rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,229
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
RNG,RS, your wood pictures have me wondering: What happens when the length of a round falls mid way between what works best in your stove? Do you buck one side to best length and leave the other side short, and if so, what do you do with the short? Or do you split it down the middle?
We have three stoves here - the WBF and a wood-burning fireplace insert in the basement here at the house, and the double barrel stove up in the shop. And of course, the "ideal" length for each is slightly different
Usually what I do is cut for the WBF - 22" is about right - so mostly it's one side to the ideal length and the other side short. Sometimes I will just split it in the middle, as the woman prefers handling smaller pieces ... easier for her.
Loading the fireplace insert front to back, rather than crossways, means shorter pieces ... maybe 16" at most. The double barrel stove in the shop can take a 28" length no problem.
It might this winter, if we have to heat again with wood. I actually need to come up with a way to handle the wood for the house with the tractor ... pallets are looking pretty good at this point, but I have to round some up. Usually can find plenty of free ones on Craig's List. Part of the issue will be the limited lift capacity of my loader.I ask because I use pallets to stack my wood, and short lengths waste space on the pallets. Maybe that doesn't matter to you?
The wood pile for the shop, which is masonry block, gets built on the east side of the building, partially under the overhang, on the driveway. No need to do anything fancy with that ... just stack it ... it's easy enough to get to.
The wood supply for the house is another issue however. I guess the plan at this point is to palletize the wood after it's split, then move it down to the house in late summer/early fall with the tractor and stack it outside under the deck by the back sliding glass door (it's a walk-in basement)
I'm not sure that even with packing that area, it will be enough to last the entire winter ... might have to use the "unused" half of the garage.
Yup ... built it last winter ... weighs around 1150 - 1200 lbs. ...Also, that looks like a serious counterweight on the back of your tractor. Homemade?
I have to manually give it an "assist" when I pick it up with the 3PH, otherwise the 3PH won't lift it ... need to add another shim to the PRV on the 3PH.
I've been real lucky ... haven't stuck too many so far ... but like you say, the pine that I've been splitting tends to tear across the grain. Maple and ash, not so much ... they usually just pop ... haven't tried any of the sycamore yet.And finally, I don't know about sycamore, but the oak around here splits much more easily when it's dry. And the dryer the better. When it's wet, the wedge acts more like a knife and tends to cut across the grain instead of wedging it apart. That takes a lot more force and it's easy to get the wedge stuck if I'm not paying attention.
It will be interesting to see how it goes with those two huge red oaks I still got to go cut up and split
