Good morning!!!!
   / Good morning!!!! #81,201
I read where Shingrix (sp?) is 97% effective among those 70 and younger, as compared to the Zostavax.
Happy anniversary Mr and Mrs Mostly. Hope you have a good one.
If only it would be more available. You might be lucky enough to get your first shot then there’s no guarantee when vaccine will be available for second one.
   / Good morning!!!! #81,202
To to show we believe in equal opportunity this is Kalani same time as pic #2
And just to be honest, both did Alert when the mower shut off.
   / Good morning!!!! #81,203
Ok, let’s try
iCloud Photo Sharing
Hmm, maybe worked. Not so convenient but I think I understand why, save space.
   / Good morning!!!! #81,204
We ran into that. 1st shots at Walmart. Went back for 2nd and put on a waiting list. Luckily we found them at Safeway the following week. Walmart did call within the window.
Strange, but true our Primary Care clinic didn’t have either.
   / Good morning!!!! #81,205
Final prep done for the cookout tonight. Tables set up in garage for food. AC on in garage, volleyball net up, Sun shade up over grill on back deck. Got mower out to trim a little, ended up mowing the whole yard again, except along creek, it had grown enough since friday. Never did trim around trees, never got field mowed.
Happy Anniv Mostly..
   / Good morning!!!! #81,206
Happy times ahead
How you like your Weber. We have the 4 burner and it has been great.
   / Good morning!!!! #81,208
Best grill i ever had.
Best gas grill I’ve had. Has stood up quite well. I think the burners maybe need some attention soon, maybe just a good cleaning.
   / Good morning!!!! #81,209
Well, it’s raining. Pretty much dashes any hope of mowing / bushhogging today
Guess I’ll just have to take a holiday.
Happy Hour up to neighbors later this afternoon.
   / Good morning!!!! #81,210
Grilled 24 burgers and 7 brats, now another 14 brats, and 24 more burgers, then some dogs and chicken.0903181542.jpeg
   / Good morning!!!! #81,213
Just finished playing out in the garage with the lathe and mill. IMG_0405.JPG Already have a powder trickler but it was fun to make. Ed
   / Good morning!!!! #81,214
Well, it痴 raining. Pretty much dashes any hope of mowing / bushhogging today
I got up this morning, before daylight, to find it was only 74 degrees with a 60% chance of rain forecast, and the yard needed mowing, but not really bad, so I walked outside and back in 3 times trying to decide whether to mow or wait for another day. It didn't look much like rain to me on either the sky or the NWS radar. But I finally decided to go ahead and start mowing to see if I could encourage it to rain. Twice while I was mowing, I felt a little mist in the air. But I got the mowing done, got a shower, and my wife and I went to the grocery store. It was raining when I came out of the store, very light, but raining. And we're still getting a very light rain, but I can see that my rain gauge has reached the half inch mark at least. I'd say I got lucky, and made the right decision to mow this morning.:)
   / Good morning!!!! #81,215
Ed how does the rod pick up the grains? The rod is hollow right? Did it have to go on the lath 5 times for the cuts/mills/shaping or what do you call each stage of the milling?
1. outside 2. inside 3. funnel. 4.rod inside 5.rod outside.
Can you tell I haven't a clue about a lathe.
   / Good morning!!!! #81,216
five hours of mowing, two doing the fields, started off doing the easy part, then got into
the overgrown collard field of the now abandoned farm next to me.
What a mess that was, Massey worked hard with a BH15 bush hog behind me, but got it done.
8 trillion bugs jumped on my bare legs. Eeesh. Lot of flailing around, not so good for straight rows...:rolleyes: but no one was keeping
score here.
   / Good morning!!!! #81,218
score here.
Well Drew that 2nd pic looks a lot like my overgrown area just much more even. I know where some of my slopes used to be until the farmer reconfigured. Of course he didn’t level out well after last harvest so a rough ride in places.
   / Good morning!!!! #81,219
David, it is used to trickle the last few grains of gun powder into the scale when reloading spent brass cases.
Don Chucked the main body in the lathe and turned the base down to size and then used the compound to turn the outside of the funnel. Cut it off at the top of the funnel with the band saw. Made some soft pads for the chuck jaws out of come copper pipe and turned it around and put the base in the chuck and squared the top of the funnel. Drilled a small hole in the funnel and stepped it up until I had a 3/4" hole in the funnel. Turned the remainder of the inside of the funnel and sanded it while turning it on the lathe. Chucked an aluminum arrow in the lathe and sanded the camo off and down to size to fit the hole I drilled across the body of the trickler. Then took the 3 jaw chuck off and put on the 4 jaw so I could center a square piece of alu i had and turned it down for the stops on each side of the body and the knob. Put it all together and drilled a 1/4 in hole in the tube with a end mill. Glued it together. Little more than that but that is most of it. Ed
   / Good morning!!!! #81,220
91F now :( few clouds here and there calling quick nasty t-storm soon.
Started Kubota letting it to warm up do some fel work all of sudden to 2 mice ran across the hood...not a good sign,shut the tractor off open the hood right in front grill where the battery sets mouse nest almost size of shoe box :eek: good cleaning spray the area well w/WD40,hadn't use the tractor about week and it didn't take long for those buggers to build...better check before use might cost $$$'s.
Well time to fire up the grill make some hamburger mix w/sausage onions peppers sweet corn on the cob.:licking:
Enjoy the evening all.
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
