Good morning!!!!
   / Good morning!!!! #114,601
75F and sunny @ 09:30, heading up to a high of 87F.
Spent some time last night working on the handle of the 8lb sledge. Got it mostly sanded down before I knocked off around midnight. Now I just need to find that recipe for the oil finish that uses beeswax ... :rolleyes:
Probably put the loader on this morning and move some pallets down here to the house to prep for paint, now that the jungle around back is cut down.
Also stuff on list that I wasn't able to get to yesterday.
Hope everyone has an enjoyable, productive, and safe day.
   / Good morning!!!! #114,602
70°F and cloudy this morning, going up to 82° today. Expecting rain throughout today and into tomorrow.
Woke up several times early this morning from loud thunder. I had my face buried in the pillow, but Wife said the lightning lighting up the bedroom was what woke her. That went on for quite awhile, but we got about 2" of much needed rain out of it. There is another storm rumbling through St. Louis city as I type this. Shaking-the-building kind of thunder again.
Didn't get a chance to get out and ride a bit until after 8pm last night, and with the clouds it was already starting to get dark. So, I just rode up and down the driveway a few times, did some road loops back and forth between our mailbox and the neighbors drive, and ended up getting in a grand total of 1.01 miles.
We are four miles north of Trenton, and there is one pizza place in town (Pizza Market) that will deliver to us. They make some pretty good pizza. However, the place we like most (local chain called Imo's) has a location in Highland, nine miles away, and they do not deliver that far. So, we usually end up picking it up. I don't believe we ever go more that three or four weeks without pizza. Generally, it's probably about once every two weeks.
   / Good morning!!!! #114,603
Ron,
Beautiful Lilly pic ... :thumbsup:
Yup - being able to drive into the lumber yard at Menards is nice.
Can't say I'm a big fan of the way they have their "We pull/You pull ..." online order/pickup at store system set up though. You have to go to the back corner of the store - I usually drive into the yard to do it so I don't have to walk all the way back there.
The problem is, if you decide to grab something additional while you're there, they have no way for you to pay and check out there - you have to walk all the way back up to the front to the registers ... and then all the way to the back again.
   / Good morning!!!! #114,604
Good Morning!!!! 65F @ 6:30AM. Abundant sunshine. High 94F. Winds SSW at 5 to 10 mph.
Gosh, Drew, sorry you ended up with a stinker for a buyer. Same thing happened to me when I was trying to sell the undeveloped lot my mom's boyfriend left to me. I was working through a realtor that didn't have much drive, that was all the way across the country. The lot featured a beautiful view, but the house next door was a double wide. Mom's house, a custom build, on the other. It seems like every other week the buyer would come back with a lower offer, and I'd counter by dropping the original price a couple hundred bux, each time telling my realtor if it happens again, put it back on the market. It did, and my counter was instructions to put it back on the market. It closed at my last counter, but it still left me with a bad taste in my mouth of being taken advantage of. I hope you have better luck.
Gotta cheaper ways to tenderize moose flesh, Bill.:eek: Thanks for checkin' in.
I like a little breeze when spraying as well, Eric. But not too much, right? Just yesterday, I took the notebook containing the operating procedures I wrote and placed it atop the battery cabinet, so at least I'll be able to easily locate it. The lithium battery can withstand a much higher depth of discharge without damage than can a conventional lead acid battery, so I figure if it can maintain at least 80% of capacity before switching to the grid for a recharge, I'll be OK in the event of a fire. What is not clear is how to quickly change the controller settings to take advantage of that 80% without wading through menus on a tiny 2"x4" screen that I have to be standing on a milk crate to see. If the generator fails to start and grid power is also down, I might even have to do it in the dark, and I'm not sure that the display is illuminated. And we still have to have the discussion of just exactly how does battery voltage relate to State of Charge, especially since I've seen that the data supplied by the battery company president doesn't correlate well with the behavior I'm seeing in "my" battery. I'm not even sure where the battery voltage is measured; the display inside the battery cabinet has never agreed with the value reported by the system controller.:confused2:
Yes, Thomas, where did June go? Here we are in the heart, and heat, of summer already. What happened to spring?:confused3:
Peekaboo with a diced snake. Nice, Kyle. Maybe a couple moth balls under the hood would have them looking for somewhere cozier to curl up in?
The portion of the oil pan that's leaking was where the mechanic had me make a cutout for the flywheel, necessary because he wanted to use a Subaru flywheel instead of the original VW one that the oil pan was designed for. The guy that made the pan wouldn't do it, and the mechanic's welding skills weren't up to it, either. I tried to minimize the distortion on that part of the pan by clamping it to the steel table when I welded it, but either it wasn't good enough or whoever put the pan on the engine didn't use enough sealant. I used machinist's jacks to bend what distortion I found to under 0.010", but again, who knows what happened to it after it left my hands. I have a new Felpro pan gasket (none was used when the mechanic put it together) and once the 5900 Loctite gets here, it'll be time to take everything back apart and see what's what. That'll be some kind of fun, as the oil pan is also part of the rear engine mount, and I need to figger out how to support the engine while I take it off.
Pretty lilies and no work. What's not to like, Ron?
All this talk of pizza, and in summer's heat, baking one at home in the oven just isn't something I do. Even the toaster oven heats up the whole kitchen. So I'm planning to use the propane BBQ outside, and I'm finding all the "experts" call for a "pizza stone". But most of those are porous and that makes 'em a PITA to clean. So I looked at "pizza steel", and sure enough, most people like 'em. But the store bought ones cost upwards of a hundred bux! So I found a place online that'd sell me a 16"x16" x 1/2" chunk of A36 hot rolled for fifty bux, and ship it for another seven. Still a lot of money for a chunk of steel, but I couldn't drive to the steel supplier here and back for $7, so I went for it. Then I guess you need a "pizza peel" to get the thing on and off the steel. The cheap ones are either aluminum or painted steel, and I don't like the thought of either one on my food, or they have floppy folding handles that just might cause you to end up with pizza on the floor. So the money I saved with the A36 will go toward a stainless steel pizza shovel with a nice long wooden handle. Now all I need is a good vegan pizza recipe. Don gave some hints earlier, but I've managed to lose 'em...
Spent the better part of yesterday checking and rechecking what I'd done to try to solve the hard cold start problem on the van. Came up empty handed, and after reviewing the guru's suggestions, am down to checking the Mass Air Flow sensor, so that's on the agenda for today. Got all the alarm system components out and sorted again, and even got two of the wires connected, so that was a start. Next is to cut the coil wire to route it through the disabler relay that comes with the alarm system, but I need to find a better place to do it than under the steering column, which is where any self respecting thief would look first...
   / Good morning!!!! #114,606
Drew you did not ask my opinion but here it is
I do not like games you folks agreed to a price now a revision he feels you are in a weakened position personally I would counter by raising the price and move on the buyer will never be satisfied. We are still in a sellers market there will be others. If you agree to this there will be more I believe
My thoughts exactly. It’s a sellers market here also.
I’d raise price and say don’t let the door hit you in the azz.
   / Good morning!!!! #114,607
I would just stay with the price, a simple no to the counter offer.
No long winded explanation just a no, have a nice day.
But it is your call, a 40,000 counter offer to me would be not even a negotiation.
   / Good morning!!!! #114,608
Good morning to all! Low went to 54, going up to 86 today. No rain whatsoever... last night the wind kicked up, woke me up around midnight, still windy now, gusts around 45 mph.
Drew, I am in agreement with the others... either hold at agreed price, or raise it and move on.. he may surprise you and have a change of his thinking. Do not short change yourself.
The pizza last night was delicious, ample toppings, cooked perfectly. It must have been the time of day when I ordered it... before the dinner time rush. No one in the store, couple of employees standing outside when I arrived.
LFN, neat video of your driving, beautiful country side. That moose got out of the way fast... fortunately for both of you!
Had another COVID scare... the first week my DIL went back to work, she was exposed to a positive COVID customer. They sent her for testing and fortunately she tested negative. Cases in this state are spiking up since partial reopening.
Today will be more sorting through paperwork and old stuff to be discarded or saved.... a tedious process...
Everyone have a great day!
   / Good morning!!!! #114,609
71°F and .01 inches rain. Have to check the garden.
Another day of brushhogging ahead. Finish up yesterday’s area and move to other end of property and hope to get that half done.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #114,610
Drew, that sux.
I pretty much agree. tell him NO and closing takes place as set.
I’d also tell Realtor that it goes back on market at on market at original price. I would NOT extend the listing contract date either. Leave open the possibility of getting a better agent. In most states, the agent works for the seller if the listing agent and not a buyers agent.
To me, $40k is sizable change and especially in your situation a cuz to pause. As I recall buyer has already beaten you down so remember to consider the total delta not just this margin.
You have been very fortunate with family help, but I’d worry maybe their recommendation weigh more in their favor than yours.
Curious who hired the appraiser, apparently not the best choice.
Best of luck and do what’s best for you.
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
40' CONTAINER (A52706)
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
2003 Big Tex 10PI...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
