Good morning!!!!
   / Good morning!!!! #131,381
No power last night thru this afternoon no more rain till Wednesday, tree took out lines down the road
Yes Drew very nice got over $10000 off when we got it now very hard to come by very nice 25mpg with six cylinder
prayers for all Mostly wife our Country
   / Good morning!!!! #131,382
2021-04-11, 0954
58 right now...high in the mid-60's today...
Got the EGO chainsaw's trigger functioning better, but not 100%. There was some crap in there, but the real problem is a sticking switch. The trigger pushes a spring loaded plunger and that plunger isn't always returning to the full extension which results with the sticking trigger.
The switch is hardwired, so I'll take the saw to Home Depot (an EGO repair facility) for a repair...
But, it did work well enough yesterday for trimming some branches. I used the chainsaw and the pole saw. Didn't drop any trees though...might not have to after trimming but we'll see after the leaves appear.
As I was hooking up the chipper's PTO driveshaft, I found it's a little too long...maybe an inch or so. The driveshaft fit the 4520 OK, so it appears the 4052's draft links are a little shorter. I could probably get it on, but that would be pretty risky since the distance between the tractor's stub and the chipper's stub is a little shorter as the chipper is raised. If you have a PTO driven implement, you know what I mean.
SO, I'll take the drive shaft to my local dealer to shorten it by about 2 inches. One reason I want the dealer to do the job is I want both yokes replaced as well. These yokes are the type take require me to retract them so they'll slide on the stub. I despise this type of set up...a real PITA to retract the ring while pushing the yoke on to the splines. Making things worse is I just don't have much strength in my right hand (result of the stroke many years ago...). I use more foul language when hooking the chipper up then any other implement...and as an ex-Navy guy, I sure know how to use foul language!!
If the dealer can get them, I want the old push-pin type of yokes, but I'll settle for the type the has a ring you rotate. Either would be better then what I have now.
So, a semi-successful day...
One nice thing...although it was in the mid-70's, the tractor's cab got pretty warm with all that glass. So, tried the AC and that was quite nice. Since the only implements I use during the warmer weather are the chipper and flail mower, I don't think the power drain (when using the AC) will will be too bad. Obviously, I won't need AC when chipping but will when mowing the field
My stepdaughter want to rake the flower bed out front....asked me where the rake was (in the garage, dear). After she asked, I thought the only rake in the garage was an ancient fire rake that my father had when he worked for the Maryland Dept. of Forests and Parks. Thing's got to be at least 60-70 years old. Anyway, I went to the smaller shed to grab a regular springy type rake I knew I'd put in there last fall (after raking leaves). I found another one in there left by the previous owners of our house. This one has a curved handle so one doesn't have to lean forward as much when using it...never saw one like this before, but it sure is comfortable to use
I watched "Hacksaw Ridge" last night....for those of you not aware, this is a biographical movie about Desmond Doss...the only conscientious objector to be awarded the Congressional Medal of Honor
Good flick and I'll watch it again sometime, but my favorite WW II movie is still "12 O'clock High" (made just after WW II)
As far as today, I think I'll get the zero-turn out of the garage...probably have to give the battery a charge first though...then tow the lawn roller and aerator both out of the larger shed
I guess that's enough typing today...
Hacksaw ridge was good.
   / Good morning!!!! #131,383
It was light rain when we left for service this morning, got .6” overnight. Then turned into an absolutely gorgeous sunny day for our little date out alone (anniversary dinner a week late), already posted about the great place we ate.
Then took a drive thru pine grove furnace state park, the place I got GBS almost 2 yrs ago.
One of the restored iron furnaces and 2 old timers. This is the halfway point of the Appalachian Trail.
Then drive thru the Gettysburg battlefield before coming home.
Then mowed the yard. As soon as I finished it started getting dark, storms are rolling in.
   / Good morning!!!! #131,384
Good evening. 53 and it was never much warmer today.
spent all day outside yesterday. Hauled a load of free firewood and stacked it, mowed, did assorted yard clean up. We were tired last night. Made rigatoni for dinner.
Today was first race of the season in Ohio. We had a good day. We did almost nothing to the bike, kid was loose and riding well. He won both the Open Amateur and 450 Amateur classes convincingly.
Everyone stay safe out there
   / Good morning!!!! #131,385
Good evening all. 41 F for the start, clear, light breeze. Wind 14-19 mph early afternoon, clear, and high temp was 83F. Chapel to start, Pancakes for breakfast, bike ride today, may not get to ride tomorrow. Neighbor and fellow biker car would not start, took my old Schumacher to jump it and smoke came billowing out of the Schumacher :(. Truck got him going, going to need a need starter box :(
Covid update: Cooke, Montague, Grayson unchanged, local not updated.
RS hope you wanted the rain.
Bill never seen BP that low, glad it was caught. good luck with conveyor
Eric glad they found the warm spot, nice pics
Drew that was an ugly pic.
Thomas god to hear trees popping
Paul the coyote remained me of seeing then at the VIH airport. bet you are glad manure is done. Hope recording session went well
RNG neat pic of the tree cutting, nice score on the firewood, hope you can get the tank permitted soon and have it ready to catch rainwater.
Drew hope you have some indoor to-do's
Billy sorry about the hunting luck, glad the apple blossoms smell good, I could never smell mine
Bird understand your feelings on dishwasher, ours is not as good as yours, need to setup an hot water recirculate for the dishwasher.
Roy I really liked the Hacksaw ridge movie, amazing story. Have you seen Undefeated, about the WWII POW?
Kyle thanks for the prayers.
RS Hope your day goes well
Drew nice pics good catch on the Studebaker
Dennis nice to hear you have anew place nearby to replace the old favorite.
Buppies sorry no power, thanks for prayers
Dennis is that a cold blast furnace?
Rich good day racing, nice score on firewood
prayers for all, especially Jay/Peg, Kyle's daughter/sister & family Covid/friend's grand baby/son&wife Covid, David(moss)/remodel/divorce, Ron/hearing/son/aunt, Phil/reflux/wife's eyes, Dennis/older brother/son, Grev/wife's eye, Randy/family, Bill/DIL cancer, Ted/knee recovery, Doug and wife/health issues/nerve and pain/ wife's eyes, Ken/uncle and low blood O2, Drew/tendon, and Country.
stay safe and healthy you all.
   / Good morning!!!! #131,386
Sounds like a great time BEF
   / Good morning!!!! #131,387
Very tired. Trying to get caught up here.
have to get up at 5:15am.
Prayers for our team, especially Mostly's wife.
   / Good morning!!!! #131,388
2021-04-12, 0252
44° right now...high now, high in the mid-50's today...
Mostly_gas, no, I haven't seen "Undeafeated". Couldn't find a synopsis online...when was it made?
   / Good morning!!!! #131,389
49 high of 72 today pollen getting bad
Prayers for Mostly wife, our Country
prayers for all
   / Good morning!!!! #131,390
Good morning, apart from the cool temperature this is about as good as it gets for spring- little wind, no rain expected just patches of light fluffy cloud and birds singing away. First swallow of the year has arrived.
The hydrostatic transmission has a mode called Auto Throttle, which lets you operate it pretty much like a car. Push the go pedal down and it moves, push harder and it goes faster. As I tried to pick up the first trunk yesterday, the tractor wouldn't move, and the RPMs wouldn't rise above idle.
RNG, my Iseki has a similar "auto throttle" function (it is always operative - no off switch). It works well, however the user manual warms that if using other hydraulic functions such as the loader, then set a minimum of 1500 rpm with the handle throttle. Could it be something similar on yours ?
TANK MANIFOLD (A55745)
Mini Skid 48in Root Rake Grapple Attachment (A56436)
Mini Skid 48in...
Caterpillar Loader Quick Coupler (A56436)
Caterpillar Loader...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
