Good morning!!!!
   / Good morning!!!! #115,131
RNG, I do not have a Fire truck to compare a measurement pic but Rick does.
Are you planning on using the suction to draft an open water supply, pond or pool?
Even though I live above Lake Oroville, it's way to far away to draft from, and the water level would be at least 100' below the pump. Not to mention the fine if I got caught.
Looking a little closer at the smaller of the two suction lines (the one marked with a "2" near the bottom of the panel, the one without the valve handle on it), the locking collar is marked 2 1/2, and the documentation references 2 1/2" discharge and suction valves. Just not sure at this point if that smaller line is for drafting or discharge.
:welcome: Tom! I also tried moving the various valves around this morning, and some are very stiff. I wonder about using petroleum based lubricants on them, though. Do valves of this type use o-rings, which might be damaged by such lubricants, or are they more likely to have old fashioned string packing in there? Wait one, the maintenance instructions do mention o-rings, and suggest Dow-Coring "Valve-Seal" as a lubricant. I'm thinkin' I'll try a little aerosol silicon lube first, being as how that would be easy.
Thanks for the guidance, folks!
More Homework!
   / Good morning!!!! #115,132
I’m for more and better funded police.
:thumbsup: and better trained in some areas too
I got an upset call from my older brother yesterday who used to be head of the local township supervisors in Solebury PA. He was also in charge of
police force for awhile, though they have a chief of course. He was besides himself because an ex supervisor was circulating a petition to defund their
police force. Huh? This is a very wealthy community, very low crime, no record whatsoever of any racial issues/profiling anything whatsoever but yet this
crazy lady decides she was just going to stir the pot. Yes, I think the coronovirus situation is starting to make some folks really irrational. Too much time on their hands
and not enough common sense. Now if she had come out and said we need more mental health counselors, we need more drug education, etc she would make some sense. Not like this small police force was buying SWAT Humvees or crazy equipment.
RNG, small lines are easier to drag longer distances, and for vegetation fires, smaller line with some pressure behind it is likely a good choice for you. If you ever needed larger lines, it would be to hose down your buildings where you needed some elevation but in most cases if you needed a larger line, not likely very safe for you to be anywhere near there. You should invest in some fire resistant clothing also. Do you have a hiding place where you could let a fire go over you and burn out?
   / Good morning!!!! #115,133
Wow, this one really hits home, Drew. The Chico city council met last week to discuss the "defund the police" topic, and several members had expressed interest in pursuing that path. The council got so much negative feedback from the citizens that the topic was voted down, 5 to 2. But then this week, a measure to ban the needle distribution activity was defeated by the same margin, 2 to 5. There are now two citizen groups actively campaigning to replace those five council members in November. I wish I could add my vote to the effort, but I live out in the county.
A couple months ago I picked up a pair of Nomex pants and a shirt, but they are dark blue uniforms, and probably not the best for actually fighting a wildfire. I've got my eye out for the bright yellow shirt/olive green pant outfit worn by the wildland guys, but what I have now is better than nothing. I should also line up some kind of helmet with a face shield, too, but again knowing next to nothing about them, don't feel real good about making a choice at this point.
As far as hiding places go, the house is probably my best bet. During the Saddle fire, the two firemen that spent the night sitting outside with me were planning to retire around the side of the house opposite the fire and let it pass by, then emerge to put out anything that caught. So that's probably what I would do, too.
That, or stand by the firetruck with a hose and just put out anything that came my way. That might not work so well in a wind driven fire, though, and with the steep slopes here, that's very likely to be the case.
Don't forget that the whole house sprinkler system is up and running, too, and it should protect the roof and walls of the building. But there's always the ember threat, and that's what the hoses are for.
   / Good morning!!!! #115,134
Drew, you are absolutely correct in some folks having too much time on their hands. And definitely not enough common sense! I bet if they defunded the police there, then crime goes up, she will be the first one to complain about it!
I finished doing the tractor projects (parking brake extension and step reinforcement), so, now I get to play with making some wing racks for the RC's.
Here are some pics of the tractor stuff
   / Good morning!!!! #115,135
Solebury is right next door to me.
In the late 70's and early 80's I spent a lot of time as a kid in NYC when the police there were way underfunded.
I remember the high crime rate, drive by shootings and whole sections of the city boarded up and sometimes just burning. The south bronx and Brooklyn had many areas where you could get shot during the day as one of the many gang disputes went full out, my father worked in east NY and had to get some bullet holes filled in on his car. This happened by a high school while classes were in session.
I don't want to ever see that again. At the time you could not wear jewelry, watches etc. on the subway. Getting mugged was a real possibility any time of the day/night.
   / Good morning!!!! #115,136
and not enough common sense. Now if she had come out and said we need more mental health counselors, we need more drug education, etc she would make some sense. Not like this small police force was buying SWAT Humvees or crazy equipment. ...
LOL ... if you really wanna see "crazy" I could send ya some links ...
:laughing:
   / Good morning!!!! #115,138
Nice work Ted
   / Good morning!!!! #115,139
Not to be political but I suspect if the call was to reform not defund the police there would be greater support. To me, the police have drifted way far from their purpose. Remember the days as a kid we were taught a policeman was your friend?
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1643 (A58375)
1643 (A58375)
