Good landscape rake - cheap (Part 2 - Daver1963's attempt)
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #21
Here's a rough idea of what I meant - also, whenever I try to get TWO pieces of tubing to go into TWO separate sockets while welded to a third piece, if I'm lucky it only takes an 8 pound hammer to get 'em to cooperate - so I've taken to making ONE of the two as a "slipper tee" whenever possible - this gives just enough slop so it fits without giving you fits :D
If anyone didn't get that last part, I'll go take a pic of one of my current project parts to illustrate... Steve
Finally got my 3-point hitch painted and a stand put on my rake.
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #24
I have one I made that's similar, and found it does a great job of cleaning up debris. This should give you good service.
I decided that the single tines with the rubber between the cup and the tine was bending too much. I changed them out for the double tine rake teeth.
Went from this: 20140218_155847_zpshc6fvkqo.jpg
To this: 20151115_152227_zpsqyva95ye.jpg
I raked some today and it seems like it is doing better. Now I just need to fabricate something to attach to the front end loader to pick up the piles of pine needles better.
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #26
Here's a simple way to accomplish a rake. Take the pickup reel off of a baler. Square or round baler doesn't matter. Build a frame and bolt the entire line of teeth on. Use all four pickup reels about 12" apart.
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2004 CASE 40XT SKID STEER (A52707)
2004 CASE 40XT...
402 (A52706)
402 (A52706)
GODWIN (INOPERABLE) 3,500 PSI HYD. POWER PACK (A55745)
GODWIN...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
