Good Morning!!!! 53F @ 4:30AM. Rain early...then remaining cloudy with showers in the afternoon. High near 60F. Winds SE at 10 to 15 mph. Chance of rain 100%. Rainfall near a quarter of an inch.
It was supposed to rain yesterday afternoon, so I got my outside work done before lunch. The new u-joint took some of the play out of the drive line on the side-by-side, but it's far from what it was the day it left the factory. It'll have to do for now, though. Changed the position of the shift lever on the van and now it's not such a reach to 3rd. I'll take it.
View attachment 598930 View attachment 598931
By 2PM there was still no sign of rain, not even on the radar map, and the weatherman had changed his mind. So I picked up where I left off on the poptop tent, a job I'd read was somewhat arduous. A Youtube video wasn't quite so negative, and once I'd located the correct screwdriver, it wasn't really that bad. The real challenge was the confined space at the back, made even worse by
the need to only raise the roof a foot or two to make enough slack in the cloth to get it around the strip of aluminum molding that held it to the metal van roof. Things were going fine until the screwdriver tip dropped out of the driver and I had to spend almost an hour looking for it. It was in plain sight, but the color was close enough on the floor where it landed I couldn't see it until I crawled around on my hands and knees with a headlamp on. I also made the mistake of using stainless steel screws, and their soft heads meant some stripped out the Phillips slot before they made it all the way to tight. Sixty some screws later the task was done; I if I never have to do that again I won't be disappointed.
How many of you have a
Chapman screwdriver set? This job, and many others over the years, would have been impossible without one. It not only fit into the low overhead space at the back of the van, it provided the leverage needed to turn the screws as they cut new threads in the metal. Only problem was I didn't have a gen-u-wine Chapman bit, which uses a pair of burrs to keep it in place, which is why I kept dropping the only bit I did have. I think I'll be doing some shopping today to correct that...:laughing:
Supposed to be more rain on the way for this morning, so I'll try to get the carb rebuild done. If it clears up enough by this afternoon I'll get the saws back out and torture my back some more.
TGIF folks!:drink:
