Good morning!!!!
   / Good morning!!!! #34,961
Fog and 59 this Morning sounds like a little cloudy Today with a high of 74 and Humid.
   / Good morning!!!! #34,962
Good morning, 70F heading to 79F with thunderstorms in the forcast. Heading out to my grandson's 15th birthday party after work.
   / Good morning!!!! #34,963
80 going to 90 and sticky.
Been away traveling and hiking mountains, rain forests, and beaches in Washington state and Oregon with one of my sons. Beautiful state. There really is a coffee shop or espresso kiosk everywhere you look. Saw the Mariners and Yankees play. Had a great time.
Glad to be home. I've got some catching up to do.
   / Good morning!!!! #34,964
Glad you enjoyed the trip lots of things to see around here!!! :)
   / Good morning!!!! #34,965
Already above 80 this morning and headed to 90 today. It's going to be another hot one. Rain mostly missed us yesterday. I say mostly it tried to wet the deck. Back to hauling hay today hope to finish it today only have 6 or 7 more loads. Then mow the chicken coops.
   / Good morning!!!! #34,966
74F and partly cloudy ... scattered thunderstorms around the area.
The 'Cake and I are going in to mow and clean up the commercial property today ... will be more fun than a barrel of monkeys I'm sure ...
   / Good morning!!!!
Raining most of the morning. Going out for coffee in a bit, then I will work in the shop, cleaning it up, organizing the chaos there.
   / Good morning!!!! #34,969
74F here now. Forecast calls for abundant sunshine. High around 95F. Winds S at 10 to 15 mph. Still quite warm, but ten degrees less than Friday.
RS, the local manufacturer (PBM) uses ShurFlo and FloJet pumps. Never heard of either one, but then I've very little experience with this stuff. I plan on taking the old pump/motor down to them on Monday to see if they have anything close that could be made to work. The pump has never given problems, nor the motor up till now, and both are about four years old. I'd have a go at fixing the motor, but the end cap is crimped on and not made to be serviced. If I can't find a replacement pump/motor, it's new sprayer time, as the yellow star thistle is starting to bloom. If given the chance to go to seed, I'll lose even more ground to it next year.
I believe the thistle came in with contaminated seed. I had a neighbor doze about eight acres down to the dirt in '11, then seeded with a barley/rye/red clover mix that fall. About half the seed came up in that dry winter, but no thistle. Next fall I put out another batch (about 800 lbs. each time) and got more coverage, but still no thistle. The next fall I put out a few more bags in the thin areas and had thistle galore that winter and spring. Seems to me if there was thistle seed in the ground already it would have come up those first two winters. And since there's no livestock on the place and the neighbor's sheep and goats keep their ground eaten down to the dirt, there's not much chance it blew in from there.
The onset of hot weather has caused several problems here, the sprayer pump is just one. All have been with electronics of one sort or another. Bad Chinese capacitors? Faulty solder joints? Got me. I take it apart looking for places the smoke might be leaking, find nothing, then blow out the dust as a final hail Mary. Then it's into the recycle pile and off to town or Craig's List for a replacement. Right now I'm shopping for a new-old stereo receiver to replace the dead one in the garage. It keeps flashing "component overload", even with nothing connected.
Drew, did you get to hear any of that iron running? Years ago I was passing through a small Midwestern town and stopped for dinner. There was a car show going on outside on the downtown streets, so my buddy and I walked around after we ate. There was The Little Red Wagon, a hot rod I built a model of back in the '60s. And while we were watching, the owner started it up and did a burn out right there in the street! Took a few minutes for the smoke to clear, and the roar of applause and whistles was almost as loud as the car.
You're supposed to clean mower decks? My dad always made me do it, but since I've been on my own I've never bothered. Bought a Craftsman push mower new twenty years ago and it still works fine. There is some grass stuck to the deck, but not enough to restrict the catcher bag or blade rotation. What am I missing (besides a mess cleaning it every time I use it)?
Got a start on bike number two of the light swap yesterday by removing the HID lamps, then pulling the ballasts and mounting bracket. First had to remove five relays from the bracket. That's all located up under the fuel tank, to it's close quarters and everything's packed so tightly on the mounting bracket it looks like an explosion in a spaghetti factory. Got the other ballasts on and all the relays back in place, less one that let the two driving lights operate independently. I never used that feature and find it good enough to just slave them to the high beam. Anyway, got it all back together, cleaned and lubed all the grounds and relay pins, hooked up the new lamps and everything worked. Big relief, and since by then it was dinner time I thought I'd quit while I was ahead. Surprisingly the temps never got above 85F in the closed up garage, even though it was 100F outside. Kept the doors shut and just ran a box fan for some breeze. Of course the little siesta I took around 3PM didn't hurt anything either :laughing: Today I'll cut the old lamp brackets off the crash bars and weld longer ones on for the new lights. A little paint will finish up the day, leaving final assembly for tomorrow.
Hope everyone enjoys the rest of this fine summer weekend!
   / Good morning!!!! #34,970
69°F and .11 inches rain last 24 hours.
Got a good start on mowing yesterday, likely finish today.
Gonna slow cook a nice rib roast on the rotisserie and then share with friends this afternoon.
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #34,971
Good Morning. 1150, sunny, 90F {100F heat index} with 57% humidity. Forecast high of 92F with 20% chance of showers today, and a low of 72F tonight. We got out and picked the garden before work, and it was already hot at 0745. Days like today make me thankful I work indoors. Speaking of work, I have a family reunion and a beauty pageant today. I like one of those events much more than the other.
The plan was to watch racing in the afternoon and round ball tonight. But looking at Brooklyn, Michigan (49230) Conditions & Forecast | Weather Underground the racing might be as late as the hoops. At least they have lights at MIS.
Hope everyone is having a good Sunday,
Larro
   / Good morning!!!! #34,972
Here in Florida you have to start early, when the grass is still wet with dew, or you just can't stand the heat. The dust and wet grass sticks, then dries out to make adobe bricks under the mower. A small push mower can pick up 5-10 pounds in a couple of hours cutting, while a 6' RFM can easily pick up 25-50 pounds. If you don't clean it after each use you will soon be getting out the pressure washer just to make room for the blades to turn. I'm no aerodynamics expert, but I'm guessing the mower deck is designed for optimal discharge without most of that extra room under there taken up with mud/grass.
   / Good morning!!!! #34,973
Good afternoon here from North central Arkansas...82ー with scattered storms.
   / Good morning!!!! #34,974
I don't mow with dew, it doesn't get that hot here. I did try to mow through a sprinkle recently that turned into rain, that never helps.
I think what RNG may be missing is juicy green grass week after week?
   / Good morning!!!! #34,975
We drove on the beach at Long Beach. Awesome wide beach.
Yes we love it wish I would have known when you were here would have bought you ice cream at Scoopers!!
   / Good morning!!!! #34,976
It was a work day so up at 5, I am starting to hate working Sunday's! Home at 3:30 then 2 1/2 hrs of seat time cutting the grass before the predicted range the next few days.
Just having a cup of coffee and relaxing on TBN before thinking of hitting the hay to start all over tomorrow.
Sent from my iPad using TractorByNet
   / Good morning!!!! #34,977
2015-06-15, 0324
62 and rain right now...looks like 60 and rain most of the day.
I did get all the mowing and trimming done yesterday. Downside is the battery in my zero-turn won't take a charge. I can jump it though...looks like a battery coming soon (this week)
   / Good morning!!!! #34,978
Predictions are for a dry week ahead. My wife has a good book ready to test the new patio furniture if the delivery truck arrives as promised. She may need to wrap up to keep warm as it is only going to reach 14C/57F by noon.
RS, the local manufacturer (PBM)[/URL] uses ShurFlo and FloJet pumps. Never heard of either one, but then I've very little experience with this stuff. I plan on taking the old pump/motor down to them on Monday to see if they have anything close that could be made to work. The pump has never given problems, nor the motor up till now, and both are about four years old. I'd have a go at fixing the motor, but the end cap is crimped on and not made to be serviced. If I can't find a replacement pump/motor, it's new sprayer time, as the yellow star thistle is starting to bloom. If given the chance to go to seed, I'll lose even more ground to it next year.
Most of the small sprayers I have seen have Shurflo pumps in them. They make a lot of low cost pumps that seem to be fair value for money for light use.
   / Good morning!!!! #34,979
67 now and we are suppose to hit 100 today. We seem to be running 15 degrees hotter this year than average, wouldn't be as bad if we had normal rainfall, but that is WAY below average. I see us being in a drought by July. Off to work today, meeting my tile setter and carpet installer.
   / Good morning!!!! #34,980
Drinking first cup of coffee. 65° with partly cloudy skies this morning. Heading to 80° with more thunderstorms thought out the day. Rain all day yesterday. 1" of rain.
Need to cut lawn today. It will be wet. Seems I cut lawn about 75% of the time when it is wet. Never clean under the deck. My 3 mowers are over 10 years old.
DABGST, I sure do not miss those 7 day weeks since I retired. Always seemed like they lasted months.
Good Morning All.
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Electric Golf Cart (A56859)
Electric Golf Cart...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
