Good morning!!!!
   / Good morning!!!! #202,231
Reading about your fridgid temps and snow makes me so appreciative as I go out to mow. Stay warm and safe.
Happy Mowing! I'll probably be doing some myself this afternoon now that the slight snow has melted.
   / Good morning!!!! #202,233
But i'm having so much fun trying to figure out Medicare and SS.... And realizing that when I take Medicare, I get to pay extra, because I have to keep my existing health plan for my wife's coverage.
   / Good morning!!!! #202,236
Good Evening Ken,
Did you check the drain filter for the washer.
Usually a plastic basket somewhere around the bottom.
Ours was full of dog hair and caused draining issues.
Ken, the last time we were up there I pulled the top and front off of the washer!
I had to use a shop vac to get the water that was in the drum out, top load model, and then used a pan under the pump to drain the rest of the water! Total pain in my butt ! I didn’t see any filter but of course I was laying on my belly ! I also checked the drain hose for any obstructions , none found ! When I get up there on Friday I will pull the entire unit out and take a closer look !
I will report back at that point ! 😉
   / Good morning!!!! #202,237
Happy Birthday Holly!
I actually went outside today and pumped 100 gallons of furnace oil into the furnace tank. The temperature was 10 above. No I didn't 'bundle' up, just my usual mukluks, jeans, t-shirt and a thermal shirt on top of that. The only part of me that got cold was my fingers and they were inside of gloves. I wonder if that could be because I froze all my fingertips when I was in Alberta back in the 70s.
I did check out remote fuel level sensors and I think I will stick with what I have.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
1999 Vermeer SC505 Walk-Behind Tracked Stump Grinder (A55851)
1999 Vermeer SC505...
2013 RAM 4500 (A50323)
Gate (A55853)
Gate (A55853)
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
Mailbox (A55853)
Mailbox (A55853)
