Backhoe Going to buy a #7 backhoe
   / Going to buy a #7 backhoe #31
You can also download the 750's operator manual from there to if you do not have one. I would attach it but my guess is that it will be to big at 38MB. On pages 37-41 it has the hydraulics info for it. The 7 BH manual also listed info in it as well.
I never could figure out how those numbers relate to mine. LV0007X250168
Well I finally jury rigged enough hydraulic hoses and fittings to finally see the hoe move a small amount.
But I had to unhook my loader.
Remember back in post #24 the pic I posted on how the bucket is connected? So I guess both of the top hoses has pressure. This Bush Hog loader has 3 hoses. 1 Pressure, 2 Power Beyond and 3 back to tank.
I assume the top hose in pic is pressure? the next one under it is power beyond.
Anyway I blocked the top outlet, connected the lower one to the hoe and it seems to work.
Now here is the weird thing. Back when my dad and I was hooking up the loader we couldn't get it to work, and somewhere before the internet I found some info where we had to remove a plug or install one inside one of the 2 outputs. Guess I can look tomorrow and figure it out.
And there is a learning curve figuring out hydraulic threads and fittings.
Ok, I found this. There is a plug in there so the loader will work.
Well 14 months later its actually bolted to the 750. All that is left is a few bolts in fenders and put new seals in the stabilizer cylinders.
I made my own front and rear hangers and modified the lower frame.
I ran into a big problem with 2 of the hinge pins in the bucket, they were completely frozen in place. 20 ton press couldn't do anything so I had to bore out each pin from each side as deep as I could go with drills and boring bar. What a nightmare. Case hardened pins. 4 days it took to get them out even with a 1/16" cutoff wheel on grinder.
I replaced 24 grease fittings. I dont think the dip s*^ts had EVER greased the pins.
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2016 Ford F-250 4x4 Crew Cab Pickup Truck (A55852)
2016 Ford F-250...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
14179 (A55788)
14179 (A55788)
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
