Good morning!!!!
   / Good morning!!!! #152,771
.37” of rain, better than nothing, but no need for flood warnings.
   / Good morning!!!! #152,772
We've been having some regular trouble with our ADT alarm system. It keeps giving an error to "Check Longrange Radio", which is its internal cell phone.
I got notices from ADT that they'd have to replace the cellular modem in my system, as the carriers were no longer supporting 3G. I used that, the ever increasing monthly fee, and their refusal to upgrade the system to something comparable to what they give away free to new customers, as an excuse to shop for a replacement. I ended up with a system from Abode, which I installed myself. It was easy to install, integrates with First Alert smoke detectors, and has live people to provide both tech support and 24x7x365 monitoring. But the real kicker for me is that it integrates seamlessly with Apple's Home app on my phone, so I have just one place to look when I want to see what's going on. Cost of the hardware was a bit less than ADT, and I was even able to lay down some conditions that had to be met before local law enforcement was called out for an alarm. There is a fee for monitoring, but it's only $110/year. The ADT plan was $480/year, and that didn't include any video camera monitoring. I wouldn't want to be a holder of ADT stock in this environment...
   / Good morning!!!! #152,773
plumbing place handed me a water sample bottle and said go get water tested at a lab in Lancaster. Ok.
I'm sure they will find the water is hard and of course recommend more hardware than I want.
my plans for today have changed and might wash the car. Lot of summer bugs.
Never could get my Ring doorbell to work. Because I couldn't install app on phone versus my pc. Couldn't get it to come
up on pc. Another wasted bit of electronic junk.
And now my fancy all lithium jump starter air compressor do all won't turn on. Says 100 percent battery charge.
Giving it to a younger friend to diagnose. He already has two so doesn't want another. I went back to the old fashioned lead acid type.
maybe some kind of resettable fuse on new one. Even light doesn't come on ,yet battery says full.
Uh, no one home in there?
   / Good morning!!!! #152,774
Good morning to all! Low was again at 60°, but the high is going up to 87°. Slight chance of a T-storm. Not a drop in 10 days now, even with storms passing close by......
Scaredy, extra prayers sent your way. Hope everything gets straightened out.
Doug, sorry to here that Leslie is still having mask problems and the daily trips are adding up.... hope they find a solution quickly.
Buppies, enjoy the new beach tent! ....and the time with the Mrs.
Thomas, go easy on the Doc / nurse.... they are only looking out for you.
Mostly, have a happy birthday, you won't win that battle....
Don, those temps are way too hot! Apparently, some of that heat is leaking out to here.....
RNG, have a safe trip, keep the rubber side down. Hope you get to see a launch!
Time to go take the string trimmer for a walk. Probably more multiple short walks with many breaks. I may just take small bites at a time. I don't want to over do it in the heat.
Need to figure out when to run some errands..... getting a bit low on some grocery staples. Might get them done first....
Everyone have a great day!
   / Good morning!!!! #152,775
Drew, The rust free vehicles are from Cal., Nevada, Arizona, Utah, and NM.
I am not kidding, I have pieces of scrap metal sitting outside for years without any rust more than some rust dust on the surface.
My son picked up an early 70's Jeep pickup cab that was sitting outside for years in Arizona. Totally wide open, just the shell.... not one spot of rust! Only faded original paint.
   / Good morning!!!! #152,776
You can install cameras now that you can talk through as well as monitor yourself with alerts set to come up on your phone when you arm the system. Plus free cloud storage up to a certain amount.
I purchased and installed some at my sons home when he was going through a heated custody battle with his baby momma..
He was able to show up to court with some pretty damning footage to help his case.
   / Good morning!!!! #152,777
and so it begins, giving away the squash.
golden egg squash
   / Good morning!!!! #152,778
67°F and no rain.
Need to scrounge around for a hose bibb. Pretty sure I have one without having to go to town. The bad one is one that has the vacuum feature, leaks terribly.
Should start spending time with mower.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #152,779
80F and partly cloudy @ 12:15, heading up to a high of around 85F for the day. It sure looks pretty sunny out there to me.
Up late, so late start.
Woman reports She is seeing results on Japanese Beetles with the stuff She has sprayed with the neem oil solution. This is after I had to prod Her a bit: She kept saying "I don't think that stuff is doing anything" or "I don't think it is working"
To which I usually replied: "Well, you do have to actually spray it on the plants ..."
... so She finally started spraying it.
She also reports that the Orienpet lily blooms are still there and that She saw the groundhog out back this morning during her rounds.
Agenda items for the day:
Refill hopper and one suet feeder first thing.
Lawn is overdue for mowing, so that's on the list for today. Probably do down here around garden first then mix up some glyphosate and spray the area to be enlarged for the garden to kill off the grass and weeds. Then mow the rest of the lawn.
After that I'll work on getting those two larger cages for the tomato plants built, which mostly just involves bending and folding the ends to lock them together.
If I get that done, the largest tomato plant out back will its cage replaced with a larger one, which will free up the smaller cage around it now to use on another pepper plant.
If there's still time left I'll go up and get another dump cart load of screened soil and fill in the area at the end of the garden bed and maybe get another tomato plant planted.
Best Birthday Wishes to MG !
Hope everyone has an enjoyable, productive, and safe day ... (y)
   / Good morning!!!! #152,780
Good Morning All,
Happy Birthday Mostly
BEF - good tent, Canadian Tire maybe ?
riptides - it's a maintenance day here also.
I have an open day today - still trying to unclog the tenants kitchen sink piping upstairs. 10 days ago started with plunger, drano, drain snake, a friend then replaced the piping under the sink for me (and put his back out), now I borrowed a powered drum drain auger and will attack from kitchen, and then perhaps from the lower end in our furnace room. it will probably be dog hair, and sand (from sink washes), grease and food particles. Failing this effort with the powered machine, I will need to call in my plumber ($$$) ... we've been here 21 yrs, these tenants have had multiple maintenance calls to me in the past 2 yrs (ignoring my directions). I can't blame them entirely as sometimes things just happen. I hope today's effort will work. I'm getting tired of charity rent. I think my morning coffee needs kahlua ... psyching myself up first. :) Wish me well. This is not my idea of fun.
RNG - is your neighbour jerk a city-boy ? All the best. Safe travels. I love Monterey Bay, have been to that area and the Aquarium probably 4-5 times. Numerous trips to California between '85 - '95 ... yes, some motivation to see a certain gal, and some other friends.
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
378789 (A51573)
378789 (A51573)
John Deere 6120E (A50323)
John Deere 6120E...
