Good generic chain saw press or scabbard?
   / Good generic chain saw press or scabbard?
Amigauser, thanks for the link. The vertical mount version is particularly interesting. Eric, the description says it can be mounted in either right or left hand orientation. May even be adaptable to work on the rear windshield wiper fluid reservoir bracket. Still like your design though, as it more completely protects the bar and chain.
My basic design copied a Quad Boss rack without using angle iron for the front cross bars so as to make the holes for carrying smaller tools. I also swiped the Koplan shoulder so as to rest the weight of the saw on the saw's main casing instead of the the blade. The difference is that I spaced the shoulder away from the scabbard holder so that the saw's gripping teeth had room without tearing anything else or themselves up.
QuadBoss | ATV Chainsaw Carrier
   / Good generic chain saw press or scabbard? #32
The one thing the Kolpin press lacks is the scabbard holder to protect the bar/chain. This does potentially present some problems with the chain teeth being able to do damage to the user in the field, while the saw is mounted in the press. I tried to eliminate this as much as possible, which is why I mounted the unit on the right side so the teeth would be away from the usual mounting left side of my backhoe. Like on a horse, I most often mount both the tractor and the hoe on the left. The Sawgrip looks to be somewhat more versatile, for some applications, but at somewhat higher pricing.
   / Good generic chain saw press or scabbard? #33
I added some round bar to my blade to accept the kolphin saw boot I have for my 4 wheeler
   / Good generic chain saw press or scabbard? #35
Its used for people that ask to many questions
   / Good generic chain saw press or scabbard? #36
   / Good generic chain saw press or scabbard? #37
The three forms and uses of to: I'm going to Granma's house to eat too much turkey. Two wolves showed up and ate all the turkey. Questions? :)
   / Good generic chain saw press or scabbard? #38
   / Good generic chain saw press or scabbard? #39
What's OT?
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2024 BOBCAT E88 R2-SERIES EXCAVATOR (A52707)
2024 BOBCAT E88...
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
2020 CATERPILLAR D4K2 LGP CRAWLER DOZER (A52707)
2020 CATERPILLAR...
EINGP PHT620 HAND PUSH ELECTRIC FORKLIFT (A57192)
EINGP PHT620 HAND...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
