Good morning!!!!
   / Good morning!!!! #116,851
Good Morning!!!! 77F @ 8:00AM. Sunny. High 102F. Winds SW at 5 to 10 mph.
Wow! You folks have been busy! Makes it hard to keep up with all that's going on, so this morning, I'm not even gonna try...
Got the oak decking back in the truck yesterday, but not before installing screws into the undersides to keep them from coming apart. There were staples there already, but they weren't holding. Also leaned I didn't get the hatch in the right spot, and ended up drilling and tapping a bunch of holes for the decking at the back. Still need to finish that up today, as it was just too hot at 1PM when I came in for lunch.
That led to setting up the new networking hardware, and what's called a Dream Machine Pro turned into a nightmare. No matter what I did, I couldn't get the setup program to run correctly, and spent hours on the 'net trying to find a solution. Still not clear what's going on, but it may involve updating the firmware, and using SSH at the command line to do it. It's been a while since I did much with UNIX, so I'm rusty, so more homework.
But I did get all the old networking stuff moved over to the new shelves, and other than a few Ethernet cables that are way too long, it's a lot easier to get to and keep track of. Biggest surprise of all came when everything worked with I turned the power back on.:cool2:
Decided to catch one of the lizards last night to start getting them used to being handled, and Tasty wasn't happy with that at all. Didn't want a worm, just wanted out, so I let her go. She hid under the bead blaster, keeping an eye on me, and wouldn't come for another worm for a half hour or so. I guess hunger eventually won out, but she wouldn't come onto my hand. Smart lizard...
About then my house hunting buddy called and asked about septic systems. He'd just returned from Klamath Falls, where he looked at a house with a faint septic smell near the concrete hatch leading to the settling tank. He was told there was a pump down there to move the liquid effluent to the leach field. But he was mostly worried about the smell. I told him it could be something as simple as a poorly fitting lid on the hatch, or something much worse. My advise was to get the name of a reliable and experienced septic person from his realtor, and have a talk with him. His bigger problem is that there are not many properties on the market right now, so prices are up a bit higher than perhaps they should be. He's patient, but doesn't have a lot of time to waste, especially going into winter when any repairs he needs to make will take longer or have to be put off until spring.
Gonna finish up with the truck today, and hopefully get some grading and gravel spreading done where it'll get parked. Then not sure what else the day will bring, but the temps tell me it'll be an inside activity.
Hope everyone enjoys the rest of the weekend.
   / Good morning!!!! #116,852
RNG
ssh user@ip
User is usually admin or root
If it needs Password it will ask.
Use default ip that the device says it uses.
Make sure the computer network you are using to connect to it is also on that same network.
Ssh will give you a command prompt to do whatever commands you need to run.
   / Good morning!!!! #116,853
my friend in Delaware asked me if I "felt it". No...but might have thought it was wind while raining...
said it was at 8am this morning and near NC/VA line, strongest in NC since 1916
looks like farm equipment dealers are doing ok, just like rv's and boats
Equipment Industry COVID-19 Update - August 2;) - YouTube
   / Good morning!!!! #116,854
71°F and .05 inches rain.
Time think about starting another round of mowing. Depends if ground is dry enough. Not looking too promising at this point. Looks like I’ll be enjoying rain with the morning coffee.
Flexibility
Anniversary today of sorts. 15 years ago today we moved here from GA.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #116,855
82F and sunny @ 12:30, high headed up to around 88F. 10% chance of precipitation.
The Woman just headed out to grocery store, asked her to report whether there were any more birds in trap on way after mentioning that the two in there yesterday were juvenile bluebirds. She was astonished (I'm not sure why ... after all, it is a bird trap ... :laughing:) wanted to know if I had rebaited it (no) ... anyways the report is that the trap is currently empty. Might relocate the trap down closer to the house and rebait it today, since there seems to be quite a bit of activity down here. Bird feeders need filled again.
Not sure what all I'll get into today ... the powered insecticide seems to have worked on the Yellowjackets that were nesting in the back garage wall ... no more activity there ... so I might start caulking up any holes in the underlayment before I put the siding back on that was removed to extract the honeybees.
Finish greasing mower (pto shaft) and maybe get the loader and box blade taken off and it put on, maybe see if I can get auger stand finished up (shade job)
Also might run down to Menards and pick that order up.
The Squeak is looking very stylish ... if not entirely happy:
She was actually pretty tolerant of me putting it on her last night ... although that might have been because she had just had some catnip.
I took her into the living room and showed The Woman and she about had a fit ... insisted on removing the harness immediately ... "It's too tight" (it wasn't) ... I'm not sure which one provided more entertainment ... :laughing:
Hope everyone has an enjoyable, productive, and safe day ... :thumbsup:
   / Good morning!!!! #116,856
So the older bush is 1.5 years old, and it did not produce much of anything this spring. The bush we planted earlier this year, was full of blooms and young berries, and we harvested 2 or 3 nice bowls full from it.
As others have mentioned, they like acidic soil ... so peat moss or sulphur as a soil amendment. Dunno what your soil is like there, but here it's very alkaline ... might want to grab a moisture/light/pH meter just to check it:
Search Results for soil ph meter at The Home Depot
This what I found at the Depot for sulphur:
https://www.homedepot.com/p/Espoma-6-lb-Organic-Soil-Acidifier-100508616/203192757
We planted a small peach tree on the west side of them, if it will grow, it would provide shade in the evenings.
:thumbsup:
   / Good morning!!!! #116,857
Good morning all. Not quite death threats, but I didn't want to risk the "or else" looks the sheep were giving me yesterday, so I opened the gate. It was a near stampede when I let them into another field today.View attachment 665366 View attachment 665365Ken, you have the right attitude to scary trees, keep taking extra care while clearing up the damage. Here is a thought for those that like to ponder over things that don't matter - the earths gravity gets weaker every day, so trees don't crash down with quite the same force as when we were younger. That is because 50,000 tons of hydrogen and a smaller amount of other gasses are being leaked out into space every year, as well as the occasional mars probe. After taking into account the amount of space dust that is pulled in, they reckon the net loss is only 0.000000000000001% every year - it will be a while before a hard hat is enough when dealing with wayward scary trees
Do you align your sleep position north south, or east west, to align your atoms with the Earth's natural Gauss lines or perpendicular?
   / Good morning!!!! #116,858
RS, I just figured the Japanese beetles disappeared because they finished laying their eggs in the ground and died off.
Yeah ... for some reason I was thinking they were around longer ... might be just because I really didn't see all that many of them this year. Typically we have a lot.
Ever dug up one of their grubs? Huge.
Oh yeah ... nasty looking buggers ... see them quite often when doing any digging around here.
A couple of years we had skunks out in the front yard in the evening going around digging them up. Still see holes around where some critter has been digging them out.
I didn't put any traps out this year, either.
:thumbsup:
Good luck on your mowing ... :thumbsup:
   / Good morning!!!! #116,859
   / Good morning!!!! #116,860
Didn’t feel quake at in-laws house in VA.
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
20ft Shipping Container (A57453)
20ft Shipping...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
New/Unused Spirit Electric Tricycle (A57453)
New/Unused Spirit...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
