Good morning!!!!
   / Good morning!!!! #55,081
The shot gun was a skeet semi auto made in Japan for S&W very deep blueing but never became popular in gun circles. I trade a motorcycle and some boot for it in 1976 and even now lost money on that deal. The 45/70 is a Marlin lever action. Over and under shot guns have one barrel on top of the other like a ruger overandunder generally using the same gauge. Used heavily in bird hunting two shots then reload. Double barrel as the name implies two barrels side by side. There are companies that make a rifle and shotgun combination Savage and CZ make them as well as others. Having never owned or shot this type my knowledge is somewhat limited.
Over and unders were designed to allow the hunter to have one gun that served two purposes and if for instance you were hunting birds and a coyote came close you could shot him with the rifle therefore the dual purpose.
This lever action I obtained was more for my collection purposes to complement my 44 Marlin. The 45/70 is an old caliber dating back to the 1800s. Lots of knock down power but limited range.
Hopefully this helps
   / Good morning!!!! #55,082
18 and searching for a high of 23. More snow in the forecast for tonite and Tuesday. I will be going out at about 10 A.M. to scrape yesterdays' snow off the driveway and others as well.
   / Good morning!!!! #55,083
Need to get coffee started brewing. 63° with cloudy skies this morning. Heading to 70° with some sun. Lots of lighting, rain and wind early this morning. Woke me up way to early. Need more sleep.
Good Morning All.
   / Good morning!!!! #55,084
23 going to 27. Just finished doing three driveways and opening up the other 5 neighbors ends. We got over a foot and now the sun is out. 40-50 mph winds coming so the drifts should be mountainous this evening.
   / Good morning!!!! #55,085
5:30AM PST and evacuation orders are still in place for low lying areas along the Feather River below the Oroville Dam. There are no reports of flooding, and looking out my back door at Lake Oroville, water is down a couple of feet from where it was when the sun went down last night, consistent with the CDEC readings of 898.19'.
   / Good morning!!!! #55,086
Good Morning! 44F @ 5:45AM. Partly to mostly cloudy. High near 60F. Winds light and variable.
Quite a bit of excitement at around 5PM yesterday when the Butte Co. Sheriff announced and evacuation for low lying areas below the Oroville Dam. That included all of the town of Oroville and over 180,000 people along the Feather River/Highway 70 corridor going south. Traffic on Highway 70 northbound out of Oroville was jammed as everyone scampered for high ground in Chico, the next largest town north. Many evacuation shelters have been set up and everyone seems to have found a place to spend the night.
This morning, main highways 70 and 99 going into the evacuation areas are closed and those needing to go south are being sent west to I5. The problem that triggered the evacuations was a "boil" near the top of the auxiliary spillway that was activated for the first time Saturday morning. Officials were concerned that the boil signaled water percolating under the weir where water leaves the lake and enters the auxiliary spillway. If that is the case, the top several feet of the spillway could fail resulting in a huge release of lake water, estimated to be a 30' wall of water coming down the river. Flows over the damaged main spillway were doubled to 100,000 CFS in an effort to lower the lake level below the 901' level of the auxiliary spillway. Overnight the level dropped to 898' and water is no longer flowing over the auxiliary spillway. We'll know more about the boil after the sun gets up, but plans last night called for filling it with large boulders put in place by heavy lift helicopters.
DWR is maintaining 100,000 CFS over the main spillway in hopes of lowering the lake level another 50' before another series of storms roll in Wednesday night. DWR officials continue to reiterate that the Oroville Dam itself has never been in danger of failing. That hasn't stopped the fear mongering going on here on other TBN threads and across the Interwebs as Chicken Little conspiracy theorists spew their shameful lies.
As a retired engineer my heart goes out to the people working to reason their way toward a solution. They are dealing with 40+ year old infrastructure and most of the people that designed and built it are no longer available to lend their experience and guidance to the effort. They're also up against Mother Nature and have no control over the path she takes. If these challenges weren't enough, the attitudes held by much of the press and the public are especially unfriendly to technology, especially that which impacts the environment. The biggest contribution this forum can make is to facilitate the dissemination of factual information related to the spillway failure to counter the fear mongering that's already going on and the witch hunts that will surely follow.
   / Good morning!!!! #55,088
27°F and clear skies this morning, going up to 50° today. Had to scrape frost from the windshields this morning. Will be glad when the remodel is done so we can get use of our garage back. The back half is full of furniture and stuff we had to move out of the house, and we left the carpenter the front half to use as a shop area.
Picked up the new front door from Lowe's on Saturday, so that should be installed sometime this week. The sunroom has three walls and a roof, and is wrapped. Carpenter installed the two doors and one of the windows. Remaining 10 windows should go in this week. Electrician has it all wired to boxes, too. Switched sunroom door knobs and deadbolt locks yesterday to new ones so all doors are now keyed the same. Plumber is there today to run pipes to the new laundry room.
Heard on the radio this morning about the Oroville evacuation. We've had a lot of bad flooding here in the STL area, but it is always from steadily rising Mississippi and Missouri Rivers, and we know plenty in advance that it's coming. I can't even imagine the thoughts about living below that dam and the potential it represents. Hope things work out OK out there.
   / Good morning!!!! #55,089
Some of our snow has melted, down to about 6-8 inches on the ground. Sunny and a high of 10C today should help the melt. Tomorrow night they are forecasting a rain storm with up to 4-5 inches of rain over a 3 day period.
   / Good morning!!!! #55,090
64°F and no rain since midnight
Not a great night's sleep, taking puppy out whenever he cried. Don't think he likes his crate. The kitten thinks he has someone his size to torment. All fun to watch
Prayers for those in RNG's area.
Be safe
Have a great day
   / Good morning!!!! #55,091
RNG, here's hoping that, in future days, you have a ring side seat to watch absolutely nothing happen!
I did read the other thread you referenced. Looks like the "usual suspects" showed up to demonstrate how little they really know about anything.
Northern Cali and Oroville are on our prayers.
   / Good morning!!!! #55,093
I really thought this storm would have given you more snow. I know deep down you would have wanted at least two feet.
Enjoy your day off
:shocked:
   / Good morning!!!! #55,094
Sure praying that dam holds, and they can fix it.
Got a new to me computer. Both desktops at home are still on Windows Vista, and so there is no more support for it.
I found one that twitched my eye.
Dual Xeon 6 core processors (yep, 12 cores). I only have 8 at work.
12G ram
NVidia Quadro 4000 video card
keyboard and mouse
DVDRW
64 bit Windows 7 Pro
$406 plus tax and shipping
I might call it Watson. or Cadmaster.
   / Good morning!!!! #55,095
12G ram
keyboard and mouse
DVDRW
Hybrid or SSD for disk would be nice...
   / Good morning!!!!
RNG, hope your dam holds. Great weather down here in Florida, but the weather is a little more bearable back home. I miss my wife and boxer girl!
Be safe!
   / Good morning!!!! #55,098
2017-02-14, 0307
20 right now...upper 20's will be the high today.
   / Good morning!!!! #55,099
:thumbsup:
I'm assuming once the market went to automatic shotguns, or the classic pump, side by sides went away?
I would think an over-under would be a heavy gun.
Drew, here a few people still buy new side-by-sides for their classic elegant looks (and they are slightly easier to reload quickly), though over-and-unders now dominate the game scene (pheasant and partridge) and clay pigeon. All break barrels have one tremendous advantage when shooting with other people, they can be carried with the barrels broken to clearly show to everyone around that the gun is not loaded. With modern materials they can make over-and-unders extremely lightweight if that's what you want, although in truth some weight is good if you don't want to bruise your shoulder with repeated recoil.
3 barreled shotguns are back in production too. Anyone fancy one of these ? Akkar Triple Crown review - Shooting UK
You can also get a combination of rifled and smooth barrels in a three barreled gun. We use the German word "Drilling" for these. Not at all common, but if you fancy plinking out back with one, you could do a lot worse than to treat yourself to one of these that I see are sold in America with that same name Blaser USA: D99 Drillings
   / Good morning!!!! #55,100
Good morning. We had a glorious sunny day yesterday, defying all the weather forecasts, though unfortunately they look to have got it right today.
:thumbsup:
If anyone wants to find out what is happening in Oroville, may I suggest you exercise extreme caution in searching the web, it is far less dangerous to wait and get the story from our man on spot, RNG. You see, there is the possibility that you could inadvertently come across "Orville" - not Wilbur Wright's brother, but "Orville the duck", a bright green ventriloquist's dummy that used to appear far too frequently on British TV. A few minutes of Orville can leave you feeling quite nauseous, or in extreme cases you may completely loose the will to live (only small children seem to have any natural immunity :)).
2022 BOMAG BW145D-5 SMOOTH DRUM ROLLER (A60429)
2022 BOMAG...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
1757 (A60430)
1757 (A60430)
Volvo ECR235CL (A53317)
Volvo ECR235CL...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A60432)
UNUSED FUTURE SB45...
17102 (A56859)
17102 (A56859)
