Good morning!!!!
   / Good morning!!!! #192,521
Great picture of Della
Great picture of duck
Agreed! Della looks like a natural in the water!
It's funny how you get attached to visiting wildlife. In the "no longer visiting" category is a one legged goose, a white snow goose, and a speckle belly goose. All hung around for a while, but are gone.
Going to 90F today. It's just getting daylight, so I'm heading out to install a new fuel pump in the motorhome generator. I've spent two days doing all sorts of fixes and troubleshooting and I think this will fix it for good. At least I hope so.
Had Rigby in for 2nd vaccination yesterday. He is 20 lbs. He was 12 lbs. when we picked him up 2 weeks ago-- wow they grow fast!
Hope everyone has a great day !!
   / Good morning!!!! #192,522
Good Morning
55° with a high of 80 today, low humidity, no rain. Pretty nice day to be outside.
Yesterday was another busy day on the construction site. Progress is continuous and swift.
Access to the attic is from the garage. I’m going to take a 300lb straight ladder and make brackets to hinge it up out of the way. The small room will be the boiler room. I had to move some wiring that passed through the new doorway into the garage.
Had to put the loader and forks on the tractor to move some pallets for my neighbor, trucking company tailgated them any the end of his driveway.
Later went and picked up a Carryall for the same neighbor.
Boys are coming to play music tonight,
I’ve got some more detail and electrical work to do for the old folks home.
   / Good morning!!!! #192,523
Good Morning,
Vt, 46 to start going into mid 70’s ! Cool crisp morning, refreshing after some of that hot humid weather we have had so far !
We have some friends coming up from Ct later, unfortunately the weather doesn’t look very good for Saturday and Sunday! Looks like we will have to play it as it comes !
Kathleen and I will try getting a boat ride in today before our guests come up !
Thomas, nice shot of Boo and cub !
Plowhog, Rigby is looking great and growing leaps and bounds !
Hope all have a great day ! 🙏
   / Good morning!!!! #192,524
That sure is the truth! Zoe is 18 months old, and still has a puppy brain and enthusiasm, but the stature of a moose! And she is still growing…….
We should have named her Clifford.
   / Good morning!!!! #192,525
Unlike my old Indiana hunting property, I don't have the invasive garlic mustard here in Iowa (yet...). Instead, I found a new invasive to go after - wild parsnip. This one is BAD. They're all over, and the sap is TOXIC. If you get it on you, the exposed area will develop a bad rash or blisters when exposed to sunlight. Grandson found that out, I heard. Easy to identify and pull (if ground is at least semi loose) or spray, but I use gloves and full length shirt/pants to be safe.
Soaking rain today. We sure don't need it, but the corn is loving it...
I made a fun little RallyCross test track to play on.
   / Good morning!!!! #192,526
Morning all, 65 going to 82 and sunny.
Worked late, nothing useful done.
Wow Paul/Popgadget, that is really moving fast and starting to look like a house.
Pup pictures are great.
Had the 2 fawns playing in the front yard so I could see them while I worked, they were certainly having fun running around and jumping.
Back to work, some watering and maybe get some more work on slab table.
Did some edge cleanup and trying to figure out how to get the last foot aligned since one is up about an inch from the other, even though they are cut one after the other from the tree....May just need to lose the last foot of length :-(
Be well,
Moon this morning on dog walk.
   / Good morning!!!! #192,527
Good Morning!!!! 54F @ 7:15AM here in Orcutt, CA. Foggy this morning, then partly cloudy this afternoon. High 68F. Winds W at 10 to 15 mph.
Back up north there's an Excessive Heat Warning and the high will be 98F. Ugh!
Very impressed with your house purchase and move, Don. You made it look so easy!
You picked a great contractor, Paul. Hope they can keep the momentum going.
Wow, Frits. That thief picked the wrong phone to steal!
RNG tank and fuel level a big ? Was working fine, then I purged the tank and as result the level guage started acting up. Would go to full and immediately drop to empty. My friend, Jim decided to disconnect, jumpered the wire. When starting it work go to full, but go to empty as part of the stalling sequence. Now it just stays reading empty but I detect a flicker of movement when running. Should be a way to test.
I suspect I will drain tank and remove, then pull the sensor and inspect for damage, not that I expect to see any. Maybe I’ll have found a test by then. So at this point I don’t have a clue as to its role in the scenario. This is a strangely shaped tank fit up under the operator station.
The symptoms you describe sound like there's a faulty connection between the sensor and the ECM, David. You could try tracing the sensor wire, wiggling it while the ignition is on to see if you can cause the gauge to jump. In my experience, when a new problem crops up it's usually caused by the last thing I did. If that's true in your case, the tank flush maybe broke or damaged the sensor or the wire. Any chance that the ECM is cutting power to the ignition if it thinks the fuel tank is empty to avoid having to reprime the fuel system?
Smooth trip down yesterday, and not even any drama trying to get up the gravel driveway with more than a ton in the trailer. Gave myself plenty of following distance and had no problem with the mill sliding around the bed. Not surprising considering the 2" and 4" wide ratchet straps. Took a few tries but got the trailer backed up to the garage OK, then the neighbor across the street helped roll the mill off the back, just using the rope winch and several lengths of half inch pipe. Still need to move things around to make a final spot for it, but the hardest part is done. What a relief!
Today I need to either cut back or remove a concrete step that sticks out too far onto the concrete covered side yard. I'll be bringing the VW van down next trip, and the van can't get by that step. The step looks like it was poured using concrete left over from a larger job, and I'm hoping there's no rebar in it. I'll see what the rental place wants for a concrete saw, but will probably just use the Harbor Freight jackhammer to remove it all together.
TGIF gang!
   / Good morning!!!! #192,528
it’s a safe bet it was the plug. The Honda electronic ignition is very sensitive to the resistance of the plug, as the plug wears, collects deposits, and the gap changes the voltage to fire it changes and the ignition doesn’t deal with it well. A common issue is kickback when starting, it is not intuitive that changing the plug would cure that. Adding to that is that the plug can look perfect and still be a problem.
Don't think I can complain. Found the receipt from Sam's Club from 1997 and I don't recall ever changing the plug
   / Good morning!!!! #192,529
78F and sunny @ 12:15, WU says it's heading up to 85 for the day's high. Local Cleveland weather guy last night said it could go 88F down here around Akron ... :(
Either one probably too warm for much activity out in the sun beyond just mowing.
And the front lawn probably does need mowed ... given the recent rain we got. East side definitely does.
Got the plexiglass routed out last night on the drill press. Turned out reasonably decent.
Today will be the day to get the tube feeder pole and feeders put back up, scatter some seeds for the ground feeders and put out one suet cake.
Have a pretty bad leak at the loader valve on the Kubota, think it might be one of the couplers. Maybe get that cleaned off and see if I can trace it down. I do have some flat face couplers I can swap in.
Need to install the Lock-N-Lube coupler on the grease gun and grease the loader.
Put up another Japanese Beetle Trap we picked up at Lowes the other day, check existing ones to see if bags are full and need changed out.
Looks like winds are light so maybe get some spraying in as well.
Have one bill to schedule for payment.
Plus whatever else comes up.
Hope everyone has a decent Friday ... (y)
More info coming soon! (A53421)
More info coming...
2013 Jeep Patriot Sport 4WD SUV (A55758)
2013 Jeep Patriot...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
