Good generic chain saw press or scabbard?
   / Good generic chain saw press or scabbard?
Amigauser, thanks for the link. The vertical mount version is particularly interesting. Eric, the description says it can be mounted in either right or left hand orientation. May even be adaptable to work on the rear windshield wiper fluid reservoir bracket. Still like your design though, as it more completely protects the bar and chain.
My basic design copied a Quad Boss rack without using angle iron for the front cross bars so as to make the holes for carrying smaller tools. I also swiped the Koplan shoulder so as to rest the weight of the saw on the saw's main casing instead of the the blade. The difference is that I spaced the shoulder away from the scabbard holder so that the saw's gripping teeth had room without tearing anything else or themselves up.
QuadBoss | ATV Chainsaw Carrier
   / Good generic chain saw press or scabbard? #32
The one thing the Kolpin press lacks is the scabbard holder to protect the bar/chain. This does potentially present some problems with the chain teeth being able to do damage to the user in the field, while the saw is mounted in the press. I tried to eliminate this as much as possible, which is why I mounted the unit on the right side so the teeth would be away from the usual mounting left side of my backhoe. Like on a horse, I most often mount both the tractor and the hoe on the left. The Sawgrip looks to be somewhat more versatile, for some applications, but at somewhat higher pricing.
   / Good generic chain saw press or scabbard? #33
I added some round bar to my blade to accept the kolphin saw boot I have for my 4 wheeler
   / Good generic chain saw press or scabbard? #35
Its used for people that ask to many questions
   / Good generic chain saw press or scabbard? #36
   / Good generic chain saw press or scabbard? #37
The three forms and uses of to: I'm going to Granma's house to eat too much turkey. Two wolves showed up and ate all the turkey. Questions? :)
   / Good generic chain saw press or scabbard? #38
   / Good generic chain saw press or scabbard? #39
What's OT?
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
Deere 310L (A53317)
Deere 310L (A53317)
