GM unveils new 6.2 1/2t specs
   / GM unveils new 6.2 1/2t specs #81
This may have been covered (I haven't kept up with this thread) but just wondering. All this power and you can't buy it in a true "Work Truck" spec-only high end versions.
High HP/Torque numbers are one thing in a truckwork truck application. In a toyhauler, I look at them as something else. Yes the numbers are the same but is the durability (duty cycle the right term?) an issue??
I know. Very aggravating.
This engine with a manual transmission in a rubber floored, crank windowed, 3/4t, 4wd, 3 pedal, 2 stick truck would be real nice.
   / GM unveils new 6.2 1/2t specs #83
You can buy that truck in a Ford minus the m/t. You can even get a a/c delete if you want.
   / GM unveils new 6.2 1/2t specs #84
I am pretty sure you can get a ecoboost in a XL.
   / GM unveils new 6.2 1/2t specs #85
Yes, you can. You have to get an 8' bed though (regular cab), I believe, but what's a work truck without a long bed? :)
   / GM unveils new 6.2 1/2t specs #86
PU margins for work trucks are not as fat so just sell the upgrade package to get that engine may be the plan. :)
But I have no interest in an automatic. None whatsoever. Ac delete is nice. I don't care for ac much. Works in both my vehicles. Never use it though.
   / GM unveils new 6.2 1/2t specs #88
Just curious, what don't you like about automatics?
No appeal to me.
I like shifting. The simplicity. The generally deeper gearing. Less to go wrong. Easier to work on. Less maintenance. Better engine braking.
Plus it's FUN!!
   / GM unveils new 6.2 1/2t specs #90
No appeal to me.
Plus it's FUN!!
While I claimed I was buying for a project truck for my son's first vehicle in part I bought the worn out 1998 S10 Step Side PU because it was so much fun to drive with the 5 speed. I use the brakes very little in fact.
When I bought the 1989 flat dump truck I stayed away from automatics because I planned to keep it for 20 years. I am OK with automatics but not in old work equipment.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
UNUSED FUTURE MINI EXCAVATOR HYD 12" AUGER (A51244)
UNUSED FUTURE MINI...
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
UNUSED INDUSTRIAS AMERICA 180 HYD SCRAPE BLADE (A51243)
UNUSED INDUSTRIAS...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
