Good morning!!!!
   / Good morning!!!! #159,241
and here's another electronics question. The electronic chimes in my new clock sound pretty good.
A fairly impressive looking magnet on that tiny speaker.
I wonder what hz range is most important for bells
wonder if I could tap into that clock output, wifi it to my pc sound system, and feel like I'm in the Tower of London
I'm going to wait for Ken to build one of those for me.
   / Good morning!!!! #159,242
Good morning,
34° now, Sunny today, High near 43, SW wind around 5 mph.
Did a dump run this morning seeing I was going by there anyway.
Stopped and filled the truck with gas, saw a friend and pulled over to chat then completely forgot to fill the diesel can which was why I went out in the first place lol.
Happy anniversary Mr. & Mrs. Fuddy
BEF take care of yourself
Not sure what the rest of the day will bring
Enjoy your day everyone
   / Good morning!!!! #159,244
67°F and 2.45 inches rain.
Kubota retrieval this morning provided it dries a bit. Tentatively scheduled 10ish so a few hours. Should get more info as to why he thinks it’s toast.
Otherwise will be a let’s see what comes day. Didn’t sleep all that well given the thunder and lightning most of the night.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #159,245
"Should get more info as to why he thinks it’s toast"
I guess he is your friend so you can't offer to buy it for a thousand bucks. 😱
Chris
   / Good morning!!!! #159,246
If clock to stereo is less than 30-40 feet I'd try bluetooth. Our neighbor has a 1946 Olympic console radio I repaired and wanted to play records. It had an audio input jack (1/4" female). Using a Y adapter I plugged that in, other end to L&R bluetooth jacks.
Walmart had a bluetooth phono $59.
It works fine.
This adapter comes with dual 1/4" to 1/8" male stereo cable. Cut 1/8" plug off. Solder red & white wires together, twist stranded wires together & solder end. These two carefully solder across clock speaker. This is tedious, an alternative is simply remove a little insulation from two leads going to speaker, solder to them. Plug that into bluetooth transmitter.
Stereo needs a bluetooth receiver plugged into auxiliary port.
Voila
   / Good morning!!!! #159,248
Good morning to all! Low of 14° (brrrr), only going up to 40°. That's better than yesterday's high of 30°. Yesterday and this morning, a beautiful coating of freezing fog. The sun just made an appearance this morning after taking a vacation day yesterday.
The heavy frost definitely took out the rest of the flowers that were hanging on. Sometime this coming week, need to cut the stems. One giant mum plant needs to get separated and replanted. It got so big the weight of the flowers made it sag over.
Been dealing with some personal demons this week.... seems I've been able to move past.... I hope.....😔
The knee has been really acting up... the pain is almost the same intensity as when it was bone on bone. Swelling bad too.... I don't know what is causing it, but has dramatically decreased my activity. Dr's appointment on Monday, so hopefully get more info then....
Dennis, stay on top and get plenty of rest. Hope you get better soon!
Fuddy, HAPPY ANNIVERSARY! You have us beat by 10 years.... Neat story.
Drew (Johnny), have a safe trip! Hope the weather cooperates for the trip.
Ron, that squirrel must be a teenager.... you know, with the bleached / dyed tail as a mohawk..... great pic!
Today is dog food day.... got started early, mid point in the process now. Doing it a little early to avoid having to make it right after thanksgiving. Using ground turkey instead of chicken this round. Picked up 6 lbs for less than the cost of chicken. I should have gotten another batches worth at the cheap price.
Max had fun the other morning when we had a dusting of snow.... he was doing ZOOMIES all around the yard. Like little kids... he loves playing in the snow.
Hope everyone has a great weekend!
   / Good morning!!!! #159,249
Chris
I’d go $1500 if he included Backhoe and Rotary mower. If he was a good friend he’d just offer for $1000.
   / Good morning!!!! #159,250
I’ve been in bed since going out this morning. Had to put on flannel shirt and sweats even under cover.
   / Good morning!!!! #159,251
Have you started Paxlovid? It really helped wife & I get over Covid quickly.
   / Good morning!!!! #159,252
Covid test is negative. But don’t know what it is. Got a telemedicine appointment later.
3 yrs ago pneumonia led to my GBS, don’t want that again.
   / Good morning!!!! #159,253
Signs and symptoms of respiratory syncytial virus infection most commonly appear about four to six days after exposure to the virus. In adults and older children, RSV usually causes mild cold-like signs and symptoms. These may include:
  • Congested or runny nose
  • Dry cough
  • Low-grade fever
  • Sore throat
  • Sneezing
  • Headache
   / Good morning!!!! #159,254
Garage cleanout progressing, think I have enough room for the foam boards to be inside now.
It's an oversized 2 car, but pretty full of "stuff"
Think I will leave the outlet boxes on the wall as they are Nailed to the cement block and can't see how to remove them unless I drill them out.
Anyone think think this is a bad idea??
I should be able to get the foam board under the conduit most likely
Drew - sounds like an Arduino with Wifi for your clock to talk to the computer. The arduino code would be easy, the PC side would be more work. As Fuddy mentioned BT transmitter and receiver. Might have to put a resistor in to attenuate the speaker output to BT though. Pretty easy.
Sodamo - Kubota is toast ?? Water damage that bad? mud? vapor locked engine?
LS - hope the knee gets sorted out. Seems this has been going on a while.
We think wife had RSV, it's been quite common around here. Symptoms sound just like M7040 listed.
   / Good morning!!!! #159,255
Fudged around a little on this cold day. The house is better sealed with 3 windows sealed for air infiltration and finished setting up the basement furnace and running it on oil currently to test it out. Might load it with wood during severe cold spells to run it full time. The oil firing is handy to start a wood fire and then cut it off when going good. In the meantime will use it on oil on a spot basis as needed to supplement the upstairs wood stove. It can run on coal too but it is too messy to deal with.
Found the Fluid Film gallon can and air sprayer that was used to undercoat the truck. The air coupler was broken so used a tap out to remove the stub and replaced with a high flow Milton air coupler. This will be used to spray the Boss V Plow for the Kubota RTV to hopefully avoid sticking of snow and ice. Also will spray the bigger plow for the tractor. Last few years were low snowfalls but we are due for a big one I think.
Also set up an air chuck that locks on to fill the portable air storage tanks without having to hold it during filling. The electric heat in the side room in the barn makes all the difference in comfort up there.
   / Good morning!!!! #159,256
Good (Sunday) morning. Overnight Low of 14C and it's presently 18.7C, mostly cloudy and calm. There was 11.5mm in the gauge at 0715... the rain occurred in the early hours of this morning.
I did get the house/driveway mowed yesterday and the piles of clippings raked/dumped, then used my blower to clean off the 'entertainment area' of the house. Penelope the pussybeast was none too pleased with the outdoor activity. Relaxed for the rest of the day.
Church this morning.
   / Good morning!!!! #159,257
Afternoon all!
Currently 35 dropping to 24 tonight with a high of 33 for tomorrow.
Spent the day today finishing up Christmas gifts to hand out to friends and neighbors.
Hands are sore now so will be taking the rest of the weekend off except for keeping the stove running. Sister sent me a pic of getting the grout work done. Came out nice! Needs some paint and we can start something else. Think I will be taking the winter off though. To darn cold. Lol.
Hope everyone stays safe and healthy.
   / Good morning!!!! #159,260
My funny Ivermectin story. First, everyone should read about it, it's interesting from trusted sites. Of course the FDA says don't take it .
My wife & I have had same doctor 35 years. I called him a couple years ago about us getting a prescription. Doctor had never heard of it! I said no problem, we have it for horses & we can measure it by weight and take it...he said don't do that!
He said he'd research it, let us know the next day. Next day call all excited saying wow! That's amazing stuff and I called in prescriptions. One little pill, $3.
I told him our pets had parasites we handled, so good we took it.
Ivermectin is amazing if you research it.
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
MULCHER (A58214)
MULCHER (A58214)
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
