Good morning!!!!
/ Good morning!!!! #55,961
Well, I missed my goal of avoiding a generator run. Not that it has run yet, but I suspect within the next hour or so. My 3 hour shopping trip to Hilo might have been a factor, but even if I could have avoided it, I doubt if I would have gotten enough panels turned on early enough to be a factor. Still a good day in that my combiner boxes are cleaned up, rebuilt, and ready to be mounted in the morning. Rerouting the wires from on the roof to thru the roof will be interesting.
On a different level, I learned today that my new battery manufacturer, Aquion, filed for bankruptcy today. As much as I researched, the one tidbit I never read was this company was another of the chosen Obama energy stars (solyndra etc). I believe they have mostly all gone under. Technology wasn't the issue here, likely poor management. The fact the lead guy, Whitacre sought refuge back at Carnegie Mellon a week before the announcement just reinforces my suspicion. Oh well, I'm still expecting they will perform well.
/ Good morning!!!! #55,962
Seems maintenance items are all coming along..
Toilets either won't fill or won't shutoff, cleaned the main bath valve internals, works like a champ now. Cleaned master bath valve internals, worked great for a hour or two, then would run very slow (not shutting off). Cleaned again, seemed to fix it again, few hours later, running again. Replaced valve internals, worked fine and now running again. There must be an obstruction at the inlet to the toilet that is restricting flow. I don't like taking the whole thing out, makes a mess and is a pain getting in there..
Propane stove gave a few issues with thermostat a month ago, spent time cleaning connections, etc on stove and all worked great until this morning. It is not coming on, have not looked at it to see what is going on..
Hot water heater is making hotter water, usually points to element going out or thermostat issue...
Metal roof on shop has a leak, will need some help getting up there and checking screws and trying to find leak..
Tractor front tire went flat parked in shop. First tractor tire to loose air..
Zero turn mower has a tire losing air (slow leak)
Snow is mostly gone, temps are warming up.
Sounds like life (mine) :)
/ Good morning!!!! #55,963
I think the moon may be even more awesome tonight
/ Good morning!!!! #55,964
Around 4" of snow so far, with a lot of moisture still to come.
/ Good morning!!!! #55,965
Working on the toilet tonight, seems to be a bunch of sediment. Hopefully caused by main toilet running extra for a few weeks causing pump to cycle. Main toilet is fine, master is getting better after pulling off pipe to bottom of toilet and flushing out. I cleaned the internals again and its working for now.
Hot water issue is likely sediment in the faucets causing the balance to stay on hot when the lever was turned. I worked it some tonight and it is working better..
Didn't make it out to the shop tonight, had to work late. I was not able to login this morning, had to have IT reset my account. I had limited access all day until near end of day when my account was locked again. This time L1 can't fix it and have escalated it to next level as my computer was somehow removed from the domain.
I misread a 2004 sales agreement and almost sent a inaccurate letter to an attorney (never a good thing). Praise God I saw the error and made the corrections needed.
Lots of folks needing healing and such, hoping you all have someone close that cares and looks in on you from time to time. I think about Jim (Crash325) in near Tucson almost everyday.
Stay safe and have a nice day all.
/ Good morning!!!! #55,966
2017-03-14, 0240
14 right now...heading to the mid-20's for the high today. Obviously, the big news is the Nor'easter coming through today and tonight. I'll be heading in this morning (work is 50 miles south) with the expectation of leaving about noon.
Tractor is fueled and the shovels are ready...
Update at 0401:
I decided to work from home today...
Got my work laptop and everything I'll need...as long as we don't lose power (a distinct possibility), I should have a fairly productive day.
Good luck to all of us New Englanders (as well as you guys in the Mid-Atlantic states)
/ Good morning!!!! #55,967
Quite a heavy dew and plenty of sunshine this morning. Lambs are up an about, trying to persuade their mums to stand so they can have breakfast. Most ewes ignoring lambs for the moment, preferring to lie on their bed of warm grass for a while longer
David, that is real shame about Aquion. The technology sounds good, so no doubt someone will buy it up and start production again one day. I guess you have lost whatever warranty was offered on the batteries, just hope you have no problems in the near future. Anyway if you did, you know what you are doing, so you will always find a work around - yet another potential project to keep your brain working :)
/ Good morning!!!! #55,968
Good call, Roy.
32, and only getting sleet mixed with rain here, then likely some snow later this morning and windy...had snow for a few hours yesterday afternoon while I was clearing an area with the chainsaw. My chainsaw is real tired, its shoulders are aching, so good that the weather will give it a rest today.
Sure could use a slice of cherry pie with this cup of Nicaragua coffee this morning.
/ Good morning!!!! #55,969
30 this morning and light snow ground covered and that's about it. Wind picks up later today snow showers but we are basically done
NE hunker down time some areas huge amounts of snow others dry slotted but a pretty big deal nonetheless
Shower and bath remodel at a standstill shower plumbing roughed in wrong looks like a lot of tile will have to come down and we remain on hold for another couple of weeks. At least the toilet works and the heated floor which feels good on your feet
/ Good morning!!!! #55,970
21 right now. Tractor is greased and fueled. Waiting for the storm to start here. Generator is fueled up waiting. Will be going out at least two times before final cleanup. 24 inches and heavy wind will give me lots of drifts. Stay safe everyone.
/ Good morning!!!! #55,971
17F mid 20's for high.
Quite before the BIG storm:rolleyes: already much as I can be should be interesting.
Enjoy the day all.
/ Good morning!!!! #55,972
Enjoy the day all.
Thomas be safe heavy wet snow heart attack time
/ Good morning!!!! #55,974
30 out this AM. All I was hearing this AM was ice pellets coming down all night long. Wind is "howling" and there is a nice glaze to everything with all sorts of precipitation falling.
Think I will manage the wood stove for the day.
Have a great day all, do not over do the snow, be safe, watch that ice.
/ Good morning!!!! #55,975
relatively warm 44 degrees going up to low fifties, than plunging temps after that. Concerned greatly over 24 degree low tomorrow morning, sheets going back over things where possible. Orchard will have to fend for itself unless I get really motivated and spray it with water. At 3am that sounds like a very cold project...
rainy and windy out, 13mph from the West gusting to 20. Pretty mild considering what the folks along the coast are going to get. Not a good day to be in NYC I'm sure.
Don, my eating a large salad IS low fat...didn't understand your concern, but my idea of balance also includes calories and trying to maintain a more concerned, enlightened yet flexible approach to food. I've gone from eating fast food three or four times a week to none. Another part of what I call "balance". So if I eat a few too many pieces of pie, it's balanced by my trying to avoid sugars and carbs elsewhere. Plus I'm now alternating salmon burgers and veggie burgers with beef burgers. My annual physical is next month and am very curious to see how my cholesterol and sugar numbers come in. And for sure, watching my PSA.
/ Good morning!!!! #55,976
27° snow still coming down outside, but sounds like some sleet. Radar shows us on the border of the two.
Wind has picked up.
Gonna nestle back down in bed, not going to work in this.
Just had my bloodwork done, my cholesterol numbers were very good, but I do take a statin. Need to reduce the dosage.
/ Good morning!!!! #55,978
Just took a Frisbee hike and fed the birds...over an inch of rain and ice in the gauge, everything covered in ice...broken branches, especially the red maples, since the branches are holding the seed helicopters...heard several pine branches snap...hopefully ice will melt off before the wind gets any worse.
/ Good morning!!!! #55,979
Coffee is done brewing. 66° with clear skies this morning. Heading to 93° with lots of sun. Nice day yesterday. Citrus trees are in full bloom. Pollen and citrus smell in the air. Another patio day until sinuses start acting up.
Those in winter weather stay warm and safe.
Good Morning All.
/ Good morning!!!! #55,980
Sunny and cool today. I hope this continues for a while.
Replaced my mail box yesterday. I had to keep telling myself that it is only a tiny hole 2 ft deep to bury the post. The temptation to hook up the PHD was strong but it really wasn't needed.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2018 New Holland C227 Compact Track Loader (A61306)
2018 New Holland...
2014 Club Car Carryall 295 4x4 Gas Utility Cart (A59228)
2014 Club Car...
2013 Ford F-150 Crew Cab Pickup Truck (A59230)
2013 Ford F-150...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2018 Deere 323E (A53317)
2018 Deere 323E...
