Good morning!!!!
   / Good morning!!!! #200,085
Drew, the propane/co2 sensor will start beeping when low voltage and when it is out of date. This is one like I had in my MH. If out of date. It will need to be replaced.
I had to replace mine a couple years ago. Next to my power panel.
Water tote drained.
Brought my eufy camera in to USB charge, was at 38%, now up to 80%.
Ordered 2 more eufy cams today, one indoor only $28 and another S340 solar.
   / Good morning!!!! #200,086
when I was inside, didn't sound like it was coming from there
funny, that unit says replace every five years. My rv is five years old...
I have two co2 detectors, one hardwired like referenced and one portable.
thanks for all suggestions.
got the garage cleared out, Gravely put in garden shed, and went to build a new work bench.
could not find hex key set, know I have at least one. Need a 5mm one, think I might have a driver bit that will work.
I'll look more tomorrow.
well the big snowman is having technical problems. The light inside works but doesn't spin. No way to get in there.
so that feature didn't last long.
   / Good morning!!!! #200,087
Got tree up after the wife left, will surprise her when she gets home. Drew just reminded my I need to get the snowman out, but think I'll wait as that will tip her off.
   / Good morning!!!! #200,088
Does the FAA set minimum altitude requirements over residential areas? I swear I've seen jet airliners over this house less than 100' off the ground. The noise was deafening, and it sure doesn't seem safe.
§ 91.119 Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
(d) Helicopters, powered parachutes, and weight-shift-control aircraft. If the operation is conducted without hazard to persons or property on the surface—
(1) A helicopter may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section, provided each person operating the helicopter complies with any routes or altitudes specifically prescribed for helicopters by the FAA; and…
In Ken’s case the first sentence says it all, as long as it was landing next door.
   / Good morning!!!! #200,089
Good Evening,
Dennis, solar is great when you can’t find an outlet or hardwire but if you have no power, you also have no WiFi unless you have a whole house generator !
I surprised Kathleen when she came home from shopping, I installed our 4 ft snowman by our front door ! It’s not a fancy one like Drew bought, just your run of the mill 4 foot snowman ! It is lighted though ! 😉😀
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
2019 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
