glyphosate and 24D mix Expiration?
   / glyphosate and 24D mix Expiration? #11
....I never had any problems.
Problem would happen if you were to use the tank AFTER spraying 2,4D (you clean like you normally would) then use the sprayer on a sensitive crop like like cotton. You *might* get it clean enough but it takes just molecules of 2,4D to screw up some plants.
If you are using the tank to kill one thing vs. killing another thing - you don't even need to clean it. I guess the OP needs to state what else his plans are for the tank...
Grass can handle 2,4D google says the normal rate for 2,4D on perennial grasses; "Use 2 to 4.2 pints of product per acre per application". That's why you never had a problem.
I'm guessing most of us just use the tanks for killing only... the research station I worked at had separate sprayers for 2,4D since they killed thousands of dollars of research plots one year.
   / glyphosate and 24D mix Expiration? #12
Glyphosate (Roundup) will kill most actively growing plants, so good cleaning after that chemical is important if you want to spray 2-4-D on the lawn to kill broadleaf weeds.
   / glyphosate and 24D mix Expiration? #13
I agree with you somewhat but I was assuming, a near empty tank after RoundUp would only leave a trace amount of it. After you refill the tank with water for a 2,4D spray, that trace amount would not effectively hurt a thing. Now the (full strength) residue left in the spray boom, that is another story!!! Yes, clean the tank....
   / glyphosate and 24D mix Expiration? #14
Agree. Just a triple rinse and flushing the boom would be sufficient.
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
Water Line Hose (A59076)
Water Line Hose...
2025 GPS Trailers (A56858)
2025 GPS Trailers...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
