Good morning!!!!
   / Good morning!!!! #176,191
Good Afternoon,
PopG, yes you can get a good boiler for 5 K, but then there is all the labor to disassemble the old one and remove it in sections. Your probably talking a 5 section boiler, so that’s a job in itself ! Boilers last a long time, so that means some piping may need to be replaced! It’s not to hard to come up with 5 to 10 thousand in labor charges on a big project like that !
I only answered the question of what a boiler costs. Wasn’t suggesting that installation would be cheap. Last boiler that I removed weighed in at 800lbs at the scrap yard. No way it was an inexpensive install.
   / Good morning!!!! #176,192
Looking at the photos, I might have to be satisfied by drilling two more holes in the center where there are no obstructions behind the step...
Or maybe low profile rivnut?
   / Good morning!!!! #176,193
Ordered a new tire inflator, that comes in tomorrow and will hook it
up to my compressor and top off the tire.
Needed a better solution to take with me on trips so also ordered the Makita cordless air inflator. Compact and hopefully powerful, takes up least amount of room
I took one of those Makita pumps along with me when I picked up the new-to-me trailer, Drew. It had been sitting a l-o-n-g time, and none of the tires registered more than 20 PSI. I didn't measure the time it took to get each one up to 40PSI, but it was in in the 3-5 minute range. There's no lock down on the trigger, so it was a bit of a PITA hunching down on the ground to hold down the trigger. It's a lot better than nothing, but there are probably options out there that are better suited to automotive applications. I wouldn't buy one again.
   / Good morning!!!! #176,194
Morning all, 70 going up to 79 and cloudy, calling for rain tonight.
Did some drywall patching last night to finally close the ceiling where the pipes were fixed. Still need to sand and coat again, then paint. Been a while since I did this, looks fine so far.
Another high school friend passed this week. Died in his sleep.
Be well,
Sorry about your friend.
On the hwy I travel to work, there is an intersection where one highway has a blinking yellow light and the crossing highway has a stop sign with blinking red lights. Tragically, an 18 wheeler loser, just blasted thru the stop sign and killed a young 24 year old woman, a couple mornings ago. Hope they tested him for drugs, and his travel logs for proper rest. It happened at about 6 15 in the morning. I came by at 7:20 Senseless.
Sony WH-1000XM4
Had a pair of these for years. Use them daily. Still like them and recommend them. Turns my crumpled steelskin into a Cadillac soundwise. They really only blocks road noise, voices, radio and sirens are just barely muted and usually easily heard. We had bought them hoping our autistic daughter would use them. She wouldn't. But now she watches things on her cell phone with some wired ear buds, which insulates her from her environment really good.
I need something for underneath the motorhome. In the event of a tornado alert while in a campground.
I've ordered some heavy duty straps and earth augers
Now I need the mounts on the vehicle
being a gas vehicle I'd prefer avoiding welding under there so
drilling the frame for a bolt is preferred.
I wonder if a magnetic drill would make this easy.
They are often too big to fit
I use a cordless impact drill to drive in the earth augers.
before I drill anything need to look under there and see if there are
any existing openings that could be used.
This is mostly to keep it from moving or tipping over.
Wind pressure is given by the equation P = 0.00256 x V2, where V is the speed of the wind in miles per hour (mph). The unit for wind pressure is pounds per square foot (psf). For example, if the wind speed is 70 mph, the wind pressure is 0.00256 x 702 = 12.5 psf.
So, if rv is 8' x 14' it would equal 1400 lbs of force. But this is a googled answer, and I'm not an engineer. So it is only worth the money you paid for it. There is much more to consider which are the vectors of force applied to your straps/anchors holding things down. Easier to pull out straight up vs pull from the side (shear) :)
Yes I can still dump. I do not use it. But wanted to have access to transmission and it’s controls.
Maybe you might have some passengers you need to dump??? :)
Took the day off and made it a date day with the wife. Then watched the sun go down.
Hope all had a productive day.
Good evening...all.
Date days are fun. Nice pic.
Very busy at work, finally got an older cnc mill working with a 5 axis trunnion. Had to revamp an old post processor to work with the 2007 machine. Switching the trunnion from x axis alignment to y axis alignment takes a lot of edits to the post....and trial and error to the cam program.
Prayers for our team.
   / Good morning!!!! #176,195
I wish I had a Mcmaster Carr near me, and that they would offer a "will call" order system. Like curb service with orders...fast!
TxDon, I hope you are doing alright. It seems hospice is fairing well. I am interested in your upcoming estate sale. Will it be an auction? Or just come and buy like a garage sale?
   / Good morning!!!! #176,196
I wonder what will happen if they converge? Remember playing the spinner game, with the dished concavity arena? or playing with tops? One of the plastic spinners in the game was named "Tricky Nicky"
   / Good morning!!!! #176,197
Good evening all. 69ºF for the start, clear sky, light breeze. Light wind, partly cloudy sky, and high temp was 95ºF. Men's meeting to start day, then putter until wife woke up from nap. Did get tree watered, irrigation guy called, areas not watering correctly, Got back on handyman waiting list. Opened new screen closure for gold door, hope to install that tomorrow. Friend came over with bike he is trying to ride, talked about how to adjust to fit him better. Did get nap in, Mexican for dinner tonight.
Ron glad coffee is good. Hope to see pic of jump seat soon :) Nice pic
Drew hope you are drying out some. Hope you can fix RV tire leak. Hope PT went well. Have fun kite flying on the beach.
Buppies sorry pond not up. Hope you get back to work. prayers sent.
Drew never heard the term before. To each his own. I did my share of tent camping in 90ºF+ temps and sun burned on top of the temps. I don't plan on RVing it anytime soon so maybe I have you beat :).
Billy glad you got rain, sorry it messed with your sleep. Hope you are getting close to done on windows. Hope new coffee good.
Mike I don't know of anything under light drizzle, maybe Paul or Buppies do.
Don hope the cooler weather is helping get the estate sale ready.
Frits sorry no rain, hope wife's infusions went smoothly
Thomas hope morning work was productive, and puttering went well.
Kilroy glad you have plenty to do.
Sea2Summit welcome to GM thread. Hope you are not in flooding path
Ken glad you got some mowing in. That price sounds like "I don't want to sell you one" price. Enjoy the figs.
Dennis I thought I was doing good at 100K miles on Saturn SL.
Dennis glad more rain, sorry it woke you up.
RNG sorry about the smoke from the fires. Hope you can find a satisfactory answer to using other 4 holes. Glad all your deliveries came in.
RNG crazy link on FB.
Ted sorry you missed out on rain, no rain in 10 day here either :( Hope you got started on drip line.
Drew good luck working out strapping system for RV.
David hope Sophie's flight not delayed.
RNG anchors look substantial.
RS hope you find the parasite draw, we had a problem with the light in the sun visor for mirror. Hope prepping for sale went well.
Ron nice jump seat, thanks for pic.
Dennis glad life is good.
Mouse welcome to GM thread. where about do you live?
Ken sorry about the wife issues. Hope the mini split finishes coming in.
Drew tornadoes go north and/or east. You can see direction of movement of thunderstorms on radar on phone. Not sure what is wold take to get 2,000 lbs holding on ground anchor. Hope inflator works for you
Randy(wag) hope the foot appointment went well.
Thomas glad day went well.
Mike that is the spirit. nice sunset and pic
RNG thanks for inflator review.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /sleeping, /wife healing, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, Lou /eye issues, /heart issues, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /land development, /favorable winds not in the forecast there "alligallyitus" and back in hospital, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, mike /wife's healing from surgery, Scotty /back pain, Helogabals /second opinion, /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
   / Good morning!!!! #176,198
64 high in low 80s no effects from hurricane no rain in forecast blah blah.
Sorry about truck driver accident Kyle, do not know answer Kyle. Sugar level out of control working to find solution
Prayers for all our Country people dealing with devastation in hurricanes path long road for many
Prayers for all our country people suffering who need help
   / Good morning!!!! #176,199
Drinking hot coffee. 43° with clear skies this morning. Heading to 73° with sunny skies. Mule Jump seat project is done. Grocery shopping this morning. Then clean up shop and barn from seat project.
Stayed up late and got a picture of Super Blue Moon.
Super because Moon is close to Earth.
Blue Moon because it is Second Full Moon in one month.
Everyone stay well and safe.
Good Morning All.
   / Good morning!!!! #176,200
good morning all
up way too early
going to be a lovely day, high in upper 70's
but the forecast....five days in the 90's coming up.
Indian summer for real.
hope my niece in Charleston is ok, she says her house sits up a little but hope she wasn't planning on going anywhere
today. I assume they shut the schools down.
RNG, that's a disappointing review, will let you know how it does pumping up my 80 psi tire. Says it goes to 150.
my alternative is hogging up an entire storage compartment for a "real" air compressor and I don't have the room.
I have a beautiful small Makita 2hp compressor at home, I eyeballed it to see if I wanted to take it along, since I have an exterior
110 outlet near the rear tires. just too big.
Ron, awesome pic, have been waiting for it
JOHN DEERE 9 SHANK CHISEL PLOW (A52708)
JOHN DEERE 9 SHANK...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
Honda EM 6500 SX Generator (A55973)
Honda EM 6500 SX...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
FRONT MOUNT TANK (A52708)
FRONT MOUNT TANK...
