Good drill bits
/ Good drill bits #21
I use Cobalt bits in the drill press only. They are to hard and brittle to use in a hand motor, they'll grab and break. All my hand drilling is done with HHS bits.
And I never use bits with a reduced shank. Sometimes they can't be griped enough to prevent spinning in the chuck.
/ Good drill bits #23
I used to own a cutting tool manufacturing company, so I'll give you my advice. There are many grades of SS and some are much harder than others. In general HSS is not hard enough to drill SS. Cobalt and carbide are the drill types that you would need. Don't worry about coatings, they're typically just for production applications. You want 100-150 sfm for carbide and double that or more for cobalt. Sfm (surface feet per minute) πD x rpm if you're using machine tools but, otherwise about half trigger on your hand drill. A drill press is ideal, especially for carbide, but you should be able to drill straight enough for cobalt. Cutting oil or coolant is only necessary for deep holes - thicker than 1/8".
/ Good drill bits #24
I've only recently stumbled across proper cutting oil. Before this, I used old motor oil, 3in1, PB blast, WD-40 whatever I had on hand. The cutting oil for thicker steel really seems to make a difference. I use stuff called Tap Magic, I think Forney is the brand name.
/ Good drill bits #25
By high pressure, I mean enough force so that you are actually cutting into the metal making decent chips. I see way too many people basically letting the bit spin against the metal just work hardening the metal from the heat.
Concur
And what is slow speed in your guys books?
I look for smoke and feel for heat and watch for Chip production...
/ Good drill bits #26
Until recently, I kept my good bits for "special" projects, never wanting to ruin them for normal stuff. So naturally I never used them and used HF coated bits instead. Well, on one project with harder metal that was burning up the HF drill bits, I grabbed a used American made drill bit that I had bought in a pile of tooling. What a difference. What took minutes before took seconds. I was converted. An example of a good American made drill bit would be Chicago Latrobe. I now have several boxes of HF bits still unopened that I guess will be used for wood and plastic and if someone needs to borrow some.
Ken
/ Good drill bits #28
For those who do not know what a Cole Drill is:
Drilling Holes, Cole Drill, Ratchet Drill
The drill's lost/scrapped/ long gone but I still have the Cole vice that came with it. Not a very good vice. I'm pretty certain my dad paid way too much for the set at the time. (Early 60's)
Terry
/ Good drill bits #29
I used to own a cutting tool manufacturing company, so I'll give you my advice. Cutting oil or coolant is only necessary for deep holes - thicker than 1/8".
Actually, thin material and when the drill breaks through the back side is when much of the damage is done. Thin material offers no heat transfer away from the cutting and when it is breaking through, there is high heat and material can push away, adding to the friction. Machining parts for the paper manufacturing business meant 50% was stainless. It's just a different material with different machining characteristics.
/ Good drill bits #30
I agree, but this is based on the assumption the OP is only drilling a couple holes and then he's done with it. In a production environment you're always going to run coolant.
/ Good drill bits #31
Drilling stainless can be an art. The one thing you have to watch for is work hardening the material by not drilling fast enough. This is what most people run into, when they complain that it's really hard to drill. When I say fast enough, I mean advancing the bit, not necessarily RPM's. For me, drilling stainless has been a one shot deal. If you start with a sharp bit, lube and the right pressure/rpm you'll drill right through it. If you screw up any of those, you'll fight drilling that hole, because you work hardened the surface and the bits won't grab.
/ Good drill bits #32
The term you're looking for is feed rate. You can actually go online and find charts for proper speeds and feeds for different materials and cutters. For the hobbyist of for low production numbers, that will get you pretty much spot on every time.
/ Good drill bits #33
So back to the OPs question, what is the best set of drill bits to get ?
/ Good drill bits #34
Don't know what the best set of drills is. Never compared. But never had any complaints with any of the American made bits I have used, usually sourced from industrial supply companies, like msc, McMaster Carr, Grainger, Fastenal, etc.
Never had any idea what they actually "carried" or what I was actually using, because most if the fractional sub-1/2" bits don't have a name on them.
The larger bits, there are many good brands. Hertel, UB, Cleveland twist, PTD, chichage Latrobe, etc.
It cannot be overstated that you need SLOW speed and lots of pressure (feed rate).
Yes the stainless will work harden if you run too fast (rpm) or too little pressure or both. And yes you will fight the hole the rest of the way.
Forget a pilot hole with the usually split-point drill bits under 1/2". All you will do is destroy subsequent bits, break an arm on a hand drill, rip parts out if your drill press vice, etc. And on the bigger bits with a chisel point, only pilot enough to clear the web of the chisel
/ Good drill bits #35
Best drill bits are going to be OSG, Sandvik, Guering, or Kennametal, but these aren't likely in the price range the OP wants to spend.
I think fro a consumer drill bit, the Dewalt bits are about as good as you're going to get. They have a really nice uniform grind and a free cutting point. Cobalt all the way.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
40' Shipping Container (A66285)
40' Shipping...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
2006 Flori Off Road Dump Truck DF40 (A65579)
2006 Flori Off...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
