GM unveils new 6.2 1/2t specs
   / GM unveils new 6.2 1/2t specs #81
This may have been covered (I haven't kept up with this thread) but just wondering. All this power and you can't buy it in a true "Work Truck" spec-only high end versions.
High HP/Torque numbers are one thing in a truckwork truck application. In a toyhauler, I look at them as something else. Yes the numbers are the same but is the durability (duty cycle the right term?) an issue??
I know. Very aggravating.
This engine with a manual transmission in a rubber floored, crank windowed, 3/4t, 4wd, 3 pedal, 2 stick truck would be real nice.
   / GM unveils new 6.2 1/2t specs #83
You can buy that truck in a Ford minus the m/t. You can even get a a/c delete if you want.
   / GM unveils new 6.2 1/2t specs #84
I am pretty sure you can get a ecoboost in a XL.
   / GM unveils new 6.2 1/2t specs #85
Yes, you can. You have to get an 8' bed though (regular cab), I believe, but what's a work truck without a long bed? :)
   / GM unveils new 6.2 1/2t specs #86
PU margins for work trucks are not as fat so just sell the upgrade package to get that engine may be the plan. :)
But I have no interest in an automatic. None whatsoever. Ac delete is nice. I don't care for ac much. Works in both my vehicles. Never use it though.
   / GM unveils new 6.2 1/2t specs #88
Just curious, what don't you like about automatics?
No appeal to me.
I like shifting. The simplicity. The generally deeper gearing. Less to go wrong. Easier to work on. Less maintenance. Better engine braking.
Plus it's FUN!!
   / GM unveils new 6.2 1/2t specs #90
No appeal to me.
Plus it's FUN!!
While I claimed I was buying for a project truck for my son's first vehicle in part I bought the worn out 1998 S10 Step Side PU because it was so much fun to drive with the 5 speed. I use the brakes very little in fact.
When I bought the 1989 flat dump truck I stayed away from automatics because I planned to keep it for 20 years. I am OK with automatics but not in old work equipment.
UNUSED AGT MX12RX EXCAVATOR (A51243)
UNUSED AGT MX12RX...
Wolverine Mini Skid Steer Auger Drive & Bit (A50515)
Wolverine Mini...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
5' X 20' 3/8" THICK STEEL PLATE (2) PIECES (A51244)
5' X 20' 3/8"...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
