Good morning!!!!
   / Good morning!!!! #34,981
72 high of 95 later today the heat is on and will be here for a while too. This kinda of heat is rough to work in must remember to hydrate must remember to hydrate
   / Good morning!!!! #34,982
54F & cloudy. 64F today with a slight chance of rain. Roy's rain is moving SSE and will probably miss us. There are no 80'sF highs in the ten day forecast.
Ron What brand of mowers do you have that you never clean the decks?
Kev and Buppies be careful with that heat.
   / Good morning!!!! #34,983
70 out this AM. Very humid. Recovering from yesterday. Put up 300 bales in the top of the barn, by hand. Ended the day getting rained on. That qualified for 100 percent humidity. I was soaked to the bones before the rain. How I love the Northern VA summers.
Hazy, hot and humid this week. Everyone be safe and have a great day!
   / Good morning!!!! #34,984
54F & cloudy. 64F today with a slight chance of rain. Roy's rain is moving SSE and will probably miss us. There are no 80'sF highs in the ten day forecast. Ron What brand of mowers do you have that you never clean the decks? Kev and Buppies be careful with that heat.
JD, Kubota, and Snapper. With 10 gauge deck on the 2 commercial decks. I do not think they will ever rust out. They are stored inside.
   / Good morning!!!! #34,985
Good morning all, a himid 70F here this morning, haeding to 81F this afternoon. Almost an 1" of rain fell in less than an hr. yesterday afternoons.
   / Good morning!!!! #34,986
I bet commercial grade mower decks are made for better air flow. My box store Cub Cadet deck is stamped and has a lot of things and shapes that the grass catches on, which is how I expect the build-up gets started. The stamping is probably a compromise between air flow and strength. I'm not worried about it rusting out, something else will die before that happens. :D Not sure what the gauge is, probably something like 12 or higher.
I don't recall doing much deck cleaning in NW Ohio though years ago with Dad's 22" Craftsman or the Toro rider a neighbor hired me to cut his grass with.
   / Good morning!!!! #34,987
58F now maybe reaching 60 F,rain during night and on/off rain now looks like most of the day...I might add much needed rain.
Putter day mostly...trim some limbs,put cables on well tile cover,maybe walk thru Tractor Supply.
Enjoy the day all.
   / Good morning!!!! #34,988
75 this morning and headed to 93 today. Heat index keeps getting over 100 for last few days but have been on tractor for most of the week. So hasn't been too hard to stay hydrated.
Hay is hauled in our original count was right 133 bales. We move 13 at a time. With last years left overs that will put me up to 196. Should be enough to make it through the winter.
Now to finish yard today. Chicken coops need mowing and house needs weedeating. Then garden needs tilling and last planting planted.
Dave have a Dixie Chopper. Haven't washed deck in 5 years. Now I do take a leaf blower and clean the top off every use. If not it likes to eat belts. A couple times a year I will get on the blacktop and do some wheelies with the blades running and it usually spits out some chunks of Adobe. Mows like a champ for about 20 feet then goes back to normal. Grass around my chicken coops can be dry and when it's mowed then you wouldn't believe how wet it is so mowing when wet makes no difference.
   / Good morning!!!! #34,989
Good Morning. 0810, sunny, 80F with 81% humidity. Forecast high of 92F with 20% chance of rain today, and a low of 73F tonight. I'm running slow this morning. I haven't even fed the dog yet, much less been to the garden. Need to decide between mowing front yard and discing the garden again. I'm putting my money on the disc. 16-18th are good planting days, and I want to get more squash, sweet corn and peas planted. Also Mamma thinks her battery charge isn't working. She wants me to come over and put mine on her Husqvarna rider. She doesn't use it enough to keep the battery charged.
   / Good morning!!!! #34,990
61F now, more abundant sunshine on tap for today. High 93F. Winds S at 5 to 10 mph. Cooler today, but for the next ten days the highs will be near 100F with lows in the mid to high 60s. That's 5F - 15F above normal, but that's what we've been seeing for most of the year so far.
That old Craftsman mower has been with me since the early '90s, and if I took the time to hose it off, still looks brand new. On the outside at least. It cut grass once a week at the last house during the summer growing season (grass stops growing during the short winter days here in California, just like the rest of the country). But back then the sprinkler system kept it nice and green, and I even got into the habit of fertilizing it a few times a year. I think I may have cleaned under the deck once or twice when I first started using it, but not much came out and I stopped. Haven't even looked under there since moving to the sticks five years ago, but then it only gets used a few times during the spring each year. During the drought I've stopped watering the grass all together, and now it's as brown, sorry gold, as the surrounding hillsides. And I've just about made up my mind to replace the small lawn with drought tolerant shrubs and ground cover, dotted with boulders and finished off with decomposed granite, a gold colored sand. At that point I'll probably give the mower deck one last cleaning before putting it on Craig's List, formally ending my grass cutting career. I'll still mow the meadows away from the house, but that's a sit down job on the tractor, and if I time it right it's a once a year thing. Does that still count as mowing? And no, I don't clean the deck on the bush hog, either.
Larro, I've had mixed results leaving so called maintenance chargers hooked up to batteries all the time. They're supposed to be smart enough to not hurt the battery, but some batteries still don't like it. Last week a buddy told me he keeps his chargers on a 7 day timer, and only turns them on once a week. That's been working pretty well for him, so I'm going to try it, too. Another of my friends takes a bulb out of the garage door opener, replacing it with a screw in socket. He connects his charger to that so it only comes on for ten minutes or so each time the garage door opens. That also seems to work, though I'm not sure how well I like the idea of stringing extension cords across the ceiling. Either way, think your mom could get into the habit of leaving her rider plugged in all the time?:confused3:
What counts as light use, Eric? The sprayer here sits idle for eleven months of the year, then gets a workout for about five or six hours a day for a week. I drain the tank and get as much water out of the pump as I can (that's almost all of it) before I put it away for the last time, and it sits in an equipment trailer out of the weather, but in which day time temperatures probably reach 140F. I should probably put a remote temperature probe in there and see. The motor in the old sprayer is still bright and shiny, with no signs of corrosion or undue heat, and it doesn't make any tell tale rattling sounds when I shake it. The armature still spins freely. If I had to guess, I'd say the brushes might be worn out, but there doesn't appear to be any way to replace them. The motor housing is a one piece stamped can, closed on one end and covered by a cap on the other. The cap engages tabs around the edges which are peened over to make a permanent connection. "No user serviceable parts inside" as they say. I couldn't even purchase brushes if I did manage to get the thing apart, though I could probably carve some from another device to fit. That's even if it has brushes, it could just as easily be a brushless DC motor. A new motor/pump assembly is $69 plus shipping from Amazon; I can purchase a sprayer complete with tank, pump/motor, and spot spray wand for $89 plus tax at the local Tractor Supply store. That would be the easiest option, but then what am I supposed to do with the extra tank, wand, and plumbing bits? More land fill material. The local sprayer company doesn't publish prices on their web site. I guess if you have to ask, you can't afford it. But I'll find out when I stop by there today.
There's a hummingbird feeder hanging outside the sliding glass door to the patio from the bedroom. Besides the obvious buzz from the birds' wings, I can hear them drinking. It's kind of a soft rattle, lasting maybe a second each time they dip their beak. I suppose that's their tongue hitting the bottom of the tank. Just goes to show how quiet it usually is around here. Most of their noise comes from their squawking when they argue over who gets a drink first. They all get fed eventually, and I've seen as many as five birds drinking at the same time. But there always seems to be one that figures it's easier to dive bomb the others instead of waiting for an opening, then they all go whizzing around until the bomber finishes. Even then it may just hover over the feeder and continue to drive the others off, especially if the other feeders are low or out of nectar. Not that anybody's going hungry with all the sage and lavender blooms around.:laughing:
Managed to get new mounting tabs welded to the crash bars for the HID lights on the motorcycle yesterday. Cut the old ones off using a 4 1/2" angle grinder purchased just last year for some tile work. It's light and cuts very quickly and neatly. I don't know why I waited forty years to buy one. This morning, assuming the paint's dry, I'll mount the lights and run wires, and also find some place to hide the igniters for the HID bulbs. Then it's back to the bike I'll be selling, mounting the lights on it that just came off the one I'm keeping. The lamps I just mounted can turn night into day, the ones going on the sale bike are better than nothing, but not a lot. Very surprising as they both use the same HID "bulb", but the housing and lenses are very different. I suppose that's why one cost 3x more than the other. :laughing:
Happy Monday everybody. Just try to save some for the rest of the week. :thumbsup:
LOT: (1) Pallet of Chains (A59076)
LOT: (1) Pallet of...
John Deere 950 Tractor (A57453)
John Deere 950...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
IRGC40 High-End Mini Golf Cart (A57149)
IRGC40 High-End...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58216)
GRID SHAPED BUCKET...
