Going rate for dozer and operator?
/ Going rate for dozer and operator? #1
60047
Still searching
I have ten acres of lightly wooded land that needs clearing. I've tried a disk mulcher, drum mulcher and just popping the trees one by one. The result is not what I'm looking for. I recently saw a Cat 963 smooth out a couple acres without even trying to hard.
What is the going rate for a medium-sized (~D6) dozer and operator? I'd like to have an idea of what to expect before calling around.
/ Going rate for dozer and operator? #2
Depending on where you are located, rates will vary $150 low side to $200 hr plus transport costs range $250-350? each way. Then you will have a few piles of trees to burn/remove too. Depending your final plans and soil type you may need topsoil etc.
I'm outside of Chicago. Yes, the burning isn't a problem.
/ Going rate for dozer and operator? #4
A dozer is good for shoving over trees but not good at making piles that actually burn. You’ll probably end up having to get a trackhoe to burn and pile everything.
/ Going rate for dozer and operator? #5
I hired a D6 last winter for $115 per hour, since he was there all day no trip charge. Another operator was $95 per hour with a $100 trip charge he had a John Deere 750.
/ Going rate for dozer and operator? #6
I recall a fella in south central MO advertising on FB Marketplace for maybe $85 an hour. I think he had a minimum of say 4 hours. Some go that route instead of having an extra transport fee. I can rent a JD650 that's about 75 miles away for $515 a day plus whatever it costs to transport it. Or, $1515 a week. But then I have to run it so having a skilled operator is preferred for me.
/ Going rate for dozer and operator? #7
I'd hire the 963 waaay before a dozer. Like 4570 said, dirt doesn't burn well and a dozer can't make a good (tall) pile.
A good operator on a 963 will have a lot of trees (including the stumps) in a pile in a days time.
/ Going rate for dozer and operator? #8
A loader is made for loading not clearing. They might be a little better at building a pile vs a dozer but they still can’t pickup and carry trees. And they don’t have any good way to dig a tree bigger than it can push. A trackhoe is what you need.
/ Going rate for dozer and operator? #9
I'd argue with that, the slightly less efficient tree digging of a loader is more than offset by the moving of the trees to a central burn pile that is totally impractical with an excavator. Smaller trees pop right out and you can "roll" a dozen at a time to the pile. By the time your there the root ball is mostly free of dirt. Same thing for bigger trees, just not as much. Don't get me wrong, I love an excavator, but have done a LOT of clearing with a 953, one size under a '63.
Ideally it would have a root rake with clamps.
/ Going rate for dozer and operator? #10
A large trackhoe will move brush better than you’re giving it credit for. You can dig up several small trees and grab them all in the thumb and carry them. A root rake with clamps would be a game changer on the track loader but a machine that just pushes is hard to move brush and build a pile with.
Can a the wheel-loader equivalent of a 963 be as effective at pushing and piling as an actual 963? Specifically, I'm talking about a Cat 950 with root rake and clamps.
/ Going rate for dozer and operator? #12
I have no experience clearing with a wheel loader and would wonder how they did on a less than perfect surface like a quarry. They certainly have the weight and power, but is it effective in loose dirt not to mention mud?
2022 Bobcat S76 R-Series (A64911)
2022 Bobcat S76...
Hunter Engineering Tire Changer (A64912)
Hunter Engineering...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2016 WIRTGEN W150CFI MILLING MACHINE (A65056)
2016 WIRTGEN...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
