good buy?
/ good buy? #2
Do you have 3-phase power at your house? The link states that welder requires 3-phase power input. In the U.S. typically only large businesses have 3-phase power so a homeowner would be required to buy a phase converter to use this at home - which can be prohibitively expensive. Hence, The 3-phase power requirement would drastically affect the value from a homeowner perspective.
That said, that appears to be a lot of welder for very little money if you are lucky enough to have the 3-phase input power needed to run it. I doubt you would ever outgrow it from the welders capability perspective as it states a welding output of 375 amps which is huge and capable of running extremely big rods which most homeowners will never be welding metal that thick.
/ good buy?
I do not have phase 3 power at home.
Sounds like it has more jam than I will ever need.
Thanks very much for the advise.
The hunt continues.
/ good buy? #4
You can look into a used Lincoln AC/DC on Craigslist. I'd recommend something with DC welding capability but AC only is far cheaper for occasional farm use.
If you want to buy new a Everlast PowerArc 160 or 200 can be bought very reasonably. They are DC, 220V, and light as a feather (comparatively). Very easy to learn on and put down gorgeous welds with just a little practice.
/ good buy? #6
Yes i feel it's worth it. You can carry on with it.
/ good buy? #7
I agree that the Everlast Power Arc 200, is really forgiving. It was making better welds in a half hour than any weld I ever made on an AC buzz box.
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2021 CAM P4EC16  16ft Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2019 KENWORTH T680 (A63569)
