious outside. Jumping up to 92.
LS, glad you got some rain...we are bone dry here and the little pop ups have missed us for the last 3 weeks.
BEF, nice job on that gear box...hope that bridge is steel. We ate lunch overlooking it, I think, from the Rabbit Hole.
Mostly, pretty waterfall.
Been outside cleaning up bear damage...he pulled a long dead limb off the paulownia where we had 4 feeders hanging. 2 are now junk, I fixed the other two. He also bent to the ground two shepherd hooks to get feeders off...totally ignored the hummingbird feeders this time.
Got a nice hike in yesterday after the humidity dropped. Need to do some work on my zero turn today.
Big Boss...
the date on the cam is a day off...time is about right.
   / Good morning!!!! #192,370
Good Morning!!!! 75F @ 4:00AM. A mix of clouds and sun. Hot. High 97F. Winds S at 5 to 10 mph.
The very hot, dry, weather has led to many wildfire starts, the closest being the Apache Fire just south of Oroville, CA. It's at 650 acres with 0% containment and mandatory evacuations. West of there the Sites Fire has covered almost 20,000 acres and containment has reached 80%. So far, northerly winds have kept the air clean, but they have also led to very low humidity.
Stayed inside pretty much all day keeping out of the heat. Replaced some upgraded LED under counter lights with the original florescents, reverting them back to dumb wall switch controlled lights.
I think I'll wait one more day on the trailer, and just do more lighting downgrades instead.
   / Good morning!!!! #192,371
Good Morning.
65° with a high in the middle 80’s under a clear sky.
Yesterday was beautiful, high of 80, but breezy, 15-20mph winds all day.
But it was a productive day on the old folks home.
Best news was that all the plumbing that I put in was in the right place!
Things are already happening out there, the framing crew is hard at work.
It’s interesting that they are from Brazil, and speak Portuguese. Spanish is the most common language of construction workers around here, with most coming from Mexico or Guatemala. It’s also interesting what a small percentage of contractors have English as their first language.
Today will start for me with breakfast with the professor, then we will see what follows.
   / Good morning!!!! #192,372
Mowed a couple little areas yesterday, including the area I worked on mower by the barn. Last night I found a long socket extension laying in the grass. I had used to prop up bolts in the hole while I started a nut on other side. Glad mower didn’t find it.
I’ve always stood exterior walls with sheathing attached, but watch some YouTube videos that don’t.
   / Good morning!!!! #192,373
Morning all, 73 going up to 91 and sunny.
Very windy yesterday, lots of branches down.
Clutch issue on simplicity again, had to haul it back in with the tractor, I think it's fixable.
Today fix clutch and get some work done on table if time allows.
Popgadget -good progress!
Drew safe travels.
Be well,
   / Good morning!!!! #192,375
Don auto blinds what will they make next? Hope biopsy negative, prayers sent
Dr. called yesterday, it was negative, it was an Amalgam tattoo. Wife says cut looks good.
Good morning! 79˚ heading to the mid 90s with partly cloudy skies and south wind.
Opted for a swim yesterday evening instead of cards, very delightful.
   / Good morning!!!! #192,376
good morning, 71 going to 89 another nice day
going to pick up groceries
Worked a little on a stone wall in danger of falling over at the barn. Should be rebuilt but my shoulder is not in any shape to do that so limited it to what I could do with the excavator
Before and after pics
   / Good morning!!!! #192,377
Meeting the construction company soon for a quote on our roof damage where the tree punctured through. Since we are remote, costs are up, and we are in CA I'll bet the repair bill will be a whopper.
Yes, in about a 10 day stretch we went from 90F+ to a frost warning!
Everyone have a great day! Rigby will ... :LOL:
   / Good morning!!!! #192,378
Gear box works as it should. Now have a spare mower for the farm. Really need to straighten the bent hitch frame, get new blades. Not much here at the house to test it on, think my wife wants to keep the garden. 😂. Found some stuff along the field.
   / Good morning!!!! #192,379
79F and partly cloudy @ 11:30, calling for a high of 81F.
Big area of rain northwest of here heading in, probably be here in 30 - 45 minutes or so ... if it doesn't fall apart. Looking forward to a good soaking.
Went out back and collected up some stuff in the garden and brought it inside the garage, refilled right tank on the Cub and then drove it over to the barn.
Put up 2 Japanese Beetle traps first thing yesterday.
Then worked on getting Sunny Boy tomato plants weeded. Watered the area and then used the battery-operated B&D cultivator to loosen the soil. That's largely done except for the southern end of the row. Got it cleaned up enough to pin down the soaker hose and mulch about 2/3rds of the row.
Water Buffalo refilled and ready to go.
Ran down to corner hardware to pick up some more bush bean seeds. Found out the owner dumped Livingston seeds for a smaller selection of Burpee seeds ... and was completely out of all types of beans ... 🤬
Local garden center was already closed so that necessitated a 6 mile trip into Ace Hardware ... who had both Livingston seeds and bush beans ... (y)
Tallest Crimson Cushion tomato plant now about 48" tall, largest Trip-L-Crop plant is 57" tall. Lots of blossoms on all the tomatoes.
Pepper plants all popping and looking good.
Did not get any plant stakes cut yesterday, that's probably the next thing on the agenda for today.
Maybe get that trip to Menards in after I get cleaned up.
Possibly some time up in the shop later.
Hope everyone is having a decent Tuesday ... (y)
   / Good morning!!!! #192,380
67°F and .01 inches rain
Should be a good day for mowing
Happy Hour at the county park was a success. Very good job on the renovations.
ODB II gave me a ERG fail yesterday on my tractor yesterday
Prayers for all
Be safe
Have a great day
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
2014 MERCEDES 2500 CARGO VAN (A59904)
2014 MERCEDES 2500...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
TANK MANIFOLD (A55745)
