Pirate
Know of a good replacement for a sodium vapor fixture? I have one sodium vapor fixture on each end of the home pointing out and one just bit the dust. Debating a LED replacement. These are on during dusk the entire time.
I have the 50 watt 6000k version of that light and it is really bright (supposed to be equal to a 150W HPS light). It is also $30ish, so not too bad.I Have been looking also. They are pricey! Here is one at Amazon LE® 240W Super Bright Outdoor LED Flood Lights, 600W HPS Bulb Equivalent, 21600lm, Daylight White, 6000K, Security Lights, Floodlight
Honeywell has one. Bought but not installed. Costco sells it.
Basically have the same setup, except mine have the dusk to dawn sensor and i used 95W equivalent 1300lumens westinghouse PAR38 bulbs 3000k..I don't know how much light your current light gives off, but I replaced one of these 500W units:
Lithonia Lighting 300-Watt Or 500-Watt Quartz Outdoor Halogen Bronze Visored Floodlight-OFL 300/500Q 120 LP BZ M6 - The Home Depot
with 75w led floods screwed into one of these:
Lithonia Lighting 2-Lamp Outdoor White Flood Light-OFTH 300PR 120 WH M12 - The Home Depot
I think I have more light now than I had before.
Here is a 50W 3000k LED for $35: LTE Super Bright, 50W, Outdoor LED Flood Lights, 3500 Lumen, 150W HPS Bulb Equivalent, Warm White, 3000K, Waterproof IP66, Outdoor Floodlights, Security Lights. - - Amazon.comBasically have the same setup, except mine have the dusk to dawn sensor and i used 95W equivalent 1300lumens westinghouse PAR38 bulbs 3000k..
Fixture $20, bulbs $8 each.
Lithonia Lighting 2-Light Outdoor Bronze Flood Light-OFTH 300PR 120 P BZ M12 - The Home Depot
Westinghouse PAR38 Reflector 15 Watt (Replaces 90 Watt) Medium Base Warm White LED Outdoor Lamp
I would have gone with a built in LED one but i HATE HATE 5000K lights, I like the 2700-3000K range looks more like incandescent
