Good morning!!!!
   / Good morning!!!! #202,231
Reading about your fridgid temps and snow makes me so appreciative as I go out to mow. Stay warm and safe.
Happy Mowing! I'll probably be doing some myself this afternoon now that the slight snow has melted.
   / Good morning!!!! #202,233
But i'm having so much fun trying to figure out Medicare and SS.... And realizing that when I take Medicare, I get to pay extra, because I have to keep my existing health plan for my wife's coverage.
   / Good morning!!!! #202,236
Good Evening Ken,
Did you check the drain filter for the washer.
Usually a plastic basket somewhere around the bottom.
Ours was full of dog hair and caused draining issues.
Ken, the last time we were up there I pulled the top and front off of the washer!
I had to use a shop vac to get the water that was in the drum out, top load model, and then used a pan under the pump to drain the rest of the water! Total pain in my butt ! I didn’t see any filter but of course I was laying on my belly ! I also checked the drain hose for any obstructions , none found ! When I get up there on Friday I will pull the entire unit out and take a closer look !
I will report back at that point ! 😉
   / Good morning!!!! #202,237
Happy Birthday Holly!
I actually went outside today and pumped 100 gallons of furnace oil into the furnace tank. The temperature was 10 above. No I didn't 'bundle' up, just my usual mukluks, jeans, t-shirt and a thermal shirt on top of that. The only part of me that got cold was my fingers and they were inside of gloves. I wonder if that could be because I froze all my fingertips when I was in Alberta back in the 70s.
I did check out remote fuel level sensors and I think I will stick with what I have.
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
2015 Komatsu PC490LC-11 Hydraulic Excavator, S/N A42603, PIN# KMTPC251HFWA42603, Turbo Diesel (A59076)
2015 Komatsu...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
