Backhoe Going to buy a #7 backhoe
   / Going to buy a #7 backhoe #31
You can also download the 750's operator manual from there to if you do not have one. I would attach it but my guess is that it will be to big at 38MB. On pages 37-41 it has the hydraulics info for it. The 7 BH manual also listed info in it as well.
I never could figure out how those numbers relate to mine. LV0007X250168
Well I finally jury rigged enough hydraulic hoses and fittings to finally see the hoe move a small amount.
But I had to unhook my loader.
Remember back in post #24 the pic I posted on how the bucket is connected? So I guess both of the top hoses has pressure. This Bush Hog loader has 3 hoses. 1 Pressure, 2 Power Beyond and 3 back to tank.
I assume the top hose in pic is pressure? the next one under it is power beyond.
Anyway I blocked the top outlet, connected the lower one to the hoe and it seems to work.
Now here is the weird thing. Back when my dad and I was hooking up the loader we couldn't get it to work, and somewhere before the internet I found some info where we had to remove a plug or install one inside one of the 2 outputs. Guess I can look tomorrow and figure it out.
And there is a learning curve figuring out hydraulic threads and fittings.
Ok, I found this. There is a plug in there so the loader will work.
Well 14 months later its actually bolted to the 750. All that is left is a few bolts in fenders and put new seals in the stabilizer cylinders.
I made my own front and rear hangers and modified the lower frame.
I ran into a big problem with 2 of the hinge pins in the bucket, they were completely frozen in place. 20 ton press couldn't do anything so I had to bore out each pin from each side as deep as I could go with drills and boring bar. What a nightmare. Case hardened pins. 4 days it took to get them out even with a 1/16" cutoff wheel on grinder.
I replaced 24 grease fittings. I dont think the dip s*^ts had EVER greased the pins.
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
2013 JLG 8K TELEHANDLER (A58216)
2013 JLG 8K...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2005 Volvo VNL Truck, VIN # 4V4N19TG25N374995 (A57453)
2005 Volvo VNL...
SEED TENDER TUBE (A52708)
SEED TENDER TUBE...
