Good morning!!!!
   / Good morning!!!! #215,721
While sitting at my computer yesterday, I heard the familiar loud THUD of a bird hitting a window. It was a Brown Thrasher, which is a pretty big bird, and a favorite of mine. I captured these afterward. After 15 mins or so, it recovered enough and flew off.
   / Good morning!!!! #215,722
Good Morning
14° and not a cloud in the sky. It will get warmer, but won’t get above freezing, even with the bright sun.
Here is the laser dot telling me I’m home.
Yesterday found me “studying” 3D modeling and printing some learning projects.
One of which was a cube with a hole halfway through it so I could measure how accurate the printer produces parts. On a 1” cube with a 3/4” hole 1/2” deep, no dimension was off by more than .006, most were within .002. I tried it with two different materials, PLA and PET-G, and the result was consistent between them.
House sure smelled good as wife was baking pumpkin walnut and apple datenut breads.
Took a break to watch a little Diesel Creek on youtube before going to Oddfellows meeting.
Today started with breakfast with the professor, now it’s back to the shop to clean up and wait for the vet, looks like we have to put an alpaca down. The herd is getting old, like all of us.
   / Good morning!!!! #215,724
You've done a really good job on sealing if your at the stage of needing an ERV. It can be pretty difficult to seal up enough to see significant gains after the sheetrocks up.
We started at an appalling 4,000cfm in a door test. Fixing the damper on the fireplace brought it down to 3,000cfm, sealing the crawlspace and making it inside the envelope sealed the uncountable leaks between the crawlspace and the living space, and really improved the energy efficiency and probably dropped it below 1,000cfm. Removing the open flue of a propane oven, and replacing a range hood with no damper brought it below 500cfm. What is left is some leakage around window seals, a gas fired water heater with an open flue, and a little outside air leakage out of the cold air intake on a high efficiency gas furnace. At this point the house is sealed tightly enough to be stale if we don't crack windows. Yes, it took some effort, but we had a specialist group do the crawlspace sealing and insulating. None of the workers were over 5' or over 100lbs, and boy were they quick and efficient.
Peter
Coulda sworn I answered this, but don’t see it. so
A quick check and here on the Hamakua coast found 1 vacate property under $200k, bur sure doesn’t look buildable. The next listing is over $300k. Of course there are $10k lots in Puna and HOVE, but, you’ld really have to want to live there. About$300sf to build a modest house. TBH we couldn’t afford it now. 20 years in, 3k sf house on21 acres, less than $400k.
Thanks! My memory was that most Hawaiian construction was pretty simple unless some haoule turned up with mainland designs, but labor and materials can be so expensive on the Islands that I was a little curious how it balances out in your area. Here it is more like $500/sq.ft., more if one wants bells and whistles. In town, it can be much much more. (Location, location, location...)
One of the young coyotes came by yesterday with the carcass of a feral, pretty, Maine coon cat that had been hanging around for six months or so.😢 She turned up injured, healed up with food and a place to hide, but hadn't warmed up to humans yet. As the rigor had set in, I don't think that coyote killed it, which makes me wonder what got it, as it isn't rattlesnake season. We've seen owl/raptor injuries on our older cats once, but mostly the cats stick close enough to the buildings to stay safe. Mostly.
@Wagtail if you don't varnish the door, I suspect that you will likely be back every year or two renewing the finish. I grew up in a house with oil stained trim, and it was a fair bit of maintenance.
@daugen those combines have all sorts of techniques to reduce dust accumulation, including reversing fans, self cleaning screens, and ducting the air flow around baffles to generate cleaner air for the filters. Personally, I'm impressed that the cabin filters do as well as they do, especially in non-corn harvests of beans and wheat that seem especially prone to generating dust. Going around a field you can't exactly stay upwind. Some of the agricultural radiators have extra wide spacing between the tubes to allow better airflow to reduce dust deposition. I think it is fun to see all of the improvements that have been made over the years for more reliable operation. That said, I also find it interesting how many functions within a combine can (and should) be tweaked to optimize yield and reduce foreign material. I'm waiting to see a bit more AI to make that a bit more automated for farmers.
All the best,
Peter
   / Good morning!!!! #215,725
rip, how much snow do you get at 'the other house'? I am going to hazzard a guess that the house is on a slab (no basement/cellar). If you got some snow and bank it up against the house, it will act as insulation, also it will keep the cold wind out from underneath.
   / Good morning!!!! #215,726
Would like to get a temp gauge to hang outside that I can see from inside. What I see on Amazon looks like low quality
Get yerself a La Crosse weather station like this. I've had that particular model since 2019. Before that I had one with an LCD display for years, also La Crosse brand, so I recommend it. There was nothing wrong with the old one, I just wanted to upgrade.
Just have to be mindful of where you put the outside sensor. If it's in direct sun you'll get "fake news".
   / Good morning!!!! #215,727
71°F and no rain
Our Christmas HH a good time, food, friends, entertaining gifts
Piddle around outside today but really hoping it rains
Prayers for all
Be safe
Have a great tractor day
   / Good morning!!!! #215,728
Warmed up the van and turned on the windshield heat to get the snow and ice scraped off. Roof did not get scraped off since hard to reach at 9 ft. Some dusting in the beginning going down the road but no chunks of ice fortunately
Picked up groceries at curbside. Nice service with young girl bringing snack for Cody as well
Tires were all low on air after the cold spells. Stopped at the barn to get them up to spec. Drain valve on the Quincy compressor air tank was frozen. Need to remember to drain it when it warms up. Dont need it broken again.
Watching some of the episodes of an Australian couple traveling with a toddler around the world in a converted Volvo 6x6.
   / Good morning!!!! #215,729
Frits, I had a 3.5hp Quincy vertical air compressor on the NC farm.
I was surprised how much water came out of it
Since the barn was unheated, had to remember to turn it off completely so
it didn't come back on automatically.
boy do I feel stupid.
And I may be stupid at times, but not sure this time.
But I am puzzled.
Guy comes and checks my large acid neutralizer tank.
Shines flashlight in there and level was where I thought it was.
tests water 6.2 way too acidic
goes through this whole song and dance about how entire unit has to be replaced because
since I did not buy the flushing model, it turned to concrete in a little over a year.
Well that was pure horse manure it turned out.
I told him landlord unlikely to cough up 2500 for a new unit, and now he goes back down, wants to
check on something.
He says to run the water and we did, now at 7.2, then 8.0.
why?
The two knobs on top were turned to off.
one I have never touched them.
Two I haven't even been in that area of basement for two months,when I changed
other filters last. So who turned those bright red valves to the off position.
I wonder if I have a ghost. I've never touched them ever since install.
so I gave the guy a nice tip and said that's one for the home team.
unit has been working fine for a year and two weeks ago stops.
but the internal level still almost full.
whole thing doesn't make much sense.
I must have a ghost
   / Good morning!!!! #215,730
But I am puzzled.
check on something.
why?
I must have a ghost
Who has keys and who has motive.
So probably a ghost who likes acidic water ? :)
   / Good morning!!!! #215,731
   / Good morning!!!! #215,732
Currently 34F and "Fair" with plenty of sunshine ... so we've beat the predicted high for the day by 1F. Low this morning hit 4F @ Clinton Station.
Ten Day calling for four days with highs in the 40's, one day with a high of 56F, also 42F with AM showers on the 25th ... so likely no "White Christmas" here ...
Got bucket taken down last thing last night.
Just fired off the torpedo heater, garage temp was @ 38F.
Coldest it has gotten out there so far was 29F ... but not for long and nothing froze.
Supposed to get to 44F tomorrow for the high at which point I will throw both 5 gallons cans in the loader bucket and head over to the barn and get more diesel fuel to refill the torpedo heater which is now down to around 1/4 tank.
Probably grab some more 2 x 4's while I'm over there as there's none left in the garage.
No mob at the feeders presently, assume they have probably emptied out the hopper ... so will mix up a bucket to refill that plus some for the ground feeders along with suet cake.
Only a half a cup left in the pot this morning ... so will need to brew another. This week's selection is Peet's "Big Bang" ...
Now that I've picked up the Menards order I have another 16 containers to put pumpkin in the freezer ... so will get started on that early as it takes some time between prepping, baking, and getting the puree packaged up, labelled, and put away.
Probably some more work out in the garage while the pumpkins/squash are toasting.
Then back down to utility room project later.
I have to reposition a gas valve to extend the line out to the garage which involves shutting off the supply to the entire house ... so will probably do that tomorrow (44F) or Thursday (56F) since it will be much warmer.
Last rebates I sent into Menards still not showing up in their system ... which is holding things up on the UV sterilizer ... 🤬
Hope everyone is having a decent day ... (y)
   / Good morning!!!! #215,733
Pebbles seems to be able to understand some words.
Wife was going to take her to the vet. She was asleep in the rocking chair, I'm sitting in lazyboy. Wife comes downstairs, says she will get the cat carrier ready. I'm still sitting in my chair, pebbles gets up and runs to the basement. Found her hiding.
BB was in some more today, he prefers to stay in than to go out. Snagglepuss wants out, in, out... I had just put BB out then wife comes home, BB is back in.
says it's 36 deg out, snow on deck is melting.
The garage pellet stove ran out of pellets before I got up this morning but I was trying to guess on how many for it to go out today.
Brother was at the farm, water line froze at the pumphouse, think he got it thawed out.
   / Good morning!!!! #215,735
A ghost that soured on @daugen?
I tired of manually draining my air tank, so I added an intercooler with a fan and self draining coalescing filter downstream, before the main tank. I still pop the manual drain just in case, but I rarely even get a mist out of it now. None of my downstream filters show any measurable condensate, which is great. However, this isn't exactly a high humidity area.
Our dogs have always recognized the word "Vet", but so far they have all liked the vets. Fingers crossed.
All the best,
Peter
   / Good morning!!!! #215,736
Chilly start this morning 4F 24F now clear sky 31F high no wind.
Good day at work afternoon did some puttering outside,Mrs. tag along stop at TSC critter food,waiting in check out line Mrs. with her shopping cart came up behind me with BIG smile,2 new cat beds bunch toys cat treats and cat food,guess kittens were on Mrs. Claus nice list this year. :rolleyes:
First day of Brownville's Food Pantry on YT,just before sunset several BIG boys show still having their head gear on :eek: now mostly Does with their young pair of foxes running barking,couple weeks going to get interesting.
Plans for the evening dinner soon than numb it to pillow time.
Enjoy your evening all.
   / Good morning!!!! #215,738
52.2 for high today 38 now even warmer tomorrow
Slow day today no care giver I don’t mind just shoots my day
Ken glad dog like snow
Rswyan hope Menards gets your rebates straight
Thomas kitty’s will be happy
Hope water line at dads ok BEF
   / Good morning!!!! #215,740
Good (Wednesday) morning. Overnight Low of 11C and it's presently 27.3C, clear with a steady breeze.
Yesterday arvo I stopped at the Shire Council depot only to find that they no longer 'hire out' their cherry-picker/bucket. It's a liability 'thing' that happened this year. They did give me a phone number of the arborist that they use, who is scheduled to be in the area in January.
I then carried on with sanding the Church doors... learning the various "speed" settings on the orbital sander. 😐 Fast does NOT equal Deep sanding. Fast does equal Delicate/Light sanding. I still have a ways to go.
Today is 'into town' day for a PO stop, then groceries. The arvo will be spent back at the Church.
I used a tennis ball for years also.
That's what I have set up in my carport... any further and I may bump the wall of my rammed-earth house.
IMO the more protection you have on those doors the longer your work will stand up to the weather Randy 🙏 So I would say yes
Thank you to all 12 responses. I strongly suspected that this was the case and I did purchase a clear "marine grade" varnish to do the job, but it's always good to check with the Brain Trust. These doors face South which means that they do not receive direct sunlight.
Ta, Mates.
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
iDrive TDS-2010H...
John Deere 25A Flail Mower Tractor Attachment (A59228)
John Deere 25A...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
