Good morning!!!!
   / Good morning!!!! #182,211
I went out to grab a light rake to cover some bulbs that were already coming up
and when I pushed on the garage door opener
nothing
here we go again
nothing, with a six month old backup battery
the gfi tripped likely due to the storm and that takes down the garage door.
which is why one has a backup battery. Or thinks one has.
apparently when the rain came down, more than several inches, floor in garage floods.
unfortunately there was a surge strip down there.
I usually try to keep them elevated for just this reason.
gfi had tripped, no juice.
started disconnecting things to determine what was unhappy and when I picked up the
small surge strip and water poured out of it, well I don't need to be an EE to figure this out.
That strip went in the trash, had a spare, hung that high up.
the seriously difficult part of this is because the garage has no entry door. Just the big door.
So if the garage door doesn't go up, I have to climb through a window on the side of the garage.
that takes some contortions but I've now done this four times. I will hurt myself at some point
squeezing in that window and flopping down on a plastic folding table. each time I survive I am thankful.... :rolleyes:
I really need to rewire the garage door opener to a circuit not controlled by that gfi.
the oem battery backup is almost useless, battery drains down.
I have a spare, that's a to do. Would be nice to wire a big AGM battery into that circuit, like an old car battery.
thanks for kind words Scaredy.
then after that extended interruption, I undid two long tangled extension cords, 10G long yellow cords that somehow had
entwined in an advanced mating maneuver hard to undo. This time I redid them with nice velco ties.
100 footer too heavy for me to hold up while rolling up, so I did it in three sections, using a large Hold-it velcro tie.
those things sure come in handy.
but once it was all undone, I ran the long cord out to the generator and put the smart charger on the tiny battery in it.
It turned green in under a minute. It doesn't charge when the motor runs, dumb design. So they give you a separate charger to plug into
side of gen. I don't even use that and go direct to the battery. At least it's 12V and not something proprietary.
   / Good morning!!!! #182,212
Good Afternoon LS,
Very nice decorating pictures ! Since your posting some pics, I guess I will do the same ! 😉
Actually the wife takes most of the credit for all the decorations!
The chairs and ottomans near the tree are Willam Morris chairs I built many years ago, I can take credit for them ! 😉
And no I didn’t forget that I’m getting some pictures for you of the corner cabinet ! 😁
   / Good morning!!!! #182,215
Could you fix a small ladder or something inside to climb down on?
Flopping on a plastic folding table reads like a recipe for a collapsed table.
And as much as I enjoyed your writings from the hospital before I'd just as soon read your writings from when you are out and about and hale and hearty.
   / Good morning!!!! #182,216
She is working for the govt what is called Foreign Service Officer in most countries
She was in Riga before and now returning. She works on East European issues among others defence of the Baltic countries
Thank you for your offer to help
Not sure how much spare time she will have on this trip
Will let you know if she has questions about area and what to do
Because people are scared from russian aggression, anyone from US who is involved on defence (actually spellcheck suggests "defense" :rolleyes: ) of Baltics is treated here like God. At least it should be so :)
Actually I live like 3 mi from US embassy ;) In case of anything, just let me know. It will be my pleasure.
   / Good morning!!!! #182,217
in my defense it was a pretty sturdy table, rated for 300 pounds but it surely sagged.
and I did move everything off the table, out the window, and then stood on top of pull garden cart with vise jammed behind its
wheel so it wouldn't move. It was truly laughable. An OSHA nightmare. I think a little engineering is called for here.
Knowing my landlady isn't paying for anything that doesn't break. It's their mentality.
Even if she likes me, which she does.
Popgadget, what is a reasonable height limit to take a drone safely when not near an airport, no warnings buzzers going off on the screen?
How low do small planes fly? Do they have to stay above a certain height in this area?
what I learned today is my drone will go up 1500 feet. I only went up 300 feet today. Am wondering if I'll see the curvature of the earth if
I go all the way up. Apparently there is a way to mod the settings to double that height, to 3000 feet.
thankfully there is a distance meter on the drone control so I can stop at a desired point.
basically I chickened out at 300 feet.
Popgadget, what's my safe ceiling in suburbia and local farmland?
   / Good morning!!!! #182,218
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
   / Good morning!!!! #182,220
I got the driveway plowed for the oil guy. New driver, didn't know how to fill a 200 gallon tank that has a pump occupying one of the top holes. Just take the whistle out and fill there and watch the gauge. 622.2 L = 164.6 US gallons Cost me $1032.05 CDN
The 'carbon tax' is gone off the HHO. This is a good thing.
Tomorrow morning I will be plowing out the neighbours and touching up this place, too. The a dump/town run.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
New/Unused Spirit Electric Tricycle (A57453)
New/Unused Spirit...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
