Good morning!!!!
   / Good morning!!!! #177,041
I also got bit by a brown recluse, that was the worst bite I ever had, felt ill and half my body turned bright red.
You already answered but I was wondering about your long term scar.
The gentleman we did work just purchased a 6060 limited edition metal flake paint, 8 foot bush hog, grapple. Pallet forks, air ride seat, very nice looking tractor takes care of 88 acres
Nice tractor. $$$
Piddling turned into a major auto project.....
The "temp control" in our little car broke a plastic gear again in the knob contraption. This is the third gear....
The original was replaced with a junk yard assembly, which quickly broke the fourth or fifth time it was turned.
Replaced the replacement....same thing again. The replacements are junk yard issue --- can't find a new one, but they used to cost $479 when they were available. The plastic is becoming brittle with age and heat.
Ended up taking 3/4 of the dash apart to gain part access to the blend door.... it moves but is kind of 'tight' throughout the motion. Only way to gain access is to remove the heater core and a/c condenser..... not going to go that far.....
Ended up just setting the blend to mid point to get some heat for the defrost. At least I know where the connection is and can manually get it changed if need be.....
I just have to put on my engineering cap and figure out a redneck design for a fix.
There's been heavy cloud cover all day, temp only up to 61° so far. A couple light sprinkles took the gauge up to 1/8". The guessers are saying better chances for heavier rain later this afternoon and tonight. Fingers are still crossed.......
Pictures? Is this the controller head, or the blend door actuator? Or something else? On the standard GM type, you can take the blend door actuators apart and sometimes turn the broken gear 180 degrees, and put it back together. Depends on the amount of movement it provides. If you could get the broken gear out, you might be able to get one 3D plastic printed.
Son had a fairly good game as an individual, but his team lost badly. He still plays a little tentatively. He played on kickoff and return teams (only 1 kickoff, 5 return teams). Also linebacker and full back. He recovered a fumble on the kickoff....only for his team to fumble it back away on the next play. The other team had a player that should be on varsity and not 8th grade.
I stopped at Bucees to fill up my car...it had gone up from $3.22 to $3.59/gallon. Ouch. Then on the way home, I saw 2 stations that hadn't raised their prices yet. So I took the SUV down and bought $80.50 worth at $3.29/gallon. Saved over $7. on a fill up.
Yes Drew, the winds have blown both ways. Keep on posting. Like my above paragraph. I'm pointing out something, without pointing fingers. We've been doing so good here, despite the times. I guess some people like expensive gas and food.
I wonder how the huge lithium prospective mine in Nevada/Oregon will play out? I'm already seeing hardcore environmentalist protesting, whilst the EV crowd who believe that they themselves are "environmentally green", and now that big ole' huge open pit strip mining come here....I'm just wondering how it will play out. USA has always had a pro mining tendency. But the main thing is, it will buy us freedom from foreign lithium...which might be the biggest thing of how things play out. I say, dig out the lithium, and fill the hole with broken wind generator rotor vanes. Then cover it up.
How's that for coffee talk?
Prayers for our team.
   / Good morning!!!! #177,043
Good evening all. 66ºF for the start, overcast, light breeze. Light wind, overcast most of the day, and high temp was 74ºF. Putter to start, then bike ride, then to town for lunch and groceries. Call A/C guy for bubbles in sight glass, they tech should show later in day. Started in on outside light on timer, bulbs ok, no power comer from timer. Probably ants in contact that allows power to fixture. Clean and reassembled fixture. More work on that tomorrow. A/C guy showed up, junk on outside coils and filter getting plugged. He showed me how to clean coils with out pull fan. Metering valve for Freon not what it used to be but still ok at this point.
Ron nice over night rain. Sorry about window washing and mosquitos. Glad parts are installed on bandsaw. Hope you were able to get limbs for neighbor. Nice flower pic
Ron that is a lot of windows to do.
Drew hope equipment return went well. It has cooled off for me, just not sure how far south cooler air has made it.
RNG glad trip back went ok. Sorry about wrong stop cock, hope you can get right one in morning. Glad you were not stuck with Jury duty.
Mike hope you got in touch with plumber and got dates set. Hope you day job is going well enough.
Drew sorry about the cyst, hope easy fix :)
Don 90ºF will be delightful after 100+. Good question on casket warranty.
Kilroy good score on the logs. Hope processing them goes well.
Thomas hope day went well.
Ken Glad replacing surge protector fix mini-split. Hope it dries out enough for trimmer yard. Hope you get to firewood.
Buppies hope you got your rain. Thanks for outlook. prayers sent.
Paul shame it took a funeral to get all of his friend together. Hope today productive and grass dries quickly.
Billy sorry about the black widow bite. Glad you got good start on mowing.
Phil hope you don't wash away in all that rain!
Dennis thank for letting me know that is the cat.
Drew hope you can get cyst taken care of. The apple man commeth :)
Kilroy nice progress on logs.
Dennis nice walk.
Ted the no rain streak broken! Hope you get some real rain.
Drew glad equipment return went well.
David enjoy the apple show. Hope no leaks on pool mods. And you can find some mowing time.
RS sounds like a lot of spraying, and watering. Good luck wit garage cleanup.
Ted good luck with home brew solution. Hope you get more rain.
Buppies sorry wife not better patient. Prayers sent.
Thomas glad day was good 3 hours with trimmer long time.
Don good to hear temps no where near 100.
David good to hear change over good. Hope you can run on solar pump.
Randy(wag) hope did not affect you too much. Hope town trip good.
DFtodd sorry about tooth issue, pain will really mess with blood pressure.
PJ glad uneventful day.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /sleeping, /wife healing, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, Lou /eye issues, /heart issues, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /land development, /favorable winds not in the forecast there "alligallyitus" and back in hospital, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, mike /wife's healing from surgery, Scotty /back pain, Helogabals /second opinion, /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
   / Good morning!!!! #177,044
Drinking first cup of coffee. 48° with clear skies this morning. Heading to 67° with partly cloudy skies. Went to neighbors and moved tree limbs off their lawn. While took down a pine tree that was blocking view of flower garden. Rest of the day was spent relaxing. No plans for today yet.
Found this Katydid on my barn door.
Everyone stay safe and well.
Good Morning All.
   / Good morning!!!! #177,045
Morning. Nice balmy 66° out. Up at 3am to catch a flight to a work shindig. It's an appreciation for the service managers who recieved top shop last year.
2 days at a resort in Florida. Not sure of what's all going on. They did say that the attire for the event is beach casual. Shorts and flip flops for the duration.
I do know that dinners in the sand tonight on the beach. And a fishing trip tomorrow afternoon.
From what my regional manager told me, they are apparently doing a presentation in the morning and looking for our feed back.
Spouse was included in the invite, but our daughter had planned a trip to Europe at the same time, so someone has to watch the grandkiddo.
   / Good morning!!!! #177,046
60 this morning high of 80 .24 in of rain yesterday some places close by still raining
Wifes eye looks better this morning
Prayers for all silent or spoken our Country
Dftodd the tooth experience sounds like a nightmare. Have fun in Florida
   / Good morning!!!! #177,047
68 outside this AM. Heading to lower 80's. 86% humidity.
No rain these last few days. Got real close one day, could smell it in the air. No joy.
We started putting hay out for the horses, 20 acres of pastures ...poof...nothing to eat. Have another 10 that's been set aside for next year, but the grasses in there are burned out too. Thinking about buying more hay to get into next year. Have about 200 bales but the math does not add up.
Most all of the farmers around me have lost their crops.
Still no word from plumber. Looks like I will need to start calling around again. Maybe time to get a rental ditch witch and lay the grinder pump and tie in myself. Then find someone to bust concrete for a few days. LOL. Any volunteers in the GM crew?
Hope all have a great day. Be safe.
   / Good morning!!!! #177,048
Good morning, 64 going to 79 no rain
Did some minor maintenance on the excavator. Cleaned the fuel/water separator by taking off the glass bowl and cleaning it up. Careful to put the red float back in. Drained a little off the fuel tank to check for water. None found. Took out the AC cabin filters and blew them clean with 30 psi air. Removed the air filter outer and cleaned as well with 30 psi by blowing from inside the filter.
Dug out some dirt around the pond and brought it up to fill in an area where boulders had been removed.
Had a talk with neighbor who is waiting for installation of a 10,000 lbs lift. He is having it installed and delivered by a local company
   / Good morning!!!! #177,049
63F thick fog 70F for high rain arriving around 11am.
Outside chores done E muffin time. :)
Plans for today...AM couple hours trimming,PM not sure yet since rain will cancel puttering outside.
Enjoy your day all.
   / Good morning!!!! #177,050
65 and thick fog...going to 82. Low humidity around the corner.
Congrats on winning that trip, Dftodd. Hope you have great weather.
Buppies, glad your wife is better.
Ron, I love today's pic. Seems that insects don't get as much attention by people, but quite interesting creatures.
Wife caught a small black snake in the house yesterday. She handled it like a pro.
I managed to get 3 more food plots tilled and planted, as well as an hour of mowing, just before the rain hit. Got the right amount after planting...1/4 inch.
I've morphed into a 1940's music fan...can't get enough. Surprising since I've always listened to Reggae, Bluegrass, Cumbia and Classical, like Dvorak.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
New/Unused Spirit Electric Bicycle (A57453)
New/Unused Spirit...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
