GM 6 speed auto- Clunky?
/ GM 6 speed auto- Clunky? #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I have a 2011 Silverado 4wd with the 5.3 and 6 spd auto trans. I like the truck, not real sure of the trans. It makes a clunking sound downshifting, done it since new. Dealer checked, all normal. Also, if I hit the brakes, sometimes it will "push" me slightly when downshifting into 1st. Anyone else experience these issues with this tranny?
/ GM 6 speed auto- Clunky? #2
I'm not sure of they share the same transmissions but my 2500HD has the same issues (6 speed auto). Clunks going from 3rd to 2nd when you slow down enough downshift but have to lightly accelerate a moment later.
Dealer told me the same thing. When I was trying these trucks out, two of them did it. My old 4 speed did it too. It's irritating, but normal. Or at least common.
/ GM 6 speed auto- Clunky? #3
The 6-speed in my '07 2500HD will clunk at low speed/throttle up-shifts from 1-2, or 2-3 now and again. Dealer said nothing is out of the ordinary when I took it in under warranty.
Good to hear its not isolated to me. It is rather annoying.
/ GM 6 speed auto- Clunky? #5
Does it do this in Tow/Haul too?
/ GM 6 speed auto- Clunky? #6
I have a 6sp in a 2011 GMC 6.2...I don't fund it clunky at all...Sometimes if you catch it between gears on a downhift it can be a little harsh, but that's normal.
/ GM 6 speed auto- Clunky? #7
The engine braking part can seem clunky I guess but mine is an 08 and has been the same since new. Always works fine. GM did have an issue with the trans tailpiece/drive yolk that needs a special grease on the splines or it will clunk if it cannot slide easily.
Yea, that downshift gets me sometimes. Feels like a slight lunge forward, even when brakes are applied. This is my first 6 spd. All other trucks were torque shift fords, 4 spd gm/ford or manual.
/ GM 6 speed auto- Clunky? #10
Mine has not done it in tow haul either. Won't do it during manual up shifts either.
/ GM 6 speed auto- Clunky? #11
My 2003 2500HD auto 6 liter has never clunked 2wd, towing or not. I'll get that when I go into 4wd and out sometimes at a stop.. Must be something new.
/ GM 6 speed auto- Clunky? #12
i have a 2011 3500hd mine doesnt clunk at all a bad u joint on the rear driveshaft maybe it doesnt happen when going in to 4wd i hear a clicking that it i have a floor mounted shifter
You have the allison correct? Mine is a 1/2 ton.
/ GM 6 speed auto- Clunky? #14
I would check your U Joints and Carrier Bearings if equipped. I have done quite a few in GM trucks as of late. Don't bother letting the dealership fix it under warranty. They just put in the same crap part and you will be doing it again in 25,000 miles. I know of a truck that is on its 4th in 80,000 miles. This last one I did with a aftermarket Moog.
One other though is the transfer case. They have a pump rub issue. Could the noise be coming from it?
Chris
Chris
Not real sure. It is not a ujoint, had those checked by local mechanic. It is coming from the trans, not all the time, almost like I catch it between gears. Done it since new with 7 miles on it.
/ GM 6 speed auto- Clunky? #17
Chris
I beleive the pump rub is a 2007 and earlier issue.
2016 Nissan Sentra Sedan (A61574)
2016 Nissan Sentra...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
John Deere 1530 Tractor (A66285)
John Deere 1530...
