Good Grinder Stand
/ Good Grinder Stand #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
Recently got a new grinder. Couldn't find a good grinder stand. Everything I looked at was too flimsy, too costly, or too short. Mostly too short. They all seem to be 30 inches or so which for me at 6-4 is not a good working height. The usual solution is a truck wheel and heavy steel pipe but I didnt have that laying around. I found a used import drill press for $50 on Craigslist. Not too good as a drill press but an excellent grinder stand. For the price you get a stand that is as good as anything commercially available, and with an adjustable table. Mine is at 42 inches. Plus a decent motor, hardware, bearings, shafts, all can probably be recycled for something down the line.
/ Good Grinder Stand #2
I like it, good for you! Now if I only had an old drill press lying around.
/ Good Grinder Stand #3
Thats a good idea. :thumbsup:
When I use my grinder I mount it on my drill press table. It is a pain to bolt and unbolt each time but works good like you say. I never thought to find a used old or import drill press just to get the stand. Thanks for the idea.
/ Good Grinder Stand #6
Great idea -- I found some old restaurant tables with a very heavy round base and four inch pipe with a 1/4 plate welded on top to fasten the table top on --@ $2.00 each they make great grinder stands. If you want higher ones - find a bar table:D
/ Good Grinder Stand #7
I did the same thing yrs ago. Nice stable and heavy plus being able to adjust up and down is a bonus!!
213086 (A64276)
213086 (A64276)
Mower King QA Brush Cutter (A64912)
Mower King QA...
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
WELDING TABLE (A68842)
SDlanch SDLGC8 Electric Golf Cart (A64912)
SDlanch SDLGC8...
2018 Toro Workman HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
