Good morning!!!!
   / Good morning!!!! #126,621
23F and partly cloudy @ 10:30 ... but I'm not seeing much sun at this point. Active Winter Weather Advisory for Stark County which is within spitting distance.
Plans for today include refilling feeders, finishing up that grocery order, fish room, further work on kitchen.
Woman concerned about getting groceries picked up before tomorrow due to storm ... :rolleyes:
Hope everyone has an enjoyable, productive, and safe day ... :thumbsup:
   / Good morning!!!! #126,622
Still feeling good after the close encounter of the covid kind during FireWise. Fingers crossed that I dodged another bullet.
Here's hoping that you did ... :thumbsup:
RS thanks for the interpretation.
You're quite welcome.
Did you click through to the Twitter thread and read it for yourself ?
I was also wondering if flattening the curve and prolonging the presence of the virus will contribute to give the virus more time to mutate.
Flattening the curve solves a problem (healthcare system overwhelmed) ... however it does not solve the problem (the virus and the sickness it causes)
Since initially, there was no realistic chance of solving the problem immediately (due to no available vaccine) we were left with what could be done to mitigate it and prevent the healthcare system from totally collapsing ("flatten the curve")
I'm guessing that we've dodged that bullet ... just barely ... at least for now.
The right virus mutation could alter that situation however.
Another take that is contrary to "vaccinate the world" is from Vaccine Information America's Frontline Doctors.
Yeah, well ... that collection of whack-a-doodles would not be on my go-to list of sources for hot takes on pandemic public health.
'America's Frontline Doctors' Continue to Misinform on COVID
Soon we will have as many opinions as new virus variants.
Not all opinions have equal validity.
In ten years the experts will be telling us what we did wrong.
It won't take that long ... it's already happening.
The biggest question is whether we will listen and hear what is being said.
BTW - on your thoughts regarding mandating of vaccines:
I'd be perfectly fine with no mandate on it ... provided that any person who doesn't want to take the vaccine voluntarily self-isolates, no exceptions ... until the entire population of the US has been given the opportunity to receive however many doses of the vaccine is required to be effective, followed by whatever period of time is required for it to become effective.
That means they stay home, out of public circulation.
Get caught violating your self-quarantine, and you get the needle in the arm. No exceptions.
As far as businesses mandating the vaccine goes, businesses have a responsibility to their customers not to infect them with what could be a deadly disease. Smart businesses will see that doing so is a good business move.
If you're an employee and work at place that requires that you do so and just don't want to take the vaccine (with no valid medical reason), then find somewhere else to work that aligns better with your philosophical outlook on life.
   / Good morning!!!! #126,623
I have Amal stuff that covers about every carb they built post WWII. Also have lots of experience making Amal痴 work on Bultacos when they are being abused.
I know all the advantages of Mikunis. But something I learned a long time ago is the efficiency of a Mikuni causes it to lean out during transition between jets. An Amal is the opposite, it is inefficient and it goes rich. When you are dealing with big bore Bul痴 used in anger, you have significant heat issues. The Amal can be tuned to use it痴 inefficiency to control heat, especially when chopping the throttle going into a turn.
Drilling the piston to allow fuel/oil onto the cylinder walls adjacent to the studs does wonders to eliminate seizing and cracking. Another old trick.
We use to drill the piston on our big McCulloch go cart engines and ran twin carbs on it to balance the lean issues under certain racing conditions.
   / Good morning!!!! #126,624
10 degrees in Bethel right now...dump run is done and got 5 gallons of diesel...
The 4052 has the filler on the left rear fender...about 4.5-5 feet off the ground. Since I don't have the upper body strength on my right side (since the stroke), it's going to be a bit more difficult to fill the tank. I guess I'm going to have to get either some type of pump or siphoning device so I can leave the container on the driveway surface. The previous tractor, a 4520, had the filler just forward of the cab window so I could rest the container on the hood while filling the tank.
Never calculated how much fuel I use in a year. Diesel is used in the tractor and the Gator. I'd be surprised if annual usage exceeds 100 gallons. Both the tractor and Gator are pretty frugal with fuel. Might be worthwhile considering an outside tank with a pump at some point. Since both my neighbors have tractors...maybe share fuel costs...
The snow is really frozen now and there's no need to actually fill the tractor's tank (still has 25%-35% fuel in it), I'm not going to do anything today...too **** cold!
   / Good morning!!!! #126,625
Good morning all, 20 going up to 32.
Oil burner man here this morning, had bad diesel fuel smell in basement. Turns out I was right and the guy before last put in the wrong nozzle and it was running rich.
Kid is playing on facebook live with school of rock band this morning so mirroring that to big TV right now.
Wngsprd - is Coco ok?
PopG-the Jeep has cams that break. Had to take apart whole dash to replace a $8 part. Have spares as this is a common issue on the Grand Cherokee's. took a few hours and had to buy a real small ratchet screwdriver to fit in there (found from others having same issue-youtube helps so much)
Randy-glad to hear you got your vaccine
Kyle- sending prayers for Waylon
Stay safe and be well
   / Good morning!!!! #126,626
Thats not gonna happen on so many accounts. Self isolate indefinitely because they refuse to take something that has worse symptoms then what most people experience from the virus itself.
I can guarantee you that my wife won't take another shot of the Moderna vaccine, ever again after the reaction she had to it.
She would be pretty gun shy to try a different vaccine with out lots of reports on it.
You don't need to self isolate. You need to follow the recommended precautions for avoiding the virus.
My wifes living proof of that after working with covid patients regularly for over a year and not getting infected.
I'm living proof of that as well, with traveling all over the country, dealing with loads of people and not getting infected
   / Good morning!!!! #126,627
64°F and 1.48 inches rain. Not looking good for getting on roof to finesse antenna alignment
Actually not promising for anything outside. Guess I’ll just take day as it comes
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #126,628
All this talk of Amal carbs, in a TRACTOR forum!:eek: Brings back fondish memories of my first big bike, a 750 Norton Commando Fastback. Ticklers and wet thumbs.
Then there was a black and silver Mk III 850 Interstate I put together with a hot cam and Amal Mk II carbs. It ran great and didn't leak because I found something called YamaBond to put it together with. Now a days it's called ThreeBond and I'm still using it. Somewhere up in the rafters there's a Henry Weinhard's box of carb stuff, and I'll bet it's mostly full of Amal pieces. And there's a little plastic drawer, maybe two, in one of those parts cabinet things that has jets and needles and circlips and other little Amal parts. I don't know why I kept 'em 'cause they were all replaced because they were worn out.
Then there are the Amal GP carbs on the Norton Production Racer that still sleeps in the great room. Those got disassembled and cleaned back in the '80s, and never saw fuel again. Most reliable Norton I ever had! It still reliably leaks oil.:laughing: That Fastback is the only motorcycle I regret letting get away from me. But not enough to go and get another one.:mur:
   / Good morning!!!! #126,629
I wouldn't want to predict that one way or another.
I'd venture to say that "most people" don't have reactions like your wife did.
And what "most people" experience isn't really the issue/problem anyways.
Understandable.
Yeah, well ... it appears we have a little compliance problem with that don't we ?
What's your solution for that ?
It sounds as though you and your wife aren't the problem.
That doesn't however mean that there aren't others who are actually a problem.
   / Good morning!!!! #126,630
Have you been doing anything more than self isolating, masks, social distancing, and hand sanitizer to keep from catching it?
Someone posted a link to a recent study that something like 30% of CV19 cases are asymptomatic. Have you two had antibody tests so you know you've never had it?
I'm asking these questions because I feel like I'm rolling the dice every time I go out among people. If there's something more I could be doing to improve the odds, I'd sure like to know about it!
(4) Aluminum 6 Lug Toyota Rims (A57454)
(4) Aluminum 6 Lug...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
Case Welcome Saw Sign (Orange) (A57454)
Case Welcome Saw...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
New/Unused Fuel Pump with 50ft of Hose (A57453)
New/Unused Fuel...
