Good morning!!!!
   / Good morning!!!! #202,213
Interesting, when we don't have a good snow cover the frost goes much deeper into the ground. Were the ground is blown clear of snow the frost will penetrate quite deeply when it's cold. But 10-12 inches of snow cover and the ground warmth will pull all the frost out of the ground and it will be thawed under the snow.
Back when we got more snow fall it was interesting (at times) spreading manure in the winter, using the wind blown ares in a field to get out up towards the higher areas of a field and spreading going downhill through the deeper snow as any spinning in the deeper snow and you'd spin down into muddy thawed ground till late in the winter.
It's the extended cold that really effects the geo system. Loop geothermal doesn't have the delta T in this cold weather like a pump and dump geo system like paul has. In an extended cold or heat spell, the ground temp doesn't change fast enough, the loops cant recover much. It's still better than an air system. Once you suck the heat out of the ground around the loop, it takes awhile to recover. The sun on the ground above helps the geo system in winter.
my units were both up to set point last night, and should recover later today.
With sun out, temp just hit -1 deg out at the weather station.
Upstairs we have been using an electic heater in our room, which is probably 1/4 the sq ft of the whole upstairs area. The geo upstairs dropped 6 deg last night with us keeping our room heated to 70 deg.
Next week it is supposed to get near 50 deg out.
   / Good morning!!!! #202,214
Good Morning!!!! 38F @ 5:45AM. Abundant sunshine. High 74F. Winds NNW at 5 to 10 mph.
Coldest day of the winter so far here, but still not cold enough to make a frost. Very thankful for the mild temps, but weather like this has a high price.
Made another SOS stew last night, this time with red and black beans, potatoes, rice, and with some tomatos and spices thrown in for good measure. Tasty and filling, I'm encouraged by these good early results. Time to hit the grocery store for more supplies.
Headed out in a bit to pick up a buddy and take them to a doctor's appointment, the first since the hospital stay. Hopefully will get the blood pressure meds adjusted, as trying to drive and work a day just isn't possible for them now. No sick days for landscapers, as it's no work, no pay for an independent contractor.
Happy Hump Day, folks.
   / Good morning!!!! #202,215
A closed loop system will cold soak the heat sink, weather it’s buried loops or a loop in a drilled and grouted well, as compared to an open loop system where the water is drawn from one well and returned to the aquifer via a second well. The open loop system has the entire aquifer as a heat sink and will provide water at about 55° regardless of the outside temperature. However for totally illogical reasons, many locales won’t approve an open loop system.
The good news is that a heat pump doesn’t lose much efficiency, just capacity as the evaporator is in low ambient conditions, whether it be water or air. It would be a safe bet that Dennis’ loop return is at least 20 degrees above the ambient when it is this cold outside.
The huge advances in heat pump efficiency pioneered by mini splits were a result of having a microprocessor control the entire process. They use a variable speed compressor, electronically controlled expansion devices and variable speed fans at both the condenser and evaporator.
This technology is just beginning to trickle into conventional heat pumps, and only partially adopted in the geo world.
I’m guessing that Dennis has variable speed loop pumps, but a single speed compressor (possibly two stage) and a fixed speed blower. That might be an ECM blower, but other then ramping up to speed, it likely runs at a single programmed speed rather than as part of a process control.
That is essentially the way mine works, but with a motorized ball valve to control the flow rather than a loop pump.
The bottom line is that a high end conventional heat pump is likely more efficient than a legacy geo system, almost certainly if it’s a closed loop system.
   / Good morning!!!! #202,216
7 this morning high in upper 20s
Today is Holly's birthday the big 70. Great tribute on Facebook by our son to his mom
Two more skin cancers on face oh boy rump scrape off just sore.
The cold will retreat for a little bit until end of month then return. Son had 5.5 in of snow at Pawleys Island SC
Prayers for all our Country
   / Good morning!!!! #202,217
Fixed speed loop pumps
2 stage scroll compressor
variable speed blower motor
I can control flow by adjusting ball valve manually.
When installed, this was pretty much the advanced system, not so today.
And no mechanical system permits required here.
   / Good morning!!!! #202,219
good morning, COLD WARMING UP TO 17 brr
kept the oil fire going overnight really made it nice to get up. the mini split heats well even at low temps when needed so it is always an alternative to the wood stove
picked up an Apple Watch yesterday and learning about what it can do
picked up groceries and went to the appointment for the finger,
looks good and next appointment in a few weeks. the joint was pulled out of its socket so will take time to heal as well
Buppies, happy birthday to Holly. glad you are staying on top of your skin cancers
   / Good morning!!!! #202,220
Sounds just like our geo. We also use the desuperheater for hot water generation.
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Sterling AT (A56436)
Bobcat 873 (A55272)
Bobcat 873 (A55272)
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
