Good morning!!!!
/ Good morning!!!! #155,101
Good Morning
I'm off to town
/ Good morning!!!! #155,103
fun morning at Popgadgets. Heated the hitch and with a giant adjustable wrench bent it back into alignment.
Then some wiring work, and adjusting the brakes which was made easier by taking off rear wheel.
My friend's Dad was an aircraft mechanic and he had some shared experiences with Paul.
They are both good mechanics. Popgadget is exceptional.
unloaded Gravely and put it in garage, need to sit and stop sweating, pretty hot out there.
I'll go back out and do paint prep and put on primer on the hitch.
Will paint it red tomorrow. Finally the beat up old ball goes back on. Might try to buff that up a bit.
It's seen a lot of miles. Like me. I could use a little buffing right now... :sneaky:
/ Good morning!!!! #155,104
was working on north sidewalk when moving extra trash can got stung by wasp that had made nest on can's handle. Hit the nest with wasp spray, then let them settle down, knocked nest down when I found wasps back on nest,. While waiting for wasps to settle down,
OUCH... something that small.
/ Good morning!!!! #155,105
90F clear sky humid. ;(
Not much happening today just out the front door early AM,long day on the job got home kitten and I took nap,going to be feet up kinda even.
Enjoy your evening all.
/ Good morning!!!! #155,106
My wife said no new projects until I finish the current ones. like that will happen.
My projects are self starting - Was a day off from leaving Ms for Va. Valve for laundry washer in bsmt sprung a leak. While fixing that the a/c drain (installed BEFORE we bought in 2010) backed up and required replacing, had to replumb that on a weekend. Simple projects but not planned for and it's a 2 hour drive for parts.
/ Good morning!!!! #155,107
View attachment 760204Busy day yesterday replacing fuel pump in youngest sons pickup. Always seems to be a hot day when repairs are needed.View attachment 760205
Recently I was changing the gasket under the fuel pump in our Sprinter Van but I was not able to screw the fuel pump in again because leaking brake fluid had caused the tank nozzle to deform. So a small repair turned into a new tank and new brake lines. Tank dropped down being suspended with two straps and that gave access to the brake lines.
/ Good morning!!!! #155,109
I'm only at 86F and the heat and humidity drove me in this afternoon.
/ Good morning!!!! #155,110
RNG, I used this plastic bonding cement. I'll post a pic of the pressure relief valve connection that was leaking. Found that most glues were not reco for polystyrene, and this one works. It was not the one I was looking for, but did a fine job.
/ Good morning!!!! #155,113
Good late (Tuesday) morning. A very mild overnight Low of 11C! Some brief, heavy, rain squalls that left 5.4mm in the gauge by 0900. It has rained again since then and, although sunny and 16.6C now, more rain is predicted for the arvo.
I plan to do a tip-run and then swing by the PO as I've been alerted that I've got mail in my PO Box.
Spring is beginning to 'occur' but I know that it's only a tease... there'll be more Winter weather on the way. :cautious:
Take care all.
/ Good morning!!!! #155,114
Good evening all. 76ºF for the start, partly cloudy, breezy. Moderate wind with brisk gusts early, eased off later, bit of a gust front with t-storms. Variable cloudiness til T-storms got here a 9PM, high temp was 92ºF, HI 100ºF, low during t-storm 69ºF, also about .2 inch rain. High 80's to low 90's in 10 day with possible rain on 5. Bike ride to start morning, the cool off and lunch then mowed front yard this afternoon, then nap. Got fish fry tickets for neighbor this evening.
I have replaced two in tank fuel pumps, and had a wire issue between tank and SUV.
Randy please check in, we miss you.
RS Got a lot of mowing, hope no problem with no gutters.
Roy hope audit goes well.
Dennis wonder how UPS got turned off. Glad Sunday went well. Hope you got back to sleep.
Drew hope you can get the bent hitch fixed, bet Paul up to task.
Drew neat pic and good way to find headphones :)
Buppies sorry heat not gone, hope storms not too bad.
RS you are up early, hope you got a nap. Sorry rocks not picked up.
Drew wonder if manatee got dirty so to get brushing :)
Billy glad sprayer fixed, sorry spraying had to be done in heat of the day.
RNG sorry it is going to get so warm. Glad oil pump ok. Hope you get new bolts soon, good luck tracking fuel issue on touring bike.
Ken sorry no rain. Wasp nest might get wet, left trash can out from house, and it rained tonight.
Paul glad you are getting help while your wife is on the DL. Have fun with Drew's Gravely.
Tom that is cheating have fuel pump go out in PU truck :)
Drew sorry about the humidity.
Fits are getting the impression that the tophat does not want to be welded?
Frits glad all is right in the welding world.
PJ glad you got some rain last night.
David hope you get another good day to finish with flail. Hope you do get to roof over more tractor shed area.
Drew glad Paul got you fixed up. Good luck getting "that" buffed out ;)
Thomas hope day not too long.
Newbury I get projects like and then there is mowing/lawn-care.
Frits sorry you had to totally remove tank.
Drew only 96ºF, glad you got hitch painted.
Billy thanks for glue info
Frits and painted too.
Randy(wag) hope town run went well.
prayer for all, especially Jay/Peg, Kyle's daughter, /mom's breathing, /learning new job, Bird/aging issues/, Don /mom's pipeline process, Randy/FIL living alone adjustments /MIL Covid /son's heart issues, /pneumonia and not posting, Roy /palpitations, /fall injuries, /angina /wife ankle, Billy /wife back & hip, David(moss) /remodel, /divorce, Buppies /3 new skin cancer spots and treatment, /wife knee healing, /getting dehydrated and cramping, Thomas /gout, Phil /reflux, /wife's eyes, Steppenwolfe/son-auto immune disorder, Grev/wife's eye, Ted /knee recovery, /retirement, /family issues, /wife feeling bad, Doug and wife/health issues, /nerve and pain, / wife headaches, David(sadamo)/Sophie's new eye surgery recovery, /Sophie's hand infection, Chris/neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, /wife not feeling well, /marriage, / friend stop drinking, Paul/ wife's healing from back surgury, Gale and KY/ tornado victims, Mike /5 year plan, Dennis /retirement plans / brother "alligallyitus" and improving, Drew /foot heel issues, /friend cancer diagnosis and recovery, Helogabals /second opinion, /wife's friend situation, Ukraine war, and Country.
/ Good morning!!!! #155,116
i believe that all wives say that ... so i bought HER a project car :)
daugen and popgadget ... sounds like a good day. i haven't met anybody from TBN yet, other than 1-2 friends that i invited to TBN forum
wngsprd - that is a lot of stuff planted
i'm basically ready for tomorrow's dump run, will need truck emptied prior to the afternoon pickup load
fuel pumps are no fun ... i have a couple of projects requiring that, and have done that a few times in the past
tomorrow will be a busy day, mostly at home, probably need to wash more eggs also
some car guys are stopping by to give me a hand later in the week, i need to restock beverages before that happens. mostly i think they just want to see what i have on the property
my fingertip is burning sore tonight, still the nerve damage from my dislocated shoulder... it feels like a needle or splinter is wedged into the finger. that and my legs are in spasms again. if i was a smart man, i should probably make some coffee.
have a good night everyone
/ Good morning!!!! #155,117
2022-08-30, 0339
66° right now, high in the upper 80's
Had a customer audit last week...have a Quality Management System audit starting today and will continue until Thursday. Going to be a couple long days...
/ Good morning!!!! #155,118
good morning all
up early, slept well.
laying in bed thinking about how I'm going to back my car and trailer out my driveway onto main road with totally blocked sight lines.
The trailer can see, but I can't....hmmmm. Was thinking about possibly driving around in front yard so I could go out forward.
I hate backing up onto busy roads. Not so hot on my neck either. Next time I'll dismount the trailer and turn it around. Since I was going out the next day
left it the way I came in. Probably should have backed in to begin with. Sigh. No turnaround in driveway is a real nuisance. This should be interesting.
As long as I don't hit the power pole on the other side of the road, should be good.
Yup, you are correct. Wife used to scold him/her that they were intentionally mucking around the night before so they could get a longer scrub.
She loved it. The manatee seemed to love it. And when the manatee brought its baby to show her, well she was really excited.
we were in a very protected marina inland, more like parking in an aquatic parking lot than a river or bay marina. Intracoastal Waterway about 200 feet away, critters would
be out there and come in to marinas likely trying to get away from boats. These are very cool, very peaceful animals, vegetarians, browsing sea cows.
With whiskers like a seal and really bad breath. Animal got a lecture on its bad breath every time.
Swim platform not all that wide, but she was determined,hauling that romaine lettuce down that rear ladder and either sitting on swim platform with her feet in the water so she could feel the animal and vice versa, or sometimes lying down on platform having a discussion. Always wondered if manatee liked the sound of her voice.
Certainly liked her lettuce. Funny, didn't like cheaper iceberg, but the romaine was closer to something they ate in the wild because it got gummed happily.
After three years living on the boat, it was time to go back to Pennsylvania.
miss the boat, miss her the most, time for new chapter in book of life, which was my farm in NC.
off to mow at church early then possibly some rain this afternoon or tonight.
I'm picking up my new inflatable Coleman hot tub at Lowes on way home, will call brother to come help me get big box down to basement, then I
have to build it. Have to figure out water and electrical connections first. Simple plug in, but not much is ever simple
/ Good morning!!!! #155,119
Thanks for sharing those memories, Drew 🤙
/ Good morning!!!! #155,120
Great memories Drew
70 high of 88 storms possible later fell yesterday very sore this morning
{rayers for all our Country
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
John Deere 5055E (A53317)
John Deere 5055E...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2019 Kenworth T880 Tri-Axle Dump Truck (A59230)
2019 Kenworth T880...
